Everything posted by Gene J
Clutch doesn't disengage
Gene J replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do you adjust a hydraulic clutch??
My daughter called today and could not get the car out of gear. The shifter would not move. Then she could not get it in gear because of all the grinding. Obviously the clutch did not fully disengage. What should I look for for??? The clutch has slowly engaged closer to the floor over time. It only has about 25,000 miles on it. Ideas??
Performance NA exhaust
Gene J replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA good muffler place could do this for you. When the GT needed a new exhaust I got 2 1/4 all the way back! And without a resonator it still sounds the same.
Squeaky brakes.......Looking for a solution
Gene J replied to mckeand13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOEM pads have a rubbery backing already. It works great!
how is subaru not on this list?
Gene J replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmmm. I didn't make this up!!!
Gene J replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. Moron here. I can generalize about Toyotas because I have owned so many and still do. I have not had a major mechanical problem on any of them. Ever. Current fleet includes a Tacoma. Non maintenance item arguably is an O2 sensor but after 11 years I can give them that. Just the usual brakes etc. Wifes Scion. 2.5 years old. Never back to the dealer for anything except for the free oil changes. My Dad's old PU. He passed away and I just like it. A harmonic balancer went bad. The adhesive on the rubber let go and produced a horrible squeal. Still drove fine. But after 22 years I can give them that. It only had two warranty items. The rear spring sagged when he put on a cap. Toyota put on a HD spring at N/C. And there was a rust through on the side of the bed. Fixed N/C. I have had my share of Corollas and nothing but maintenance.
Gene J replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSad to say yes. My 97 Toyota PU is great and warranty work consisted of a glove box door that warped. Everything else has been maintanence. 98 Subaru. Battery, alternator, master cylinder, clutch, lots of light bulbs. Maintanence. Plus ... Need I mention headgaskets?
seatbelt swap...
Gene J replied to offroadsubaruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry it took so long to post. Stopped at the dealer and they were replaced in an hour. The belts look nice and work great! Thanks Subaru!!!
Best / Most devious location for kill switch? And stereo Q's...
Gene J replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHad a buddy who used a minivan door contact on the ashtray. It is used to make connections for power locks when the door is closed. The car would only run if the ashtray was pushed in. Slick! No switch to look for!
seatbelt swap...
Gene J replied to offroadsubaruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDrop an email to the factory. They handled mine with no problem.
seatbelt swap...
Gene J replied to offroadsubaruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts true! Its true! They will be replaced next Friday! Thanks guys!
seatbelt swap...
Gene J replied to offroadsubaruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"Thank you for visiting the Subaru Web site and for your message. I am sorry to learn of the concern with the seat belts in your 1998 Legacy GT Wagon. Per page 6 of the 1998 'Warranty and Maintenance' booklet, seat belt coverage lasts for the useful life of the vehicle and includes seat belts and related components which fail to function properly during normal use. Upon inspecting your vehicle, your Subaru dealer can advise you if the repairs to the seat belts in your vehicle would be covered by warranty or not. When you schedule your appointment to have this concern physically inspected by your dealer, please contact us with the appointment date and the name of the dealer. We would like to follow-up with the dealer upon their inspection of your Legacy Wagon. Thank you for the opportunity to be of assistance. Sincerely, XXXXXXX" I may try to do this on Friday!!!! Gotta love those Subaru folks!
seatbelt swap...
Gene J replied to offroadsubaruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am going to check that out. Our fronts are frayed badly.
Dodge Snow Flake Wheels (lug nuts)?
Gene J replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you go to a real auto parts store they carry Dorman lug nuts. They cab pull one for Chrysler wheels and they know what a Subie needs. They have every combination under the sun! Heck! With those guys I put Lincoln wheels on my Toyota PU!
No start, crank or click - back to the drawing board
Gene J replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat was the problem??? What did he fix? Inquiring minds want to know!!
Gene J replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere is another one to consider for the not starting bag of tricks. Got in the Sub today and all I got was clicks. Hmmmm. Cleaned the battery posts and got the same. Put on the charger and it would not charge, It would not draw any amps. Put the charger to 200 amps for fast start and still no amps drawn. Still the same clicks. I started thinking about a bad ground when the radio would not play. The electrical system would come and go. I pulled the battery out and went to the auto parts store to test it. It would vary from 3 to 10 volts and they couldn't charge it either. New battery solved the problem!
No lowering springs to be found for a 98 GT wagon!
Gene J replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChecked Whiteline. I am very sure I know what "Out of Stock" means.
Eibach. Discontinued H & R Discontiniued B & G Discontinued Intrax Maybe next July. I ordered KYB GR2 struts. They will arrive any day. I did a search but did not find much. Can we cut off 1/3 of a coil???
Ebay Struts
Gene J replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSummitracing.com has the best price on KYB struts. Free shipping just a 10 buck handling charge. They sell lots of stuff besides racing parts for American cars.
Interesting story from a co-worker with an 04 OBW...
Gene J replied to unverviking's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe had a harmonic balancer go bad at 80,000 which ate the front of the engine. SOA paid for the parts. We paid for the labor. Since it was no longer of warranted I was happy. We have to travel 60 miles one way for a good dealer.
CEL on, Knock sensor code, no symptoms
Gene J replied to crazyhorse001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith a bad knock sensor the computer gets very conservative on ignition timing, so no engine damage occurs. Mileage will be poor and power will be down. If you do not check mileage or romp through the gears you will not notice any issues. My wife didn't notice but I did!
Drastic MPG drop in '00 Outback
Gene J replied to ahreno's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre there any codes? When our knock sensor went bad the mileage dropped pretty badly also.
CEL in BFE thins the wallet - now I want a code reader
Gene J replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 9145 works great on all of our cars including out 98 GT. It has paid for it self many times over! http://actron.com/product_category.php?id=249
Weird stalling issue
Gene J replied to hawksoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso check the IAC. I had the same symptoms. It just needed to be cleaned.
Totally SCREWED by AAMCO...
Gene J replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am sorry you misunderstood my point. If any and all problems can be cured by a rebuild then there is no skill used for diagnosis. And today many of the problems are computer problems and the transmissions are mechanically sound. The dealer we took my daughter's to remembered the problem and looked up the TSB. It was repaired inexpensively.
