EJ22T valve cover leak ?
Fairtax4me replied to Megell's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey wanted you to pay $7 a piece for the grommets?!? Glad you got 'em cheaper, but for future reference... https://www.1stsubaruparts.com/partscat.html Part numbers 13271AA051 grommets $2.52 each x6 = $15.12 13294AA012 Gaskets (both sides are the same) $10.04 each x2 = $20.08 $35.20 + shipping...
Front End Noise
Fairtax4me replied to DaveSluder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt'll probably lock up, and you'll be stuck wherever it happens. Whether its on your street or going down the interstate it'll stop dead in it's tracks and it just plain won't move no matter how hard you try to make it. Either that or it will lock then explode and take out the rest of the transmission with the chunks that go flying. You won't get much warning when it quits. If you're going 25 or something you might get a few seconds of a jerky feeling or thunking that might feel like a misfire, then it'll jam and that'll be all she wrote. There used to be a video of a guy racing on Youtube and the diff locked up on him. I can't find it anymore, but it was pretty fun to watch.
Timing Bearing Components
Looks fine to me... must be those new super low friction air bearings. :-p
Front End Noise
Fairtax4me replied to DaveSluder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGuessing on your ... short... description you mean the front differential. Which fluid did you check?
13mm square rear differential options
Fairtax4me replied to BikeRack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1/2" ratchet.
Anti nock sensor question?
Fairtax4me replied to redob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt shouldn't matter for a knock sensor. You could use one from a Ford or a Volkswagon it still works the same way.
2000 Legacy stalls when clutch is depressed
Fairtax4me replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah just a vacuum gauge connected to manifold vacuum. Could also be checked by reading MAP values when the car is running if you have a baseline to compare to. The only difference in the diagnostic systems between a 2000 and 2001 might be the protocol, but good software should be able to work with either one regardless.
Transmission whine due to donut??
Fairtax4me replied to johnD5400's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShouldn't have made a big difference. The Center diff is hard to screw up. Though I suppose with extended use a spare could cause excess wear on the bevel gears. Thing is whatever noise those might make would disappear once the full size tire was replaced, assuming that it is of equal size and tread wear as the other 3 tires on the vehicle. Which now begs the question, did you replace it with a brand new tire? Or did you repair the old tire?
OSD language change - How to?
Fairtax4me replied to jacb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm... interesting. The only McIntosh I know of in the audio world is these guys. They make some seriously high end equipment. http://www.mcintoshlabs.com/
So has anybody ever made a non EGR motor have an EGR?
Fairtax4me replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLoL! I had to start laughing when someone mentioned wiring up the ECU to be powered all the time. My first thought when I read the very first post of this thread was, Why not just run a constant 12v power wire for the ECU so it doesn't turn off when the key is switched off? Seems like it should work. But I guess you have to do it to find out.
Fairtax4me replied to jacb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmm... a Japanese model you probably can't press "Reset" and make it go back to the default settings. I dunno, go find a Japanese restaurant and ask if they can figure it out? Might be worth a shot!
Tire rubbing on strut
Fairtax4me replied to Justbri's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI honestly have no clue. There's no adjustment for camber on the rear without using cam bolts. If your car has those then that could be why, but there really isn't any reason a car should need those unless it's been modified (lowered/lifted) or wrecked.
why dont we have cop cars like this
Fairtax4me replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOur County cops have everything imaginable. Including about a dozen brand new Honda Accords that they use for both marked and unmarked patrol vehicles. Among the others they have Impalas, Intrepids (both getting old now) Crown Vics, quite a few Expeditions, a Mustang (and it is marked), AND a riced out Civic for spying on street racers. Most people don't know about that one, and probably never will.
Radio Feedback with lights/brakes
Fairtax4me replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are something like 2 dozen chassis grounds in various places on the car. You're going to want to look at interior grounds. I'd check the two on either side of the transmission tunnel directly under the dashboard. There should also be one or two under the drivers side of the dash. Remove the lower kick panel and look up under the dash. All the wires going to it should be black or brown.
Fairtax4me replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne post is quite enough thank you. I will give you Kudos for providing past maintenance history. Most people don't do that, even experienced forum users sometimes don't, and it does help in many situations. I'm not sure how much help I can provide, but a simple vacuum check could provide some answers. Another thing that could help would be freeze frame data of what is going on when those codes are being set. A good diagnostic scanner would be able to show that info.
What seats fit?
Fairtax4me replied to Kerplunk105's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure about the Outback but I drove a 2010 Forester the other day and the seats in that I swear were the same as the ones in my 96 Legacy, just covered in leather instead of upholstery. They weren't very comfortable either.
car died on hiway won't restart
Fairtax4me replied to Tahoe Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy did they cast dimples in the pistons if they don't even line up with the valves? Nice to hear you got it running. Sorry to hear you had to go through so much to get it there. All part of the fun of owning a Subaru I suppose.
Legacy w/ ABS brake fluid bleed
Fairtax4me replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith diagonal split brake systems it doesn't really matter which way you bleed it just as long as you see clear fluid with no bubbles and don't let the fluid in the reservoir run out. Now triangulated brake systems like the ones Volvo uses are a bit different. There is a procedure because the front calipers are dual piston and have a separate line for each which is tied in with the rear calipers. To add to the complexity there is a lockout valve which cuts the flow to one half of the circuit in the event that brake pressure is lost, so if you stomp on the pedal too hard during bleeding it closes the valve, which is a royal PITA to reset.
Hood Release Cable Replacement
Fairtax4me replied to 99OB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPossible, but probably a pain in the rump roast. Most hood latches these days are designed to not be opened from the outside without going to a LOT of trouble. Keeps people from reaching in through the grille and popping the hood to steal your battery, or carburetor, something important like that. Only these days people would steal something like the ABS module or any other control module they can get their hands on.
Good news---Bad news
Fairtax4me replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou win some you lose some. Glad to hear you're OK. I wouldn't expect frame damage from looking at the outside, but you can't always tell. At worst the bumper support might be tweaked. New bumper reinforcement, cover, hatch and a tail light should be about all it needs. Can you get the hatch open to see if it damaged the jamb or latch?
Major oil leak 96 Legacy Brighton
Fairtax4me replied to Lanky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably the separator plate. They sell the new ones as a kit because they use different bolts with the new designed part. Ultra grey RTV should work. I used Permatex anaerobic sealer when I did mine.
1996 Outback issues
Fairtax4me replied to JeffStu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom what I understand everything EJ22 before 96 used the dual port heads. Some 96 had single port. After that Single cam motors were single port until 99 when the phase 2 EJ22 was introduced. After that I'm pretty sure they were dual port again. You'll have to swap the front pipes to single port pipes to match the heads for a proper seal. Shouldn't be too hard to find in a U pull it. If not it'll be about a $250 dealer part probably.
Evap purge control solenoid problem.
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI really wouldn't know if the GL has those connectors or not. Ask in the Old gen forum. Those guys know everything there is to know about the older model soobs.
1996 Outback issues
Fairtax4me replied to JeffStu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe difference between a 2 bolt and 3 bolt exhaust manifold is single port (2 bolts) vs dual port (3 bolts) I wasn't aware that a dual port manifold would bolt up to a single port head. This could mean that the heads were swapped, or that the entire engine was swapped for one out of a newer model.
Is Valvoline Lying?
Fairtax4me replied to rugbyben's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was just thinking the same thing.
