136
AaaaaI see now. You want the lobes cut a little different. (brain fart) Durr... Not sure what to tell you there. Depends on what you're looking for performance wise. I'd imagine NASIOC has a few more people who've done these sort of engine mods. I'd be interested to know what you decide to go with and what effects it has on performance once installed.
The flywheel bolts are heat treated high strength steel. Most of your average hardware store bolts won't stand up to the 65ft lbs torque spec the flywheel bolts need to be. The PP bolts aren't anything special. They only get torqued to something like 12 to 15ft lbs. I wanna say they're M8 X1.25? Grade 5 should do fine there.
Might be a CTS issue. If you have a spare try swapping it out. Try searching the boards here and you should be able to find how to test it. I'd also try some strong fuel system cleaner. (it never really hurts) Beyond that... Check the resistance of each of the spark plug wires when they're cold with an ohmmeter. They should all be fairly close in measurement, if not then get a new set.
And probably futile. From what I have read, these things start reading incorrectly within a year from being brand new. Replacement parts are expensive, and the problem is almost guaranteed to return. I go 240 - 250 miles in town before filling up, (I average 20mpg city) and even then I still have about 4 gallons left in the tank. You just get used to looking at the trip ODO after a little while.
Of course the car can't just let me slide with a new clutch and main needle bearing in the transmission, it has to make me do something else to please it! I've had a very very slow leak around the water pump since I got this thing (96 2.2 in case anyone wonders), which I can smell from time to time, but I've never had the coolant BURNING smell that I had this morning. (burning as in, dripped on the exhaust pipes and burned off as they got hot, not a pleasant smell.) So, Does anybody use something besides just the little paper gasket when replacing a water pump? I'm thinking some Indian Head shellac will keep it from doing this ever again.
3 bolts and the whole assembly pops out. The hardest one to get to is behind the grille. Putting that one back is optional. But the grille is really easy to remove. Get out your flavorite flat head screw driver, pull the grille outward with your hand, (start on one side and work your way across). If you look close at the little tabs on top they have two bits on either side that stick out, just pop those in with the screw driver and the tab will slide back. The lower tabs half the time are broken or will break when you remove the grille, but just a quick pull upwards will get them loose. I take them off and put them on the grille before reassembly. Little tab on the bottom that you just slide forward or up (which ever way you look at it) with your finger and it will slide right out.
I had some fun with a P0100 code back when I bought my car. Mine would randomly stall for n reason though, with no other symptoms. Engine ran perfectly, no loss of power, just would stall randomly. Even during cruising at steady speed with the car in gear. Check the wiring in the harness to the MAF sensor for cuts/crimps in the insulation things of that nature. Check inside the plug for corrosion/water/dirt or other evidence that may cause a poor connection.
Not necessarily. OBD2 is standardized to all vehicles currently sold in the US. But the communication protocol used by each one was not standardized until just a few years ago. There are several and car makers can pick and choose which they want to use. Some older scanners will not communicate with newer vehicles due to the new protocols used today. You can pick and choose what you want to believe on wikipedia... http://en.wikipedia.org/wiki/On-board_diagnostics
RWD sedan?
Fairtax4me replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Not if you lay on the gas and turn into it. No but really, I've done a fair amount of "playing around" with mine on gravel, and did some fun driving in the snow a few weeks back. AWD will start to push going into a turn IF you take your foot of the gas. Keep on the throttle, and it pulls the front end into the turn, swings the back end out a bit, but it follows right through. And when you get it really sideways its close to driving Rwd... just faster. -
I don't see anything missing. There is no "bucket" on these lights. Adjustment is done by moving the reflector inside the housing, not by moving the whole lens. What gets me is the position of the hole for that inner bolt on the top support. It looks like it's too far back for some reason. I'll check mine in the morning and see what it looks like.
Sounds like the test mode plug is connected. Look under the dash for two wires with a green connector. Unplug them if they are connected. Guessing this car has an auto trans? (reference to park/neutral) Search the site for P1101. Sort by relevancy in the advanced search. Lots of info about that here. Same with the P0130, and the P0500. All of those are circuit codes (wiring) so check the harnesses for those items for breaks. Helps to have a multimeter to check for open circuits.
Outback is a Legacy with a raised suspension. The bumpers were different, and the grille was taller. There is a recess in the bumper right under the grille on the OB that isn't there on the standard legacy. But the lights should be the same I would think. Same part number. 95-97 Legacy and Outback. http://www.subarupartsforyou.com/cp_partdetail.php?partid=1281 http://www.subarupartsforyou.com/cp_partdetail.php?partid=1191
Got a multimeter handy? You'll want to probe each of the lines on the window near the ground side of the grid to check each one for voltage. The FSM suggests using a piece of aluminum foil wrapped around the lead that you can use to slide along the grid lines while monitoring the reading on the meter.
