136
If it's getting a signal to fire then I would think it should fire. Did you check to see that the coil is getting power from the battery? You have a copy of the FSM don't you? The lines on the belt are hardly the best way to set the cam timing. But if it ran before just fine, then the timing is probably good unless the belt just straight up broke.
Been getting colder here at night the past few weeks. The past few mornings I've walked out the door to see frost on the car. Which never bothered me... til I got this Subaru. I turn on the defroster as soon as I start the car, and by the time I get to work (roughly 15 minutes drive) about 1/8" of the frost on either side of each line has melted away. All of the lines work, they all melt the frost, just not very well. Is it just mine or are they all like that? I often have to parallel park at work and its no fun when you can't see out the back window.
CAN means Controller Area Network. It's a new twist on the On Board Diagnostics system that basically allows more information to be read. Cars are getting more and more new sensors every year, and the ODB system has to be able to communicate with those sensors in order for it to maintain proper operation, and more accurately detect faults when they occur. edit: He beat me to it.
How many miles on the car? It could be that the "new" ECU is dead. Hard to say though. Will it still start with the old one? All of those are circuit codes except for the misfire code. You could have a loose or broken ground wire somewhere causing the trouble. That would be the easy fix. My first thought was skipped timing belt. Has the timing belt ever been replaced? I'm also always suspicious of vacuum leaks whenever multiple codes show up, or general poor driveability is encountered. There are certain conditions that when present the ECU will cut power to the number one injector, kind of a Failsafe mode, to alert you that there is something seriously wrong and it needs to be checked out ASAP. Try searching those code numbers here on the board and you might come up with some other ideas to check.
Oooh, where's that Endwrench article about the P1507 code... ? The P1507, I think it was only for manual transmissions that the article applied, but it seemed that that code was usually present with a ton of others if the neutral position switch was bad. P1700 is Throttle position sensor circuit malfunction. That's a manufacturer specific code, and though several manufacturers use that code, each one has a different definition for it. P1507 Idle control system fault. This, again, is a manufacturer specific code. P0122 is TPS sensor circuit low input. I'd be willing to bet all this can be cured by replacing the neutral switch, but I'll let another more informed member post their opinion.
I think that's worse than usual. Most that I've read about the gauge reads empty with around 4 gallons left. Some people have reported improvements by running a bottle or two of Techron fuel system cleaner through the tank. You could try it, but it it doesn't work you'll have to either put up with it or replace the sender units in the tank. (there will be two of them if your car is awd, one for each side of the hump)
I think he's more concerned about the torque converter pulling out of the transmission when he tries to separate the engine and trans. Just bend a piece of metal and bolt it to the bell housing to push on the converter. It doesn't need to be anything special, just as long as it will hold it there and not get in the way.
Could be Autotraders fault. We've had trouble with them posting the wrong pictures in a listing several times. We usually end up with pictures of a Honda or a Toyota or something in the listing for a Mercedes or BMW. It could also be a rebuilt car. Flood damage, salvage title, etc. Go find that exact car and check the Vin against what is listed on the website. I promise it's not the same. Get the VIn for the car pictured and run a Carfax on it.
