Everything posted by Dazed Dreamer
what's this...??
Because it is extra weight you dont need DUH I am always worried about getting mud and water in my little fly wheel thingy that spins and such like that "you know if you think about it mud is just dirt and water mixxed" - Bart Simpson
what's this...??
start your engine and watch it spin
Rock + Steering = Oops...
What kinda car is that? and you could have a leak in your power stearing lines which caused an air pocket ( I dont know just a guess)
3 pictures of my 93 Impreza
Not sure if you guys are interested I thought I got some better shots of it but I guess they didnt turn out right http://www.cardomain.com/memberpage/570492/4
1993 Subaru Impreza Timing Belts
Hello soon here my 1993 impreza is gonna get a new timing belt, i think it still has the one it came with but I was just curious if there are any "performance" belts and if so where can I get them. In the brochure I got it has an STi timing belt but thats only for the newer WRX models and I was also wondering if it was worth spending the extra money on one or should I just get the basic OEM
RWD Conversion?
Dazed Dreamer replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLink doesnt seem to work
Matching Cars! NEW SVX. Wooohooooo!!!
Dazed Dreamer replied to ccrinc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is CCR?
Will EJ20 work with Impreza wagon?
not to be picky but the 22B has a EJ20 bored out to 2.2L
Dazed Dreamer replied to ccrinc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa rebuild isnt that much more trouble serious? cause my EJ18 impreza needs some new seals and timing belt replacing "Roos Only" will do it both for about 500-600$ but thats alot of money if I can save by doing myself please tell me what is needed and how much I will save time money and skin
repair progress pics on my impreza
I love the URABUS I always wanted to take my SUBARU off and put FUJI on the back then FHI emblem up front
Rally Xers Beware (praying for rain)
anyone know where I can rally cross in Colorado and what is required to participate?
Subaru handbrakes...
I think the loyales are the only ones have have front hand breaks and power sliding isnt using the hand break
Oil Pan Replacement
Yah I got the oil pan off the imreza at the junk yard with a little bit of a struggle bent the dip stick tube but when I brought it home I couldnt get it off my car cause I couldnt raise the engine at all with my lil jack and couldnt find a good spot to place the jack so I had to take it to ROOS ONLY here in denver they did it for $130 which im glad I didnt try to do it cause I gues auto zone sold me the wrong gasket but shes all better now cept a few cosmetic things need to be put back in place
Oil Pan Replacement
thanks that actually helps me out alot since I dont have a dremel tool guess Ill have to raise the engine with a jack which seems like it should work so all I have to remove is the bolts at the bottom? and put a jack underneath and it will raise without bringing the car up with it?
Oil Pan Replacement
well my oil pan is smashed and I was wondering if anyone knew an easy way to replace it on my 93 subaru impreza L its seems like an easy thing to do but I cant get to the 4 screws in in the back of the pan with out removing the engine anyone here know an easy way to get to them or any tricks PLEASE HELP im with out a car till it gets fixxed
What is an "Interference" engine?
Dazed Dreamer replied to ajosefick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdont quote me on this and please correct me right away If I am wrong but I believe an "interference" engine will seize and lock if the timing belt breaks as apposed to a "non-intereference" which wont, other than that I dont know
ej 1.8 "overhaul"
Hey my ej18 from my 93 impreza has got 240+ miles on in 20k of those miles are from me being kinda hard on it (with proper oil changings) now my oil leaks I was wondering how much $$ and time would it take to replace all the oil main seals or would it be better just to buy a 2.0 or 2.2 engine? any opinions or suggestions very welcome
(mileage check) Who's got the mileage record?
I have a little over 240k on my 93 impreza
90 legacy 2.2 uneven acceleration
Dazed Dreamer replied to Brayburks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXflushing the radiator could help just a thought
Tire Selection
the thing is if I get those blizzaks then ill have to swap rims ever day just about cause one day the roads will be snowy and the next dry as a bone and hot if I lived in the mountains it would be fine and about the studded they are alowed here but I heard they dont help much kind of a waste of money
Tire Selection
What is the best tire to get for a 1993 Subaru Impreza L AWD for colorado during winter?
1993 Impreza fog lamps
and what do I do with this number?
is there a place I can get those that it will be a nice fit into the place it seems they should be?
Impreza 1.8L conversion
Dazed Dreamer replied to Dangerdave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would think it woudl be pretty easy if you used the 2.2 ecu intake and exhaust thats what im plannin on doin with my preza which is a 93 is the AWD system controled by the ECU though?
Drums replaced with Disc
How much trouble would it be on my 93 impreza L (sedan) to change the rear drums to discs?
