Everything posted by 987687
jdm legacy cluster fit a postal?
I don't know how first gen stuff swaps, because I don't own one. But you don't want a JDM one.. It'll be in kilometers.
Do Subaru oil filters not have anti-drainback valves?
987687 replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use napa filters. On my GL that has the filter sideways, the oil pressure gauge jumps right into life as the engine is cranking over. So it must have a drain back valve, otherwise half the oil would drain out of the filter.
Cam Slipped , What to Do?
987687 replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo rotate the cams I put gloves on and just do it with my hands. Use gloves though... If you overshoot, it snaps and your finger gets caught between the cam and the timing cover it leaves a wicked bruise if you don't have gloves on. Wonder how I found that one out
Dragging caliper
987687 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the pads are wearing on angles, or one is wearing significantly faster than the other. Something is stuck.
EJ25D block swap to EJ257 block
The other thing with that engine is it's supposed to run high octain.
Please Help Timing Belt Srew Up?
987687 replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlign the DASH MARKS on the sprockets with the marks on the timing covers. The one on the crank gear to the mark by the crank sensor. DO NOT USE THE ARROWS. THEY WILL MESS YOU UP. The belt has over 200 teeth, that means over 400 revolutions to get the marks to all line up again. This is an older engine, and your sprockets will look different, but the idea how to line it all up is the same.
Dragging caliper
987687 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's a rear one, they like to get rusty inside and freeze up. I had one on my legacy that was intermittent-ish. Sometimes it was bad, sometimes it wasn't quite so bad. I flushed the rust out, and it was fine after that. If it's a front one, the bottom slide pin in the caliper bracket is probably frozen up. If it's not too bad, you can heat the bracket with an oxy/ace torch and get it freed up.
Question about gearing, 3.70vs.3.90vs.4.11vs.4.44
987687 replied to superu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, you get a full 100% lock. Bratman had a 6speed put in his fozzy, and I wired in an aftermarket DCCD box. Taking tight turns on pavement if you slide the wheel all the way to lock the car jerks and bucks. It's total lock up.
Whats broke on your subaru lately.
There's always something broken on my cars... But as long as nothing that impedes the car's safety or ability to move, it's good to go! hah
Coolant bubbles
987687 replied to ktdenali's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt doesn't take very long. They put the test thing in the rad cap, start the engine, and the fluid in the test thing changes colour within a minute of running. Really easy test to perform.
I should post pics of my dash. My gauges and hvac are blue. No sploches or anything. I'm really happy with how it came out.
How even is the light doing that? I just glued strips along the back of the plastic thingies and the lighting is perfect.
1997 Subaru legacy out back overdrive not working?
987687 replied to subliminal1284's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI didn't realize your tranny lost 5th gear...
987687 replied to subliminal1284's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy would you drive 654 miles in 4th gear?
Nothing broke today!!!
987687 replied to subliminal1284's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's a reason they stopped with the silly 5th gear... It's fine as 5th gear is a 6speed maybe.
987687 replied to superu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnly the 6speed has DCCD, the center diff control. WRX does not have 6speed. I've never heard talk about 3.54 and STi trannies, but I don't have any hard information, so I'm not going to say they do or don't have 1:1 centers after 06.
987687 replied to subliminal1284's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe outback has a 0.871 5th gear ratio, whereas the other subarus have a 0.780 ratio. I guess they gave it a shorter 5th gear because they assume you'll be towing or hauling heavy loads with it, and the bigger tires. Which, I have to say, does help when I'm towing with the outback. It's fun for tooling around back roads too. But it does suck on the highway, reason I don't like that transmission. FYI, 4th gear is 1.088
987687 replied to superu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have this chart. Only goes to 05. But I've never heard the 06 having anything besides a 3.9
Help identify this steering wheel
I have this wheel in my GL. Bratman gave it to me because someone gave it to him... It fit without any mods (besides making a friction ring for the horn) I dunno what suby it's off, but someone should know. If I ended up with one in Maine, I'm sure there are many more kicking around somewhere you could snatch up.
987687 replied to superu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only 6MT that has a 1.1:1 ratio (according to the spreadsheet of gear ratios I have) is: UK/Europe/NZ Impreza WRX STi MY02-04
987687 replied to superu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs I said right above, some of the SVXs had 3.54 ratio. And since it's an auto I seriously doubt the center wasn't 1:1. That would mean they have to have a 3.54 front diff too.
987687 replied to superu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought the SVX had 3.54 all the way around? Or did it have a non-1:1 center ratio?
After fixing my frozen parking brake lever on the caliper, one of my lug nuts wouldn't torque down... Eff. Go to napa, of course they don't have pug nuts. Fortunately it was one with the removable washer thing on the nut. So I just pulled that off and used a normal subaru nut with that as a washer. Seems like it should hold..
In The Middle Of A T Belt Change
987687 replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat doesn't work on an automatic
