18
Everything posted by 987687
				Whats broke on your subaru lately.
987687 replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
After fixing my frozen parking brake lever on the caliper, one of my lug nuts wouldn't torque down... Eff. Go to napa, of course they don't have pug nuts. Fortunately it was one with the removable washer thing on the nut. So I just pulled that off and used a normal subaru nut with that as a washer. Seems like it should hold.. -
	I use the starter method. Put a socket with a long breaker bar, or breaker bar with cheater bar over it. Put it on the crank bolt, and the other end on the ground on the driver's side. Make sure everything is tight and secure. Make sure the engine isn't going to start, disconnect the coil, or engine harness, or whatever. Then turn it over.... Should crack the bolt free! I'm bracing myself for all the people telling me this is a bad idea. It's worked fine for me.
	So many people lately having issues removing the compressor. ?? Anyway, you should also replace the gaskets on the lines that go into the compressor. Since the system is discharged, it would also be a good time to replace the schrader valves, I've had them leak in both my Legacys. If you don't know how to charge an AC system, or have the proper gauges, you should really take it to a shop. It can be dangerous if done wrong. At least read up on how to do it.
	To do a head gasket properly, you're looking at probably $200. Between the head gaskets, four cam seals, crank seal, valve cover gaskets, grommets. While you have the engine out it would be dumb not to replace the separator plate, should probably reseal the oil pump at the very least. Then just other dumb expenses like hose clamps, coolant, oil, random fasteners, etc. And that doesn't even include timing belt stuff.
	I got a really nice looking used one at a JY in PA. I think it was $40. The person I got it for hasn't had any issues with it. It had no corrosion, cracks on the tanks, or anything. Like any JY part (whether you pull it, or a guy takes it off a shelf), it's up to you to inspect and make sure it's a good part.
				EA 82 runs poorly on a hot day- low power/ poor mpg
987687 replied to jmoff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did you use subaru plugs and wires? And also replace the cap and rotor? Check your timing with a timing light. Could very well be causing your problem, it's a really easy thing to check! -
Ok, sometimes the joint can break internally. But did you make sure the hub splines aren't stripped? It can happen pretty easy if the axle nut isn't torqued down well. -
Are you sure it's the transmission? It could be a broken axle or stripped out splines in a hub. -
I need a new right rear strut. When the subframe cracked I didn't realize it bent the strut a bit. It leaked all its oil out, and now it's completely bouncy. A little scare to drive over really bumpy roads fast... -
	You can use the auto ECU, although, the tuning is a little different. It doesn't like to idle down always, this can make it a real annoyance driving in traffic. Or trying to get revs to match right when shifting. It keeps the IACV open more often (I think...) than the manual ECU. I just know the tuning is different. I put an auto ECU in my manual car once just to test it out. But yes, the auto ECU will work fine. I've swapped them either way. I believe you have to connect the two big wires coming out of the shifter assy, can't remember exactly though. It's for the NSS so it will start. Just put a meter on them and see if the connection closes in N and P, and no other gear. Then you have the right wires. And just hook up the two wires for reverse from the transmission, not really a big deal. If you want to get fancy, hook up a clutch switch.
	You aren't really supposed to play with the trottle body linkage stop screw. Or tighten the cable, the IACV will correct up to about 4% opening anyway and make it idle right... Your idle is probably fine, your gauge just reads low. Lot of them do this. If it's running rough at idle, the normal suspects. Plugs, wires, PCV, filters... blahhh. General tune up stuff.
