sea#3
Everything posted by sea#3
Ok this is only a theory Since you have replaced the ECM and have the same out come, I would think you might have a back feed through the harness somewhere. The most likely place is the B19/E1 connector (see schematic). May be some corrosion or water in the connector. If not that, I would disconnect the C7 wire and the C20wire at the ECM then see what the scan tool says. If it says 3.8v it’s inside the ECM. If its 0 then get a voltmeter and measure the wires on the harness. Since the B19/E1 connector share the front and rear 02 sensors there may be a back feed through there Hope this Helps SEA#3
Sunroof leak
sea#3 replied to telemachus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There are 4 drain hoses , 2 at each front a-pillars and 2 at each rear d-pillars. The best way to find it is drop the head liner and water test it . Not an easy job , you have to remove all the trim that contacts the head liner then drop it out the rear gate. One thing that makes it a little easier is that it a wagon Some time the sealant at the right rear drain cracks and leaks , but most of the time there is debris in the hose SEA#3 -
need some help
sea#3 replied to 916RS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
This where it's at (see attached ) but doubt it's going to make noise Does you speedo work? Hope this helps SEA#3 -
One last thing that may or may not be related - when you first start this car up in the morning, everything is fine until you put it in gear and let the clutch out the first time - you have better be ready to push the clutch back in quickly, because the engine is going to self rev to about 3500 RPM. It does this for about 10 seconds, then settles down and is fine for the rest of the day. But every morning, first time you put it in gear and let the clutch out, it revs to 3500 RPM all on its own. If you don't get the clutch back in you'll take off like a bat out of .......... Any ideas on that? Tom There is a ECM update for your last concern . It may fix the first concern SEA#3 Thanks to all. Nice car but these two things are very annoying.
The whistle come in at 3000 to say 4500 under moderate to heavy load right? It comes from the Muffler(rear) , now your saying it can't be it sounds further up.Try driving the car with the rear hatch open and you might have a different opinion . I usually get 2-3 complaint a year , mostly on Impreza's but some Legacy's hope this helps SEA#3
