Everything posted by sea#3
Update, HELP NEEDED, O2 Sensor 3.8 volts???
sea#3 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk this is only a theory Since you have replaced the ECM and have the same out come, I would think you might have a back feed through the harness somewhere. The most likely place is the B19/E1 connector (see schematic). May be some corrosion or water in the connector. If not that, I would disconnect the C7 wire and the C20wire at the ECM then see what the scan tool says. If it says 3.8v it’s inside the ECM. If its 0 then get a voltmeter and measure the wires on the harness. Since the B19/E1 connector share the front and rear 02 sensors there may be a back feed through there Hope this Helps SEA#3
99 outback TPS problem
sea#3 replied to tforce's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAssuming it's a new TPS and not defective, I would look at the wiring to the TPS and the connector between the TPS and the ECM. The one connector that often gives trouble is the one at the engine harness and the main harness from the firewall. It should be a gray connector SEA#3
Sunroof leak
sea#3 replied to telemachus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are 4 drain hoses , 2 at each front a-pillars and 2 at each rear d-pillars. The best way to find it is drop the head liner and water test it . Not an easy job , you have to remove all the trim that contacts the head liner then drop it out the rear gate. One thing that makes it a little easier is that it a wagon Some time the sealant at the right rear drain cracks and leaks , but most of the time there is debris in the hose SEA#3
valve seals in gasket kit/2 colors??
sea#3 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXedit
- 2000 Outback Sport ECU
sea#3 replied to Richard1296's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPassenger side foot well . Pull back the carpet and it under the metal sheild (2 bolts 1 nut 10mm ) Sea#3- would a connected speedo cable cause CEL to come on..
sea#3 replied to subie94's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup the speed sensor #2 is in the speedo , it has probably coded up code 33 speed sensor #2 malfunction Hook up the cable , clear the code and you should be good to go SEA#3- oil leak help?
sea#3 replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDiagram #5 Sea#3- Update, HELP NEEDED, O2 Sensor 3.8 volts???
sea#3 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe CEL is for the front bank no response. What is the code ? There may be a recall on the ECM Sea#3- Torque bind and Tran luid light.
sea#3 replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo to code 24 Hope this helps SEA#3- Torque bind and Tran luid light.
sea#3 replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSEA#3- need some help
sea#3 replied to 916RS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis where it's at (see attached ) but doubt it's going to make noise Does you speedo work? Hope this helps SEA#3- 99 Outback Auto Tranny Problems
sea#3 replied to tforce's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis should help you find the resistor (#2 on page 4 and 5) SEA#3- Air bag light on
sea#3 replied to outbackusjunkus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry this to pull codes Hope this helps SEA#3- 99 Outback Auto Tranny Problems
sea#3 replied to tforce's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry this to pull codes , Tell us what you get , it is most likely the Drop resistor, don't worry about the buzzing hope this helps SEA#3- Where is the "Main Relay"?
sea#3 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis may help you SEA#3- Subaru 2000 Outback---error code P1133
sea#3 replied to bentonjim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck with the dealer there may be an oustanding recall on the front (A/F) sensor Get your VIN # and phone it in and see SEA#3- Subaru herk and jerk...
sea#3 replied to Tom Kirkman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne last thing that may or may not be related - when you first start this car up in the morning, everything is fine until you put it in gear and let the clutch out the first time - you have better be ready to push the clutch back in quickly, because the engine is going to self rev to about 3500 RPM. It does this for about 10 seconds, then settles down and is fine for the rest of the day. But every morning, first time you put it in gear and let the clutch out, it revs to 3500 RPM all on its own. If you don't get the clutch back in you'll take off like a bat out of .......... Any ideas on that? Tom There is a ECM update for your last concern . It may fix the first concern SEA#3 Thanks to all. Nice car but these two things are very annoying.- Code 0325 Knock Sensor
sea#3 replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTime for a Knock sensor.... They go open circuit with temperature change You can find it just below the throttle body on the cable side ,Take out old one ,clean off block install new knock sensor and torque to 17 lbs/ft Hope this helps SEA#3- Timing belt issue question
sea#3 replied to sajara's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you check the idlers before you installed the belt? #2 idler are known to wear , if the bearing on that idler is worn it will tip up and push the belt out SEA#3- Cruise Control Relay?
sea#3 replied to motojeff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis might help , you did not say if it was an auto or standard SEA#3- Can't remove key from ignition!!!
sea#3 replied to justwalkaway's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry this attachment SEA#3 D""m to big to send- rings/whistle during acceleration
sea#3 replied to vanbasten's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe whistle come in at 3000 to say 4500 under moderate to heavy load right? It comes from the Muffler(rear) , now your saying it can't be it sounds further up.Try driving the car with the rear hatch open and you might have a different opinion . I usually get 2-3 complaint a year , mostly on Impreza's but some Legacy's hope this helps SEA#3- Check Engine Light
What model and year??? It might fall under a recall SEA#3- Duty Solenoid - Help Needed
sea#3 replied to uletek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot a feeling you might have crush the soleinoid !!! Drop the pan and have a look, check the solenoid where the connector goes , if it is loose on the solenoid it is most likley done . You can also check for continuity it should be less than 1 ohm SEA#3 - 2000 Outback Sport ECU
