Everything posted by sea#3
Help- Grinding noise after rotar job
sea#3 replied to CMohan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the gap between the rotor and the backing plate it's probably close or touching SEA#3
Please help! dead car!
sea#3 replied to itruns's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you pull your starter out and look at the space between the bell housing and the torque converter it should be about 3/16" space between the two if it's any larger than that the converter is not installed corectly . If it is ok then you should check the locating dowels on the trany and the engine you may have too many in place ??? ( extra from either the original engine or the replacment) it may twist and the bind the engine/ torque converter when tighten The small wire you are looking for on the starter will be hanging off the firewall about mid way down just right of the brake booster SEA#3
Power Failure Question?
sea#3 replied to QuackAttack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet your alternator checked out , also it may qualify for a recall on the alternator SEA#3
Engine Code on 99 Forester - Help
sea#3 replied to 30thAnnivSS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPO325 = Knock sensor code - probably needs a new sensor PO335= Crankshaft position sensor - probably needs a new sensor SEA#3
Rough idle - sometimes it stalls...
sea#3 replied to Stormy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry replacing the front A/F sensor (02 Sensor) first. It is situated just below and back of the right front inner c/v joint They are notorious for lying to the ECM and not throwing a code , as well as causing other codes to be triggered Whether this is your problem it's tough to tell You can tell if the front A/F sensor is "Lying" if you have a scan tool and you monitor the front a/f sensor and the rear 02 sensor, which your dealer should be able to do !!! SEA#3
Tried everything and the speedometer wont work, HELP
sea#3 replied to thecougfan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have repalced the speed sensor and the cluster , most likely it's in the wiring harness What is probably happening is the harness is shorting to ground and cutting out the speed signal Checking for continuity through the wire may check out ok , but the next thing to do is to check if that wire is grounded SEA#3
98 outback engine disassembly
sea#3 replied to wayneb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThet can be a B**ch You can try using a impact driver and a twist socket -like http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=65939&group_ID=11664&store=canada&dir=catalog They are a special bolt and i'm not sure if you can get them seperatly ,so be careful SEA#3
Custom High Flow INTAKE Problem
sea#3 replied to pingtang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat code is coming up ? SEA#3
Making noises when not running... freaky
sea#3 replied to Seann's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMosy likely it's the ABS relay stuck on , if you remove the phillips screw on the black cover you should see two relays pull a relay till the noise stops, that would be the one SEA#3
Please help with removing fuel pressure regulator!
sea#3 replied to friendly_jacek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBefore you try and drill them out , Try using Visegrips on the out side edge of the screws . You have nothing to loose if you damage them ,If the threads are stuck and you try and drill them out you still have to get he threaded bits out , always a dicey job SEA#3
'93 Legacy whistle
sea#3 replied to Miles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry cleaning you throttle body and throttle valve with some spray carb cleaner . Also spray some through the IAC valve they are known to whistle on early model Legacy SEA#3
Another legacy A/C question
sea#3 replied to rdrx7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXR-12 fitting are screw on fitting and if it been converted to 134a there are quick disconnect style fitting on it (Usually) You may want to look around for any retro fit stickers SEA#3
Run out of ideas
sea#3 replied to beezer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBeezer Try putting an ignition relay in it , the relay has 2 sets of contacts in it that supply voltage to the ECM at two points . Sometimes one set of contacts stays open ,which can cause your codes to trigger .This is why if after you start the car and it runs bad ,then you shut it off and restart it , it reactivates the relay and gets a better contact You can find the relay on the left hand side of the dash just above the inside fuses box(it is a PITA to get to) It is a brown square relay with a brown connector SEA#3
Bands adjustable on '98 4EAT?
sea#3 replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may be on your way to a trany o/haul , The forward clutch pack o-rings are probably worn out or have shrunk SEA#3
'96 Transmission trouble codes?
sea#3 replied to mtsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour TCM (Transmission Control Module ) has a stored code in it . The easiest way is to use a Select Monitor Scan Tool to access the codes SEA#3
Do 92 Legacys have an Inertia Switch?
sea#3 replied to 300td4x4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope ,it doesn't have an enertia switch . Check the fuses and the wiring might have got damage in the acident SEA#3
OBD 2 DTC's
sea#3 replied to AlexK's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSEA#3
Head gasket replacement/cam removal
sea#3 replied to Max Power's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes you have to remove the cams to access the head bolts . it would be wise to resurface the heads and check the valve clearence SEA#3
PLEASE HELP!!! Cylinder Misfire code on 2001 outback.
sea#3 replied to xing_fu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet them to check the valve lash clearence , it is probably closing up and holding the valve open when it is cold . It is a scheduled check at about your mileage SEA#3
Part identification help..something to do with throttle
sea#3 replied to Happyhighguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's a automatic? It's NORMAL , what you are hearing is the selionoid in the trany for the oil pump . SEA#3
check engine light advice needed
sea#3 replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are two , there is one just where the two pipes come together , just below the right side axle shaft and the second one is just behind the rear trany mount SEA#3
Car wont start
sea#3 replied to Happyhighguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry this site to read codes and then tell us what code you have http://www.troublecodes.net/Subaru/ SEA#3
sea#3 replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot the same year but the same trany. Try this http://www.main.experiencetherave.com:8080/subaru_manual_scans/Subaru_Service_Bulletins/1991/4EAT_FWD_and_4WD_Brake_Band_Adjustment_On_Car_Servicing.pdf SEA#3
96 legacy outback hard starting
sea#3 replied to dale47's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope you just need to plug in a scan tool and read the codes SEA#3
AT pan bolts -- size?please
sea#3 replied to yarikoptic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe bolt size is 6mm(dia) x 1.0 mm(pitch)x 10mm (long) As far as where to buy them i would suggest the dealer, since they coudd get the right ones for that application SEA#3
