sea#3
Everything posted by sea#3
Electrically the IAC (P1507) and the injectors have a common connector , I would check the connector that goes from the firewall to the engine , there are three connectors on the right side of the motor . Pop them aprt and see if there is any corrosion . Should be a 16 pin connector , concentrate on the two centre rows Hope this helps SEA#3
The next thing is check the fuses , relays( in the fuse box under the hood) and connection at the ABS / hydraulic unit . if thats ok it maybe the light bulb is simply burnt out . The reason it's not working may be the work that was done on the rear wheel bearings , one of the sensors or its wiring maybe damage which will set a code and the ABS will stop working until the code is cleared SEA#3
The front A/F sensor (o2 sensor ) can go bad and "lie" to the ECM and set that code as well . usually more on the 2.5s but basically the same sensor You could disconnect it and see if it changes anything , it will set a code Easier to tell if you have a scan tool and you can check the data between the front and rear sensor to see if it is reacting properly Hope this helps SEA#3
Get your serial # off your car and phone your local dealer and see if the Air flow meter recall has been done on your car . There is a recall on the air flow meter and it will prioduce that code . It maybe going so lean that it is pinging and the knock control can not compensate for it There ia a blue painted dot ussally on the top edge of the air flow meter by the screw if it has been done Hope that helps SEA#3
I think you may want to review that. The inhibitor switch is directly involved with the starter circuit. They are known for bad contacts and intermittent starting, especially when the car are left to sit after driving (heat soak) The shift lock system does use the inhibitor switch as a reference to see if it is in park, so that you have to apply the brake before you can move the shift lever out of park SEA#3
Have a look at the surface of the rotors , look for a patern that looks like a record groove along the surface of the rotor. If that's the case you will have to turn them again . then the rotor should be sanded so that they have a cross hatch patern in them ,This will seat the pads faster and reduce the likley hood of the noise coming back . You should also wash the rotors after doing this to get any filings off the rotor surface SEA#3
I'm with Cookie It's the start of a head gasket problem . You can do coolant pressure tests , you can try checking for bubbles in the over flow when running ,you can check for CO ( carbon monoxide ) coming from out of the rad using a dye or a gas bench But the best way i have usually diagnosed this problem is by doing a leak down test on each cylinder with the rad cap of and the rad topped up to the brim of the neck and watch for any change in the level SEA#3
Your car has thrown a code and that is why the Check Engine light is on aswell as the cruise light- which will flash The reason the Cruise Control doesn't work is because of the code . You car is a "drive by wire " on the throttle . when there is a code in the memory, it goes into a fail safe mode -will not operate Go to the dealer and get them to scan for the code Hope this helps SEA#3
It's the keyless entry that is causing the lights to flash . if you have the remotes you just have to hit the disarm button . If not,you have to find the passive button which is usually found by the hood relaese (black button ) . If you don't find it there look for the control module ,which is by the fuse box. Should be strapped up there . Hold the black button down and turn the ignition to the on position . The lights should stop flashing Hope that helps SEA#3
