Everything posted by LosDiosDeVerde86
g/f crashed the impreza today
yeah, that'll also help with the torque-peak for optimum fluel mileage
Thoughts On Used Japanese Engines
hmm, very interesting nip
Huntingdon/Raystown
So, i'm going over to Huntingdon to take advantage of lake raystown. aug. 11, 12, 13 anyone in the area?
what?
I need more lift
Tko nekak je zgledu subi pred in nato po višanju, komplet za višanje pride okrog 5.000 do 6.000 sit. V kratkem bodo izdelane še podložke za pod kolotek oz. vmesnik med navojnimi vložk, kolotekom in vijaki s podloškami 8) ?
I need more lift
i'm just stating possibilities
4wd awd problem
bs, you said that the dutyc puts out next to nothing!
4wd awd problem
to those of you who read my "fwd fuse amp" thread i found that it appears that the switch is burned out. i reconnected the wires and the awd works properly, so that only leaves the switch to be at fault. oh, andy? i rechecked all the wires, they ARE soldered to hell and back.
I need more lift
extend the upper bolts and add a spacer?
Outback with Swampers Video
that one turn coming out of the first puddle, i guarantee that the tires helped. if you're not bottoming out, you're not puching hard enough!!!! :banana:
MAF Sensor Failure?
LosDiosDeVerde86 replied to JohnD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi just replaced mine. 96 legacy. it was doing the same thing. eventually (i was lucky this happened in the garage) your engine won't turn on at all.
thats what i figured. i always wanted to stop there and jump on them.
what are those two wire things i see sometimes stretched across the road that are connected to a box? car counters?
I need more lift
\ correct....to an extent.. a body lift will not bring up the engine and diffs any farther from the ground than stock because it actually LOWERS those elements from the car in order to raise the body upwards. however, because of the body being higher up, you'll be able to use much bigger tires which in turn WILL lift the drivetrain/power elements. my suspension lift gave me approx. 2 inches, and my tires add about another 1.5
if you mean overconfidence in that some guys think that innercity roads are a good place to pretend they're Vin Diesel? yes, i agree. if you mean overconfidence in that "don't worry, i'll make, i've got pleanty of room", then i dissagree. that causes dinged doors and scratches, but not injuries. panic is the WORST thing you can do while driving. no matter what the situation. examples in my life: if there's an animal in front of me and thick traffic, sorry animal, i'm not slowing down or swerving. tha-thump. if i start to lose traction, slow down the car by letting off the gas, steer the correct way to correct the car's path. both of those things have happened to me quite a few times. i've had my car for over 5 years now (as long as i've been driving) and i've never been in a fender bender, smack, bang, boom, wreck, paint chip, and bumper brush because i KEEP MY COOL WHEN I DRIVE
I need more lift
that's ALOT of stress you'd be putting on you CV joints with forester struts AND kingsprings. likely that you'll be going through cv's like oilchanges. and don't listen to andy about the king springs. he's got money to burn.
FWD fuse amp
no. i ended up using a .22 round.
Super Street August COVER CAR
forgive me
i'm sorry, a lot of people think i'm sexist, which i fight them on, but i may very well be. but not in the "make me a chicken pot pie" way, just in the "my god i dont understand what you're thinking" way. i know we just went through this big thing with shawn's email, and i hope this comment doesn't "offend" anyone: would a man in that situation start to freak out, throw their hands in the air (wave them like they just dont care), and call the passenger's name to take over and "make it all better"? no. that's why my wife doesn't drive when i'm with her unless it's a long trip and i need a break. she can't handle weather or precarious situations without hyperventalating.
so can i personally blame you for all of my traveling woes?
2002 Outback Sport Center Diff Lock
i'm really not sure about the 02s. sorry.
i don't think that it's a difference in transmission that matters, because i think they're pretty much the same. however i think it's differences in the way the the awd is activated
i knew you'd chime in. i think that the differences in the AWD system wouldn't allow the Andyjo modification to work. could be right, could be wrong....what do i know.
EJ18S Performance
LosDiosDeVerde86 replied to drink's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis has come up ALOT today for some reason
need more power
you could change all sorts of stuff. that doesn't mean it'll help though. i changed my maf sensor a few weeks ago and my mileage greatly improved. it may not for you. you really gotta know your car and know its history before you just go out and start replacing sensors. will it hurt? no. will it help? who knows. and thanks Nip and Brian, that clears it up for me.
