MachineAgeVictim
Everything posted by MachineAgeVictim
  1. they make ATV tires that fit our rims, check in the offroad section
  2. remember paul, one comes with my wagon, so one of the ones you have won't need to go toward it
  3. well the shaft still turns even if it's not engaged (the rear wheels/gears will turn it) if it's off balance then it'll cause a bad vibration through the car, very noticable, if it does then you can unbolt the back of the shaft and tie it up with wire till you can get it fixed. to fix it then you'll only need the joint (looks like a "t" with round bearings on each end) and you'll need a press to get it together/apart
  4. yeah I got the lugs with them, the seat is also seporate from the nut, it rotates (or doesn't rotate as you turn the nut)
  5. I always wondered what was special about the alloy lugs? bigger seats?
  6. if you buy it then I'll keep the Australia badge in the grill
  7. I'm selling my wagon http://www.ultimatesubaru.org/forum/showthread.php?t=71511
  8. ^^^^ sorry hopefully everything is wrapped up now sorry to hear about needing to sell your stable off maybe once I sell the wagon I'll have left over to get one of those bikes
  9. I'm selling my 4x4 in the for sale section
  10. I'm suprised how much torque is transfered to the wheels of my EA71, with oversized tires I can spin them through 1st btw I own the best honda ever built and they shouldn't be written off as behind the curve (Subaru takes a turbo to do what honda does N/A, 120hp/liter)
  11. let us know if that helps, sounds like the same problem mine has that didn't go awya after a pump replacement, I dialed it out a little after I put a new rotor on it
  12. ok so it moves only with alot of cranking, currently using channel pliers around the outside of it can I compress it using a clamp?
  13. I like the video on the right under it
  14. boot rebuilds? I'm lost LOL I'll PM you in here about the gasket
  15. I'm having trouble getting the piston back into the caliper to make room for the new pads, the piston doesn't seem to rotate and wont go back under compression, any ideas? these are the Bendix brakes I believe
  16. any info on who would stock a replacement windshield... or anyone have any gasket chrome?
  17. looks good, should do the wheels too it'll look badass with a flat black brush guard too
  18. actually I'm trying to put the 2.5 tranny in the 2.2 car but if the final isn't the same then it won't work for me, as I am only getting the tranny
  19. so will a 2.5 tranny mate with the 2.2 without having to change anything else?
  20. the transmission I have doesn't fit (it's from a 2000 RS), does anyone know if the 1998 2.5 legacy transmission will work with the 2.2???
