Everything posted by MachineAgeVictim
offroad brat
MachineAgeVictim replied to michael appel's topic in Historic Subaru Forum: 50's thru 70's
they make ATV tires that fit our rims, check in the offroad section -
74 Sedan Arrived Today!
MachineAgeVictim replied to bryanthompson's topic in Historic Subaru Forum: 50's thru 70's
WOW where do you find these!?!? -
well the shaft still turns even if it's not engaged (the rear wheels/gears will turn it) if it's off balance then it'll cause a bad vibration through the car, very noticable, if it does then you can unbolt the back of the shaft and tie it up with wire till you can get it fixed. to fix it then you'll only need the joint (looks like a "t" with round bearings on each end) and you'll need a press to get it together/apart
yeah I got the lugs with them, the seat is also seporate from the nut, it rotates (or doesn't rotate as you turn the nut)
I always wondered what was special about the alloy lugs? bigger seats?
I'm selling my 4x4 in the for sale section
EA71s are fast!
MachineAgeVictim replied to SakoTGrimes's topic in Historic Subaru Forum: 50's thru 70's
I'm suprised how much torque is transfered to the wheels of my EA71, with oversized tires I can spin them through 1st btw I own the best honda ever built and they shouldn't be written off as behind the curve (Subaru takes a turbo to do what honda does N/A, 120hp/liter) -
Strange low rpm hesitation
let us know if that helps, sounds like the same problem mine has that didn't go awya after a pump replacement, I dialed it out a little after I put a new rotor on it -
Brake pad replacement question
MachineAgeVictim replied to MachineAgeVictim's topic in Historic Subaru Forum: 50's thru 70's
anyone?? -
ok so it moves only with alot of cranking, currently using channel pliers around the outside of it can I compress it using a clamp? -
one awesome 1979 DL
MachineAgeVictim replied to backinbrat's topic in Historic Subaru Forum: 50's thru 70's
I like the video on the right under it -
boot rebuilds? I'm lost LOL I'll PM you in here about the gasket -
New look for the Brat
MachineAgeVictim replied to GoldDiggerRoo's topic in Historic Subaru Forum: 50's thru 70's
looks good, should do the wheels too it'll look badass with a flat black brush guard too
