Everything posted by jboymechanic
There is nothing wrong with my car, I just hate driving an automatic. Not to mention my '96 Brigton averages 27 mpg while I only get 24 mpg out of the '95 with auto. There is a first gen legacy wagon in town, really rusty, that I could get super cheap, it has stick in it. After hearing opinions, I'm not going to attempt this (at least not any time soon).
You can call your local dealer and they'll give you a part number based on your vehicle's VIN. Just get the ECU somewhere else.
Those 3.8 V6s are pretty good motors. I have two of them in my life time, put well over 250,000 on both. Had friends that had them too that put well over that mileage as well. When I was in high school we took my friends 1988 Buick with 3.8 down to St. Louis and back to Milwaukee area, it had 388,000 on it at the time, had no issues. Pretty solid transmissions in those cars too.
Hi, don't freak out!
jboymechanic replied to MoparPhoenix's topic in Meet n' Greet. Your USMB Welcome Center
Hey, I'm another Mopar and Subaru fan. I have two 2nd gen Legacy wagons, both with the bullet proof 2.2, I have a '98 Dodge Ram quad cab 4x4, and my baby is my '56 Chrysler Imperial Coupe for which I'm building a 354 cubic inch Hemi. -
If you are able to do it yourself, about $200 to $250 for the all the gaskets (head, intake manifold, exhaust manifold, valve cover), seals (crank and cam), timing kit (belt, water pump, and pulleys/tensioners) and maybe even radiator hoses. It is not very technically challenging work, but it can be labor intensive. If you take it somewhere to be done, it can be rather expensive (pushing $1000 in my area).
Don't be surprised to find you transfer clutch drum is notched, may be a good idea to have a spare shaft/drum assembly ready just in case. I learned this the hard way when I went to replace my, my hub was actually sheared off the shaft and I had to leave the car on my friend's lift for a week while I sourced the parts. You may want to check you rear speed sensor and try a trans fluid flush first, but at 177,000 miles you're probably ready for a new solenoid either way.
Those are 14" Subaru "Snowflake" wheels, they were optional on first gen (1990 to 1994) Legacies (not sure if available on all model years). If you clean up the back side of the hub area you will find the Fuji Heavy Industries logo and some casting dates and part numbers. I have the same set of wheels on my '96 Brighton wagon, pretty classy. By the way, are you in Lake Geneva, WI?
In the past week I have done the following to my 1996 Brighton -Put the proper upper radiator mounts in -Added a coolant overflow tank -Painted Tom's hood from black, white & orange to a red that is closer to the car's color -Bought and mounted some early 90s Subaru snowflake wheels with good Widetrack SR tires (no more terrible steering wheel shake!) -Completely replaced all of the rear brake lines from under the back seat up to and including the rear wheel cylinders -Replaced the missing stick shift centering spring -Added a tachometer and proper 140 mph speedo -Ordered my pedal switches to complete the addition of cruise control
I'm a bigger fan of "Dark Side of the Moon" personally.
I knew a guy that got his hands on a real train horn and installed it and the compressor in his old chevy pickup. People just about ************ themselves when he hit the horn!
Put a new oil fill neck o-rings in in both my '95 and my '96, old ones were so hard they snapped during removal. No more oil leaks there. Put a new oil pressure sensor in my '95, no more oil leak there either. Finally, put new plugs and wires in the '95 and to my shock I found the current plugs to be in finger tight! Needless to say the car runs much better and has more guts, the previous owner was a real gem!
Hi, putting my transfer clutch back together and I need to confirm the orientation of a spring that popped out when I removed the tail section cover. I tried to be slow and careful, but the cover was stubborn and I had to tap it a bit with a hammer and block of wood. Any way, here is a picture I found on an Outback forum and I want to know if this is correct before I put mine together the same way (kind of annoyed that my FSM doesn't show it). I hope to finish this job today, so if it is correct please let me know ASAP. As usual, thank you to all those that help!
