Everything posted by Setright
Yes, for sure spend the extra cash on the Genuine filters. Some of the other filters named here aren't bad, but the Subaru is a sure-fire, no risk, best option. I like Mobil 1, and have had good results with it for a long time, in many cars. Castrol products are good too. I use their brake fluid and trans oil for the rear diff. Shell in the manual gearbox, and Shell in the coolant. Mobil in the steering pump.
I drove a 2.5XT Forester recently, and it pulled in the horizon after 3000rpm, too! However, throttle response is dulled so much by lag, that taking the car round corners was terminally frustrating. Brake hard, turn-in while releasing the brakes, stomp on the gas.....nothing....nothing.....VROOOMMMMMM! In my 2.0 Impreza the "stomp on the gas" manouvre is followed by instant urge and a small dose of oversteer. Just how I like it
Standard camber on standard ride height is -1.0 degree. You'd need about 3-4 degrees to cause abnormal wear. Which is easily visible and would leave a smooth wear pattern. Toe is harder to see and leaves a rough pattern. "Providing you don't liff off.." TRUE, but this can be necessary on public roads
The cold rad only indicates that coolant is no longer circulating. This can happen for a number of reasons: Thermostat stuck Waterpump impeller loose or missing propellers Timing belt slipping on water pump wheel Waterpump bearing seizing Vapour lock in the water pump Blocked radiator or coolant hose Running very low on coolant Vapour lock means there is gas in the system, could be atmospheric air from the rad replacement, could be compression/exhaust gases due to a small HG leak. Do a site search for "coolant replacement" that's my best bet at getting it done without air bubbles.
Well, it does sound like your clutch is not fully disengaging. How old is the clutch cable? If Josh and yourself couldn't find anything wrong with the adjustment, then maybe the cable itself is tired. Of course it could be something less obvious, like oil on the clutch plate. If the rear crank seal is leaking, this could leave a film on the flywheel that drags the clutch along, even with the pedal down. This might explain why leaving it standing reduces the problem? Maybe. Or, you need to replace the gearbox oil. Valvoline Synpower 75W-90 has recieved a lot of praise from a local Dane who rallies an Impreza Turbo. Might be worth looking into. Otherwise, Castrol Syntorq has been a favorite of mine for a while. I have recently switched to Shell SF5288, but it's probably too thin for Texan temperatures.
