soobie_newbie67
Everything posted by soobie_newbie67
  1. Sway bar linkage. The link that connects the sway bar to lower control arm. Just get another at the junk yard. Oh. And it is easy to replace.
  2. I can tell you MMO cleans out catalytic converters. They were plugged up pretty bad on my truck to where they were killing power, but the truck has no post o2 sensor so it didn't throw a code. I ran MMO in the fuel for 600 miles and not only did it clean out the cats, I got back some missing power. Now this is a truck the we have owned since it was brand new off the lot and we have never ran a fuel additive in the tank since we bought it and it now has a 104,000 miles. I ran Marvel Mystery Oil in the fuel and when I decided to pull the catalytic converters they were spotless. They were so clean I held it up 2 light and you could see right through them. Now I don't know about you but if you can make a catalytic converters that clean I'm pretty sure Marvel Mystery Oil is good for something. My buddy also put it in his Honda engine that you fired up in the morning it would burn a little oil and now it doesn't burn any oil at all. The oil burning went away after about 200 miles. Of course that 200 miles came fast for him because he drives 80 miles a day so yeah. I'm a strong believer in Marvel Mystery Oil. I had a 1991 Mazda Navajo that had a few running issues so I ran Marvel Mystery Oil in the fuel with the fuel pressure regulator disconnected. After about 500 miles I noticed a huge improvement in acceleration and throttle response. No I probably want to ask somebody on the forum first about doing this to my Subaru because I don't know if the fuel rail would be able to hold up to full pressure all the time. Anyone have any input on that???
  3. How the heck did you install that Chevrolet rearview mirror? I wanna do that.
  4. I have a stock turbo you can have. No play.
  5. I see that over confidence issue in the snow every year, but with idiots in big rump roast trucks. They think their ginormous tires give them better traction right before they crap themselves cause they almost killed someone. They just don't think they have to slow down like everyone else.
  6. Cool. Thanks GD. I was going off what I learned from a 40 years experienced ASE certified teacher I took 3 years with in an automotive technologies class. IMO. The most important thing is to get the correct service grade and viscosity. Just my 0.02
  7. Actually Ivan all oil is not the same. And I'm not talking about the differences between synthetic and conventional. Things you need to look for when checking out oil is the service grade. As of this year the current survice grade is SN. Also be looking on the front of the oil bottles for the starburst symbol. It says American Petroleum Certified around the edges and "For Gasoline Engines" in the center. On the back you wanna look for what's called API Service donut. It states the service grade of the oil, oil viscosity, and may or may not say energy conserving. Just keep this in mind folks: as long as you use the viscosity rating and service grade (or higher, never lower) that your car calls for and the oil you are buying has the starburst symbol on the front, you are buying a quality oil.
  8. Ah. Over hear cheapest oil you get is Federated. A little parts store called 9 to 9 auto parts sells it at 3.49 a qt. It's legit stuff. We have a 2000 Chevy k2500 p.u. with a 454 that we have used said oil in since we bought it new with 91 miles on it. Replaced valve cover gaskets at 104000 miles and the heads were still silver. Spotless. I also used the stuff in a 1994 Plymouth grand voyager 3.8. The inside of the engine wasn't perfect put after just 2 oil changes those heads were clean. I know cause I had to do a intake manifold gasket.
  9. Well I hope your right. I called the dealer and the service guy told me it has a speedometer cable. I don't believe him. I couldn't find a cable anywhere.
  10. So, I don't mean to thread jack or anything, but is it a good thing that I did these procedures and the AT temp light didn't flash at all???
  11. Well. On Monday I'm gonna call the dealer and see if they can calibrate it. I downloaded a speedometer app on my phone and found out I'm doing 65 @ 60 on the dash. Around town no problems through. Doing 36 @ 35 on the dash.
  12. Can't I just use a speedometer sending unit from an outback that uses 205/70-15 tires? Or do I have to go to the dealer and have it calibrated?
  13. Actually I did notice something interesting. You would think it shouldn't work this way, but I noticed my car moves along better and steers better with these tires. :/ Oh yeah. And what will I have to do to fix the speedometer difference issue???
  14. So I should get better fuel mileage too xD. The engine will be turning less rpm's while the speed is upped.
  15. Alright. Today I successfully put outback rims and 205/70-15 tires on many legacy l and I was wondering, since my stock tires were 185/60-14, how badly will my speedometer be affected and how hard will it be to correct???
  16. ^^^ would there be one of those intake silencers on my 1996 legacy? Found it. Removed it. Wow
  17. Actually the dri-************tiez has a very off the wall climate. It changes unexpectedly.
  18. Alright. I think I'm gonna pitch the idea for now then and just wait till I order the legacy gt-b engine cause I will have to change the cross member for that too. No since in removing the engine twice.
  19. I believe GD told me the ej22 is capable of taking 10 psi on stock internals, or was that a dream? There's a legacy (gen before mine) and I was wondering if it would be possible to grab the y pipe turbo and downpipe and swap them directly into my engine. And what would I have to go through to run the oil supply line and return line.
  20. Ok. I got the cooler installed and I'm good to go. Installed it like the picture shows. And replaced both of the rubber hoses, I think they were the originals.
  21. Ok. Thanks. That's funny. I thought there was no such thing as too cool when it came to autos. My next question is: which of the 2 lines is the return? I'm assuming it's the lower one.
