4
Everything posted by Idasho
Official 6-Lug Re-drill Thread: Now in the USRM!
Idasho replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Or just drill extra holes in between each hold in a 6-lug steel wheel... Make is look like a "universal":) Then youd have a 12-lug wheel, with almost infinite ways to mount it on your 4-lug subaru:banana: -
Documented: The 1970 FF-1 Project car...
Idasho replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
PIMP :cool: Props for pushing on with this project. Fantastic work. -
Last link. Although mine are 14" So they would be equiv and Id assume identical to these. http://recstuff.com/14X6-5-4.5-White-Spoke-Trailer-Wheel.aspx And currently, 14's actually provide better off-road tire selection for these older Subarus, assuming you do not want to hack a tone of sheet metal to make things fit. -
Those look to be the exact wheels I have. Scored from a junk yard here in town for $5 a wheel -
I dont think Ive ever seen a non-safety bead trailer wheel either. Ive got a set of 14" trailer wheels in the shop that will eventually be drilled and fitted with some BFG A/Ts I just went to check, and they do have safety beads. I can get some pics for you tomorrow. -
Idasho replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks like a 6-lug trailer wheel to me -
lookin' good dude. Bravo for bringing this one back.
No orings. The machined surface with a bit of sealant is what creates the seal. Bolts just hold the two halves together. Unless the cracks are huge, don't worry about them. Do not use any kind of sealant on the headgaskets.
Welcome JTR!! Im right down the road in Moscow. Give me a shout if you need some help with anything. Ive got my own shop. :cool:
just remove the entire spring/strut assembly. You do not need a compressor.
With power steering the rag joints see very little stress. The rack should turn effortlessly with the motor running, and a good power steering pump. hence the "power" in power steering Dont even think about using rag joints on manual steering. They wont hold up.
Ive got power steering, and I like the comfort rag joints provide. My solution was a short extension for my small lift, and double rag joints. The extension is nothing more than a small section of steel tubing, and two flat bar flanges. The rag joints are made from heavy heavy dude radiator hose, doubled up.
Looking good dude. So I guess the stubs are welded to the CVs, eh?
this thread has some rebuild info. http://www.ultimatesubaru.org/forum/showthread.php?t=3296 I considered doing just that a whole back, but instead just bit the bullet and purchased a reman. This page has some dizzy replacement info http://www.bonnefinstudios.com/kwb/automotive/dizzy.htm
hello everyone. brat owner
Idasho replied to giantmalamute's topic in Meet n' Greet. Your USMB Welcome Center
Actually it says upgrade to a hitachi manifold, them weber Welcome! -
Send a PM to lyter1983 I just purchased a motor from him, and in order to get the thing light enough for UPS ground, he stripped it a bit for me. Alt bracket included.
EA81 - Charge Light "ON" with key OFF ?
Idasho replied to gadberry's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You sure it isnt just the ignition switch? Can you turn the radio on? How about the headlights? -
dont bother with Por-15. Way too much fuss. Check out Monstaliner's chassis paint. http://www.monstaliner.com/monstaliner_how_to_stop_rust.htm
