86subaru
Everything posted by 86subaru
i am going to pull a pop up camper , with my 1997 legacy L awd a/t wagon, [ class 2 hitch] every place i go to says something different, that a hitch for a legacy L wagon and a outback are different ? or are they the same ? i was reading here i think that the wiring for the lights is very simple ? thanks
Helicoil exhaust header bolts on a loyale?
86subaru replied to Milemaker13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
this topic has already been covered, and i ended up getting kicked off the board for a day, -
i have a 88 full time 4wd turbo wagon , a/t
ok, checked all fluids after i drove it 50 miles,thanks
it seemed to get better as i drove it, that is what i was thinking , thanks
it's on my 88 turbo a/t full time 4wd wagon, no oil in coolant, no coolant in oil, compression good, nothing leaking, as been sittting for awhile, very cold outside, exhaust was fixed right, drives good, seems like alot of smoke coming out of exhaust, while it's idling, if driven not as much ?has never done this before
found 7/16th 14 1inch corse bolts
86subaru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
since the bolts might be hard to find ,they have them , just thought i would pass it on,the stores are in indiana, ohio, michigan , WI, , they are found in then bolt area, -
found the bolts at menards .49 ea, which are used on spfi + turbo exhaust if the threads are stripped ,you will need a 7/16th tap found at napa ,
in my opinion keep on adding oil, check it a few times a week , what weight of oil was it changed with? it might be a bad pvc , which is cheap, can't answer the 2nd question ,because i do not have emision check here,, in my opinion and where you live change it with 10w40 regular oil , when the headgasket was done all seals should have been done also,
parts bin, is good,
idle problem after warm up
new plugs , it has been pretty cold out , 10-15 above 0, at night ,and it does set outside , will check it out when i get home saturday morning ,thanks
