86subaru
Everything posted by 86subaru
Engine racin' in park (no load)
86subaru replied to thealleyboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
john clean out your pm box :banana: -
loud noise from power steering pump.
86subaru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i broke the tensioner bolt , [ square compressor ] can i still put the belt on and run it ?or what size is it -
the ones i saw were a total of 58 bucks, but remember shipping is higher going saskatchewan,
ebay had them ,40 bucks + 18 shipping , us dollars or pay-pal
my 88 spfi d/r dl. wagon does the same thing ,but only when it is colder out side , but since i do not have a tach ,i am not sure what the rpms would be , after i cleaned the maf it started to do this, but it does have 197,000mi on it -
no problem pat, or what size is it ? i could go and buy 1 , it will be aleast sunday before i am back home -
the alt belt is new along with alt, water pump, + i check things out during oil changes -
yes tensioner bolt, if i remember right counter-clock wise will tighten it up , after i get 1 ,thanks pm me and i will give you my address -
i took the ac belt off because the compressor locked up , yes i could have just unhook the power to the compressor , but the ac belt was very loose , since i bent the long bolt ,on the square type compressor , and have not replaced the bolt, it must be the colder weather ,because the ac belt has been off for awhile , pat do you have the long bolt ? for the square type compressor ,it's the bolt for the pully on the tension pully , about 8 inches long [ 12 mm ] -
sounds like a bad compressor , the belt is squealing , but the alt belt is new , along with alt, new napa water pump, seems the colder it gets the more it squeals , and it only lasts about 5-10 seconds , the car sits over night , the wheel is straight , ,it is not the compressor ,because the belt has been removed , the alt belt is not wet or oily also -
if it is not the power steering pump then what else should i look at , the wheel is straight car is running and still makes the noise? -
now if i can find the spare 1:eek: -
as the weather gets colder here the power steering pump is making a loud noise , after afew seconds it goes away , i am thinking the pump is bad any comments ?[ 88 turbo a/t full time 4wd wagon] new alt belt, new alt, and it is tight, i have a spare , it should be fairly easy to change
not sure the name brand of my muffler ,but the muffler shop put on a turbo muffler, it's on my 88 turbo a/t full time 4wd wagon, with no cat, make sure you run aleast 2in pipe from the curve part back , and yes it makes a difference , the shop i went to did not put a flange ,so if i have to take it apart it will be harder, , and where the cat was i wrapped , my mpg did not really go up ,but alot more power , 24 city, 25 hi way, but mine is a automatic tranny
black smoke out tail pipe
ok,it only did it 1 time,and only a small cloud , the plugs are new ngk + good new wires, will see if it does it again , thanks -
we did get gas from a different station , 87 octine, , i think the idle problem is that i am running 87 octine instead of 90 or higher, on my 88 turbo , the station she always gets it from has 10% ethanol in it , mpg is 23-24 city.the air cleaner is a k-n ,cleaned out 5,000mi ago -
wife came home and said that BLACK smoke came out the tail pipe, and ran fine after that, right before that the car got real dogish, no cat , everything looks good, no major oil leaks, that might cause burning,
idle problem , 88 turbo a/t full time4wd
ok, i'll telll the wife , but she's pretty tight with a dollar thanks -
I fixed my car with vacuum cleaner parts!!!
86subaru replied to Frank B's topic in Old Gen.: 80's GL/DL/XT/Loyales...
please add to subaru manual -
yes had the car for 2 years, i was thinking about running higher octine, but it does cost more , , instead could i put something into the fuel tank ?average mpg is 23-24 city hi way 25 -
after the car is warmed up and driven , a few miles , shut the car off for like 1/2 hour , restart it the idle is real low almost ready to stall , if the car sits over night the idle is fine new, oem pvc, nkg plugs, good wires, new cap /rotor , cleaned maf , timing set, no cat, running 87 octine, this is on a 88 turbo a/t full time 4wd wagon, , also new fuel filter, ,thanks
i also bought a 2 row radiator from them , very quick shipping , + fit great :D :D :D
MAF sensor cleaning...who'd a thunk!
86subaru replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
no real change mpg 24 , city ,but have been using cheaper gas, this time i filled up with better gas :-\ -
my update on cleaning maf , cleaned turbo wagon today , no affect , on the spfi dl wagon mpg seem to be up -
power steering pump question
ok thanks
