86subaru
Everything posted by 86subaru
  1. just wondering what a 89 dual range 4wd white hatchback is worth ? also rust free, over 100,000 mi ,it is a carb , new ctutch, new tires, it is very close to me
  2. my guess is the timing is off or plug wires are switched
  3. no did not have to pay, i called the dealer and it is still under warranty ,
  4. i did ,and no response , 3 weeks ago , i see him on the board and he does not , email me back ,
  5. my 2000 outback is leaking again ,but i have not bought the stuff from the dealer yet , should i go ahead and get it ? and put it in ? the headgasket was replaced 20,000 mi ago , 36,000 mi , do they have to put it in ? or can i ?
  6. please check your email, i have not yet received the set of rubber seals, i have emailed you many times and i need them , i wanted to order more parts , but ........
  7. also if you can get it done , degut the big fat cat ,if it is a turbo , i run acell coil , ngk plugs, 8mm wires, k-n filter, air box cut out , improved hp alot, mpg is 22 city , set timing at 20 , it is a/t full time 4wd wagon
  8. i am also going to put 4wd into my dl wagon , the dl is already a manual
  9. ok, i am going to reseal my manual 4wd ea82 dual range tranny , my question is ,i have a complete rebuilt kit oem for a a/t ea82 fwd tranny ,what other seals or gaskets will i need for the manual tranny ?
  10. do you have a place to work on it ? and of course get tools ? haynes, chilton, and even how to keep your subaru alive , you could always try to talk him down .
  11. i have a new drain plug , i'll check with a local shop and see what he can do , he ows he a favor anyways , then i guess a different oil pan , which i do not have ,
  12. i went and got a new bolt for the oil pan, i still can not get the old one off , any suggestions ? besides replacing the oil pan , would a impact work ?
  13. yes if you can fix it , it is nice to have , i have it on my 88 turbo full time 4wd a/t wagon , even if my wife does not
  14. what auto parts store ? advance auto ? now to get the old one off ,i have plenty of oil pan bolt gaskets , thanks
  15. after everthing is said and done get out and move away ,even out of state , start over
  16. yes you can put regular struts in it and replace the air suspension , it all depends on the price of the car ? and over all condation
  17. ok i stripped the 17mm bolt on my oil pan , it is still on the car and not leaking , what would be the best way to get it off? what other bolts would fit ? it is really tight , would any auto parts store have 1 ? thanks
  18. brain please check your email , i need some more subaru parts ,
