Everything posted by 86subaru
rear bottom seat needed asap / tan
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow about a left rear arm rest [ tan] , [ drivers side rear] and a cargo cover/
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalso a gray cargo cover for the same car [ working ]
i am in need of a rear bottom seat tan asap , for a 2000 outback wagon , sent to 45365 , send me a private message with cost . also the seat must be like new no stains or cuts a-1 shape . thanks
subaru's being crushed
another junkyard which has been closed for 20 years crushed 2 78 brats 2 - 80s wagons
i went to a big yard today , thinking they would have some parts i wanted , but all there subaru's were crushed 2months ago , so drove to another smaller yard thinking there was a turbo wagon there , no go , scrap steel is still pretty hi ,good thing i have alot of spare parts
89 GL Wagon: Source for driveshaft and replacement 1.8L engine
it's pretty far off ,but brims in kenton, ohio would have all you need
ac question
ok, thanks, because i think the square compressor in the turbo wagon is bad, also while i was mowing the lawn i must have through a rock and it hit the windshield ,about a 6in crack
ac question
can i change the compressor from the square 1 to the round 1 ? is so what all would it need, the 1 on the turbo wagon is bad and it is sqrare and i have a good round 1, they are ea82
The ROADTRIP tool kit.
86subaru replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa cold 12pk, plenty of smokes ,
thinking of parting the subie
or contact me
i will make a offer when i see pics , what part of MI are you in ?
trying to troubleshoot am ea82t stalling and running sickly any thoughts?
this is what i did to my turbo a/t gl-10 full time 4wd wagon w/ 85,000 , ngk plugs gaped at .45 , 8 mm wires, acell coil, cut out bottom air box, k-n filter , cut out big cat , no center cat ran 2in pipe all the way back , turbo muffler , i get 22-23 mpg in the city , temp runs 1 bar less than before , but i have a 2 row radiator also
What causes that Subaru ticking?
try mmo , mine does the same thing 86 spfi a/t sedan , use a good oil + filter
air suspension question and help
ok, did some looking ,i think the black air line is bad , when i wiggle the black air line going into the strut it sometimes leaks more or less , i set it all back togather and it is not leaking , can i replace the black air line ? and where can i get the line at ?
ok, if i discount the control under the drivers seat , it still will leak off right ? i may try putting tire inflate into the struts , or could the hose be loose going into the strut ?
i have 88 turbo a/t spfi full time 4wd wagon , when the car sits like 8 hrs or longer all the air leaks out of the front air struts , after you start it up and let it build up it is fine while driving , if you park it with the motor off for 1 hr it is ok , it was fine a week ago , where should i start looking ? any easy fix ? and yes i have looked at the xt board and read about it , or should i replace the front 2 struts ? what are good name brand ? are there different sizes or are they all the same for a ea82 manual wagon 88, ?
If anybody needs a carfax run, let me know.
could you run this, jf1an42b1jb458993, thanks
fuel leak/ need part
ok will give it a try , thanks
i found a fuel leak by the fuel pump ,it seems to be leaking around the regulator , it is a 88 spfi dual range manual wagon , does any one have one of these to sell ? the regulator looks real rusty and is leaking badly , or are they same as on top of the motor ? after the fuel filter , because i have several of these . thanks
Digital to analog gauge change?
how about changing a 88 dl analog , and putting a analog from a 86?
another loyale tranny problem (yeah, I know)
i have no problems with mine , turbo full time 4wd a/t 85,000 mi gl-10 , also 2wd spfi a/t sedan 76,000mi
Hooters for lunch
yes i have drinking cold BEER
new motor
try at your local junkyard , here in ohio there about 150 bucks used , but different parts of the county have different prices , manual or a/t
found 89 hatchback / rustfree
he wants 600 bucks, glass all good, interior is ok, and other work has been done to it , i will be talking to the owner again tonight , i only talked to his father which knows very little about it , thanks
your right
