Everything posted by 86subaru
Okay stupid question i know... but thermostat replacement
well i use 180, make sure you put in a new thermo gasket also, may check all radiator hoses, change heater hoses, check fan belts, change diff fluid, wiper blades,
problem w/ 88dl manual 4wd wagon
yes after i warm it up it will not do it as bad ,
after the car sits for awhile like over night, it starts up fine idle is fine , i 'll put it into 1 st gear and start moving and push on the gas it will almost stall or buck and run real slow for a few feet , after it is warmed up it is fine , timing is set , new fuel filter, acell coil, 8mm wires, new cap, but i did not change the rotor , or is it something else ?
Sheet of Plywood hits my soob on the freeway
well something like this happaned to me ,but i was in the semi and some how through a good size rock from the rear most trailer tires and hit a chev -s-10 , and i did not not know i did it ,until the guy waved me down , but in your case improper load [ not tied down] in my case it is called a road hazard
ea81: replace ? when engine is out
the answer to your question , you could stop by any auto parts store and ask them
Read... Help... Oil...
i my self have been using 20-w50 , use a dura- blend , about 9 bucks a-gal and a good filter [ castrol , ]
go to any auto web site
fuel tank question
i was just asking a question , if you do not know the answer please do not respond
fuel tank question
i asked this before but can not find the post, will an 88 xt 4wd fuel tank fit into a fwd seden or 4wd wagon ?
fuel tank QUESTION
i have an xt fuel tank from an 88 single range will it fit onto a turbo 4wd wagon or fwd sedan , since i am stripping down an xt it might be a good to keep a spare fuel tank , i can get it check out for free and cleaned out etc...
fuel tank Q
i have a fuel tank from a xt , the xt was a single range 4wd , will it fit onto a 86 spfi a/t fwd sedan ? or a 4wd a/t turbo wagon ?
rumble + shimmy = ?
mine does almost the same thing, at 65mpr , when you brake hard the steering will shake alot back and fourth but i am thinking the rotors are warped or pads
found a 90 legacy awd a/t wagon just a few Q
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe owner says it could be a 90-91 i forgot to look at the vn# , no rust underneith , bosh anti- abs brakes, i think i can talk her down , now to tell the wife, or just buy it and hide it
fan, blower not working
ok, thanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell the car has no battery and sitting in weeds , but it has not been sitting just to long , the rear hatch does not open , drivers side mirror is missing , small crack in windshield , i may offer her alittle less and take my chances ,thanks
since i know alittle about the 80s but not to munch about the 90s , i found a 90 awd legacy l a/t wagon silver 122,000mi good body , no rust, but the owner says it will not hold water, so 3 things it could be, 1- radiator, HG, or water pump, it also has abs brakes , or could it be something else?
Head gasket or Replace engine
well a full gasket set from napa is 200 bucks , it took about 14 hours with 3 guys , well 2 guys new what they were doing and i did not , if the body is good and no rust , and what you will have it after everything is done ., and a place to do the job and tools
No spark...bad coil??
when you switched the coils did you by mistake pull on the coil wire ? did you hook up the coil wires right ? check the fuse under the dash
'97 Outback Oil Leaks
86subaru replied to STL808's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa good friend of mine would do the hole job for alot less , we could do it in my garage , all seals , timming belts, water pump, etc... if you would buy all the parts , but i am aleast 3.5 hrs away from you
Snorkel on MY wagon
my wife would really like that on her turbo wagon , man you make them and sell them , my wife's car would be the only car in the area like that
strut question ?
the xt is a manual single range and the turbo wagon is a full time 4wd , will they interchange ?
strut question ?
will front struts from a xt work and fit on a front 88 gl-10 a/t turbo wagon ? my air struts on my turbo wagon are a pain and i am going to replace them
who's gonna bring some entertainment for WCSS6
how about miles road trip to idaho
Blowing white smoke
i would use napa complete set around 200 bucks ,it comes with alot of gaskets all possible needed and then some
abandoned vehicle Q?
this is how i got a turbo a/t sedan ,no title,no key, , this garage towed it from a apartment building and the owner has 30 days to claim it , but i did not try to get a title either just a good parts car
