Everything posted by 86subaru
engine flush question
right, just wanted some input ,thanks
this has been asked before alot, the engine has not been driven alot , i have driven it 500 mi with clean oil, good filter , should i use motor flush or tranny fluid ?, which might be better to use ? and of course replace oil and filter ,
cooling ?
i had the same problem , i used a xt clutch fan , it is shorter , and has another fan blade
New discovery... late model XT seats BOLT IN to Loyales!!!!
no , but but with a few changes they will , bottom track on seat must be swapped , mine are in my dl right now
alt question
well the dash lights are not working , we replaced the dimmer switch and the lights worked , when we started up the car , no dash lights , on my 88 dl 4wd manual wagon the alt was pretty warm even after sitting 10 min ,
alt question
yes everthing was hooked up ok, but the alt got real hot , so i shut it down , and ran out of time to work on it ,
alt question
bump
alt question
ok, i replaced the alt in my 88 turbo a/t full time 4wd wagon , replaced dash light dimmer dash lights were good , did some other work , no dash lights, also alt is real hot to the touch ,should i replace the alt again ? thanks
groaning front end
could check your drive axles , looking underneith the front at the inner outer boots , just a guess ,
dl wagon hatch question
ok, thanks
ok we all know that dl are stripped down , my question is there a way to put power lock unlock on it like the gl's ??? or do you have to put power front locks in , which i am going to ?
Show us your homemade carrier bearing mount!!!
i will go buy some film and take pics of my dl wagon which there is a bolt on type mount for the carrier bearing
reverse light wiring, 5spd conversion, vice versa
bump
alt problem fixed/dash light problem
ok, thanks
hello all, my alt on my 88 turbo full time 4wd a/t gl-10 wagon went out , so i replaced it , now the dash lights are out , clock , floor shifter light , are all out , the digital part is ok , is there a breaker fuse or reset somewhere ??
Probably wrong section, but hear me out
3.5 hrs from my house
Found a tool in my Loyale, Whatsit for???
i think it is the lug nut wrench , might be other tools also
Car stripping advise
save everything , i have done 3 all that was left ,was the frame and glass , put the bolts on pretty loose for the struts and put it onto a trailer ,push it off at a junkyard ,then jack it up and remove the hole strut brake stuff ,and drive off
light problem , all gauges are on
any place where i can get bulbs for the dash ,
How is life in the real world?
welcome , if you can buy a parts car and park it behind the house , when you need any parts walk out back and get them or strip it down , but always remember where you put the parts at , not like me forgot ,
Inexpencive parts for a 1988 Subaru Gl
yes you do get what you pay for, but around here there are no more subaru's ,i have bought them all , all the junkyards crushed all they had, all the auto stores have to order parts for me every time , so having parts from other cars sure does come in handy
email miles fox , he is in ne IN,, I am in western ohio, what parts are you after ?
Mufflers, Cats and Welders oh my!
i have a 88 turbo a/t full time 4wd wagon w/ 88,000mi , i get 23 city 28 hi way, big cat cut out ,2in pipe all the way back turbo muffler , i run 87 octine , but i may try a tank of 93 or 94 from shell ,
thanks, well my wife did help , she has longer fingers and smaller hands , i think i read awhile ago that you could change the bulbs and even buy them at radio shack , not sure of the #
ok i changed the alt , all lights are out, but now the white top and bottom are blown out on the dash , speed ok, temp ok, fuel ok, also on the shifter on the floor are not on ?? are they blown out ? if so can they be changed easy ? thanks
