Everything posted by 86subaru
found 89 hatchback / rustfree
just wondering what a 89 dual range 4wd white hatchback is worth ? also rust free, over 100,000 mi ,it is a carb , new ctutch, new tires, it is very close to me
Help with backfiring on Loyale
my guess is the timing is off or plug wires are switched
coolant additvie question
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno did not have to pay, i called the dealer and it is still under warranty ,
Att, Tailgatewagon! (updated 4/19)
ok,will do
i did ,and no response , 3 weeks ago , i see him on the board and he does not , email me back ,
bump ???????
my 2000 outback is leaking again ,but i have not bought the stuff from the dealer yet , should i go ahead and get it ? and put it in ? the headgasket was replaced 20,000 mi ago , 36,000 mi , do they have to put it in ? or can i ?
bump hello, hello, bump
please check your email, i have not yet received the set of rubber seals, i have emailed you many times and i need them , i wanted to order more parts , but ........
Sawzalled the aircleaner
also if you can get it done , degut the big fat cat ,if it is a turbo , i run acell coil , ngk plugs, 8mm wires, k-n filter, air box cut out , improved hp alot, mpg is 22 city , set timing at 20 , it is a/t full time 4wd wagon
Need YOUR input as a Soob owner!
all the above
2wd -> 4wd conversion
i am also going to put 4wd into my dl wagon , the dl is already a manual
4wd manual tranny question
ok, i am going to reseal my manual 4wd ea82 dual range tranny , my question is ,i have a complete rebuilt kit oem for a a/t ea82 fwd tranny ,what other seals or gaskets will i need for the manual tranny ?
to XT turbo or not to XT turbo
do you have a place to work on it ? and of course get tools ? haynes, chilton, and even how to keep your subaru alive , you could always try to talk him down .
Common Subie probs??
oil leaks, timming belts, drive axles,
oil pan bolt question
i have a new drain plug , i'll check with a local shop and see what he can do , he ows he a favor anyways , then i guess a different oil pan , which i do not have ,
i went and got a new bolt for the oil pan, i still can not get the old one off , any suggestions ? besides replacing the oil pan , would a impact work ?
ok, thanks
Air suspension Q's
yes if you can fix it , it is nice to have , i have it on my 88 turbo full time 4wd a/t wagon , even if my wife does not
what auto parts store ? advance auto ? now to get the old one off ,i have plenty of oil pan bolt gaskets , thanks
Road Trip II: TrashWagon's RETURN
after everthing is said and done get out and move away ,even out of state , start over
Air suspension Q's
yes you can put regular struts in it and replace the air suspension , it all depends on the price of the car ? and over all condation
ok i stripped the 17mm bolt on my oil pan , it is still on the car and not leaking , what would be the best way to get it off? what other bolts would fit ? it is really tight , would any auto parts store have 1 ? thanks
music subaru video
brain please check your email , i need some more subaru parts ,
someone was asking route of trip , i bumped it up to the top , along the way is the title
