Everything posted by 86subaru
91 Loyale - I made a BIG Boo Boo, can anyone help
well just in case that you could not fix your girlfriends car , always worked for me
Hello everyone!
try auto trader .com. or ebay ,
wine and dine her in the subaru , alittle soft music from the radio , a bowl of grapes, some good canjun cooking
How much for my subaru???
around here 800 or 900 dollars , i just sold a fwd 5sp with 181,000mi alot of rust 300 bucks , but had all new seals, good tires, ac worked, am-fm radio, so different parts of the country bring different prices
Subaru Dealers
86subaru replied to STL808's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot trying to be smart , go to subaru .com and do a dealer search , it will give you locations + phone # 's
Ahh gotta love those Cops...
should have gotton out of the car grabbing your neck and falling to the ground , just joking
EA82 Timing Belt replacement
maybe a good time to replace the fan belts, i suggest oem , because aftermarket can stretch , plugs and wires, air filter , pvc, fuel filter ,
This Event Has The Tommy Lee Seal Of Approval: 2nd Annual Subaru Shootout!
what part of pa ? a few of us may be coming that way to get a turbo wagon very soon
1700miles of Doom (Or a story of Addiction)
well i just about had the same trip but shorter , a 5hr trip took 13 hrs , truck problems , tornado's and no lights on the trailer , for a 88 single range xt4 turbo with a blown headgasket
ground questions , locations
ok, thanks , i am running a 60 amp , which is my last spare , the battery is 5 months old, i have not had the battery tested yet ,but i will
88 Gl 10 turbo ?'s
i have a 88 full time 4wd a/t turbo gl-10 wagon w/ 90,000mi , make sure you run a 2row radiator , mine also had the air struts ,but i had to replace the fronts , mine runs great and shifts good , k-n filter , acell coil, ngk plugs, 2in pipe all the way back
does my ac work?
is there a ac belt on , does the compressor turn at all ? it might just need recharged, but i would say it has r12 in it , all the old oil and r12 has to taken out ,, and replace all o- rings , switch over to r134 it is much cheaper
it is a turbo full time 4wd a/t gl-10 wagon, with digital dash no volt gauge
well having a few problems , 1- i keep on burning up alt's , i put on a 60 amp , which is the last spare i have , where are all the grounds located ?
Chattanooga area?
check the xt board also
1988 DL wagon questions
also remember the dl has no power locks or power windows , which is ok ,but it sure is nice to aleast have power locks
well check underneith the car around rocker panels, underneith all 4 doors for rust, check any major oil leaks , but subaru's like mine leak alittle oil, but remember that after you buy it that the timing belts might have to be changed along with the water pump and seals , check drive axles inner outer boots , drive it and see how hot the radiator gets, check ac, heater , look at all records, well being automatic they can go bad and at 155,000mi , bepending on price
charge light / alt problem
no it was a used 1
checked fusible links they are ok , charge fuse is good, dimmer switch is good,
ok, it just seems odd that just a few weeks ago i had the same problem , i changed the alt and it was fine
my wife made a point , each time the alt went out it was rainnig????
all the red lights come on now , i just put a good alt in it , it is a 88 a/t turbo full time 4wd wagon , would it be the alt ? or something else ?
EA 82 Wagon New Seats?
go with gl-10 seats fronts and back just my opinion
turbo exhaust question?
but of course that price is here in this part of ohio and only 1 place that i know of
cleaned out , 2 in pipe, turbo muffler, 100 total included labor
