Everything posted by Cyfun
Introducing the Subercoupe Now with 50% more cyl’s and 100% more RWD!
Cyfun replied to suberdave's topic in Members Rides
6-speed, fich ja! Or just throw a FWD auto trans in for drag racing purposes, and then you wouldn't have to worry about a clutch, but where's the fun in that? -
Oil Catch Can in EA82
Cyfun replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So to clarify, you put your catch can between the driver's and passenger's side valve covers? I'm working on some catch can ideas. Was just going to make one out of a jar, but then I considered using this filter/catch can for air compressors from Harbor Break. Not too worried about the filter getting clogged, it's designed to push pretty good volume. And like you said with the eBay catch cans, the pipes seem too small. For $10, we'll find out! I'm actually going to try this first on my mom's Volvo 940 Turbo first, as she gets a disgusting amount of blowby. Mostly happens when I drive it, for some reason.- 42 replies
- Oil Catch Can
- PCV System
(and 8 more)
Tagged with:
Steering Wheel Adapter Questions - 88 GL-10 Wagon
Cyfun replied to subi dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Don't have any pics of the one in question, it was for my Eagle Talon and not my sooby. I've got it lying around here somewhere, I'll try and find it. It wasn't very pretty, as it was off of a Dodge Colt Vista and still had the plastic shroud for that vehicle. The trick was getting everything centered. I still had the existing boss bracket from the car it came off of (my '82 Trans Am), so I just lined everything up, drilled holes to bolt the bracket to the Colt steering hub, and called it good. Never did get the horn working, didn't really matter when you can't hear the horn over the exhaust anyway. -
This might work, claims to be "universal Subaru." Looking at the horn mechanism, it just might work. For $20, I'll give it a shot. If not, I'' b!tch them out for not being completely "universal." -
O M F G That's insane. What did you have to do to the suspension? And why did you mount the fuel tank in back instead of the front? I suppose I should ask where the build thread is on this. -
EA82 Right bank keeps jumping time
Cyfun replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Maybe the tensioner is tired, cause I'm pretty sure slipping on the right side is the most common place for it to slip if there's slack. -
Adjustable Timing Pulleys… who might want some?
Cyfun replied to All_talk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Holy 7-year old thread resurrection, Batman! What ever happened to this? -
Congrats on not having to crack the transmission. And it sounds like that axle needed replacing anyway.
Interested, how much are you asking?
After tearing more into the rear cross member, realized I was a dumbash and what all the parts are for. I updated the list, and plan on making a more detailed write-up on each component of the lift and its significance. I know I could probably get away without lowering the rear crossmember and just muscling the rear trailing arms down, but I have something unusual planned. I'm currently replacing the rear struts with 4runner struts and Accord springs, and then I will be relocating either the top or bottom strut mount so that it's angled sharper. That will give me more travel and a smoother ride, and with any luck help with my articulation issues. I'd prefer to shift the upper strut mount, but there really isn't any room unless I tear out that bump stop bracing in the car's body. So my other idea is to cut out the bump stop plate on the trailing arm, then weld a new bracket for the bottom of the strut up an inch or two. We shall see what happens.
Hell, I'd rather have the torsen than the locker for on and offroad driving. I mean, a locker would be BEAUTIFUL offroad and only offroad, but with a torsen if you get one wheel up in the air, just apply the brakes a bit and it will give enough resistance to the spinning wheel to send power to your good wheel. Then when you're just driving in the packed dirt or the snowy pavement and going between high and low traction situations, you won't worry about wearing tires or axles or the diff.
I'm still curious as to what some of these extra pieces are, though. Here's that pic from T'subaru's post, let's see if we can identify all this crap. I left out the diff plate, though, as I already have that done. My main concern is #8, cause I have no friggin clue. Edit: Think I figured it out. 1) Front strut lifts 2) Rear K-member blocks, rear parts 3) Rear strut lift brackets 4) Trans crossmember blocks 5) Engine crossmember blocks 6) Part of front radius rod blocks 7) Other part of front radius rod blocks 8) Rear K-member blocks, front parts
Rear Wiper Switch Replacement
Cyfun replied to Dj7291993's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm pretty sure a few of the ones in my HF pack were triple throw. In fact, I believe one of them is momentary when up and stays when down, not sure what the acronym is for that. But here's all the DP3T stuff on Mouser. -
I got a big pack of various switches from Harbor Freight for fairly cheap, rated up to 30 amps. But what I've been wanting to do is to steal a delayed wiper switch/relay setup from another car, maybe a newer Subaru. Cause with those, if you spray the washer fluid, it will automatically run the wiper for 4 or 5 swipes, not to mention having an intermittent delayed wiper. Drives me nuts in the winter to have to flick the rear wiper on and off every few minutes. -
Holy ancient thread revival, Batman. How many of you guys have smartphones? Just get a dash mount for it and use an inclinometer app.
Thanks for the link. I think I need to lower my rear K-member by about two inches, since I've been running it at a two inch strut lift just fine. I just ordered up some 4runner front struts and Honda Accord springs to replace my stock rear struts, and since they're stiffer, my plan is to change the upper mount so it's angled much sharper, thus giving me more travel and a smoother ride. If I have more travel, that will help immensely with my articulation issues. Funny that SJR's 4" lift doesn't appear to lower the rear K-member at all.
Gotcha, was looking at that pic too. But what about blocks for the rear K-member? I made my 4" rear strut brackets, but I can't get the rear control arm to pivot down far enough to install the damn things.
I've been running on a homemade 2" strut lift, and am now working on making a 4", but of course this means an assload of body lift blocks. I've searched and searched, and found plenty of pictures of SJR lifts and other homemade lifts, but haven't seen anything that really lists all the components needed. So here's a picture of someone's lift. I didn't use SJR's cause I'm sure they don't want to help people steal their ideas. If anyone can help me identify each of these parts and where they go, or if I'm missing anything, me luv u long time. 1) Front strut lifts 2) Engine crossmember drop blocks (i'm guessing) 3) ??? transmission crossmember drop blocks ??? 4) ??? part of the radius arm drop blocks ??? 5) ??? other part of the radius arm drop blocks ??? 6) ??? 7) ??? 8) ??? rear suspension K-member drop blocks ??? 9) Rear strut lift brackets
Impreza's i believe have the same spline, but the horn is different. Do what I did: get an EA82 wheel from the junkyard for a few bucks, cut out the hub, weld up a bracket for your wheel's pattern. Helluva lot cheaper. And the last time I bought a steer wheel adapter, it was so poorly made it broke while I was installing it. Better that it break then than while I'm in the middle of a big drift. -
upload them to tinypic I'm amazed more people aren't running LPG with their Roos, especially in foreign countries. You'd think at least a few of the yuppie Portland, Oregon Subaru drivers would be into that crap. I'd love to run dual fuel, but I don't think I could afford shelling out a $hitload of money to do it.
Wow, way to resurrect a 6 year old thread. xD But nice trike, tweety, I dig the inline fighter-jet style seating.
That sucks. At least a lot of places still have some stockpiled. And you could always go with the cheapo OEM replacements. Wonder if SenSen makes one. If worse comes to worse, then it'll be EJ knuckle/strut swaps for the lot of us.
