el_freddo
    148
  1. It could be the front seal on the gearbox. I hope not! The rear main seal is much easier to replace. The clutch plate might be soaked in oil making it pointless to re-use it without at least burning the oil out of the pad then hoping for the best. Cheers Bennie
  2. EA81 with an O2 sensor?? Unless it's a turbo unit I doubt it! Or did you get this setup for the californian market? You mention shifting gears yet also ask about flushing the Auto trans fluid... What have you got, an auto or a manual? Without a compression check I would say that the engine is just very tired - blue smoke indicates blow by and thus low compression, possibly on all four pots. As for the oil leaks - the subaru engines are great for making a small oil leak in the rocker covers OR the oil pump look like a major leak or a rear main seal that's gone. I'd pull the oil pump, clean it up, reseal all the necessary components and replace it. Wash the underside of the engine and see what happens with the oil deposits over the next week or two. Do the compression check, this will tell us a lot about the health of your EA81 in general. Cheers Bennie
  3. Subaruby over on ausubi has one in the rear of his MY - it's an unlocker similar to the detroit, a short run that were made by a rally mob over in Australia I believe. Either way they're worth their weight in gold and no one makes them anymore It is an r160 too. Probably doesn't work the best with AWD though. Could work for some, a lot of effort! But for me it's not going to work as I'm going to be running AWD for better traction in all situations. I've enquired with McNamara Diff's in Melbourne. Yes they can do it not a problem... IF WE HAD 500 ORDERS OF $1000 A UNIT!!! Then it would be simple after all the crap of gathering the half a million from 500 members to get it happening! Then there's postage etc to deal with... I'd love to do it, but I just don't have that money lying around and can't find 500 members with $AU1000 to hand over for the unit. I could probably find 500 members who are keen but once it comes to putting the money up everyone backs out as usual Cheers Bennie
  4. The crown wheel would need a little bit shaved off regardless of what casings were used to house the diff... You should be able to work out what needs to be messed with and what should be left alone... Cheers Bennie
  5. Hey all, Still after the info on whether 91RON is acceptable to use with these cams - I can't see why not. Another thing I was thinking of - do I need to get the followers re-faced or just run with them as they are? Cheers Bennie
  6. And Australia Looking good on the repair works... Just don't go hitting anything with that corner!! Or anything anywhere for that matter! Cheers Bennie
  7. If you ever look at upgrading to a dual range gearbox PM me as I'm keen on the push button gear knob, the vacuum diaphragm on the gearbox and the vacuum solenoids on the driver's strut tower Good looking L! Cheers Bennie
  8. That's pretty important in a build - as much as it gets in the way! As for the L series 5 speed from this ausubi thread it is longer than the EJ 5spd dual range by 65mm or there abouts... Cheers Bennie
  9. WTF?! So what's going on? Stolen? Impounded?? I know you've got me anxious for you and your subi, even though I don't know what it is I'm already thinking the worst I hope it's a simple case of paying pound fees and she's all yours again and not a stolen/burnt situation - that would break my heart as well. I'm praying to the subi gods for a safe (undamaged) return of the safari wagon! Bennie
  10. That's looking totally awesome! Top effort... you should be proud! Cheers Bennie
  11. And it saves heaps on fuel and energy used for driving! I'm saving about 1L per hundred km on cruise compared to using the foot... Cheers Bennie
  12. PM taza on ausubi for his foz VIN, but I think that's a 2001 model, still the 2L that you're after though. What I think they mean by "they do not interchange" is "We're just covering our arses so nothing gets put back on us" as we all know the subarus are like lego. You just have to know what bits you need and what bits you need to swap out to match the first bits you need Clear as mud?? Cheers Bennie
  13. Yeah if you don't have the proper equipment or a mate that's got the gear, then it'll be a difficult process. I'll get on to a mate who's done it before, I've only read about it and know that it needs to be done for these final ratios with the L series low range. When you drop it all in it's pretty apparent what needs work done... Yes it would - case internals are pretty much the exact same for the front cases. There's a couple of differences such as the low range light which I forgot to mention The EJ use the selector fork to trigger the low range light via a switch that is mounted directly above the fork - the fork has a tab on it to push the button. The other real difference is the bellhousing design for the different stud pattern. The only real downer about this is that you have to use the adaptor plate and worst of all the EA clutch setup - which should probably be beefed up = more $$$s needed... Cheers Bennie
  14. Thanks GD, that's great to know! Cheers Bennie
  15. Yes but if it is outside the adjustable area then it won't work... everything has a limit, I want to be within the limiting area, not outside it! Cheers Bennie
  16. Oh-o... What have I started now?? :D Very true as the engine is worked in its torque range meaning less revs for the same momentum build compared to an NA that would rev higher to get the same momentum built up... That's the raw basic idea anyway. You just need to drive it with a light foot - once you plant it you can kiss your fuel economy goodbye! Cheers Bennie
  17. Another thing I should have asked is can I still run with regular (91RON) or do I need to run premium (98RON)? Cheers Bennie
  18. Propane aside - what have people found to be the best ECU to run the frankenmotor with cams - the 2.5 litre ECU and wiring or the OBDII 2.2 litre ECU and wiring? This thing sounds like it's going to be off its tits once its going! Will be watching this thread Cheers Bennie
  19. I'm just throwing this out there as you're looking at going for FI. Do what you want with this idea: Ever thought about a supercharger? A toyota SC12 or SC14 would be a great upgrade to the EA81 especially if you're going with FI! Advantages are boost off the line, you can set it up so that the supercharger is on or off via a toggle switch on the dash if you get the unit with the clutched pulley. Not meaning to throw a spanner in the works for you. It does seem like an interesting build. I'd be keen to see some pics! Cheers Bennie
  20. Watched and commented Cheers Bennie
  21. Or reverse is dead... Drain the tranny oil and see what comes out with it. Any metal bits will tell you that something's not 100% internally. I hope for you that it's a dodgy linkage, but if you can get 5th no problems I doubt its a shifter linkage. Cheers Bennie
  22. You don't need to do that. It's all about learning here Cheers Bennie
  23. Yeah mate!! The only thing I can tell is different is the front of the weber that's poking out to say a quiet "hello, I am under here!" Good stuff. Also, I'm not sure that the air intake will change much of the note from the engine, you might notice less intake noise though... Cheers Bennie
  24. Anything with the push button on the gearstick is SINGLE RANGE ONLY as Vegablade has already said. Over here these were only available in pre '87 L series wagons and were 3.9 ratio I believe. The dual range gearboxes from the same era were also 3.9 ratio. Post '87 I've never seen a single range 4wd and the dual range gearboxes are all 3.7 ratio. So make sure you match the rear diff to that of the gearbox or your subi will do weird things/break stuff when you engage 4wd. You still haven't told us if you have an auto 4wd or a manual 2wd. I say the manual 2wd as you'll need the rear subframe, diff, drive shaft, swing-arms with 4wd hubs (should be on the subframe already), moustache bar and mounts to make it all work. If you had a 4wd manual you would already have the single range if you're looking to go to dual range... The auto 4wd will already have the rear end you need, but probably not the matching diff ratio of the manual gearbox. Cheers Bennie
  25. Love your attitude! Sounds like a good way to be headed, if not for the tyres certainly for the choice in bigger brakes you'll have open in your options! Yeah I'm pretty sure that the SVX didn't last long around here - maybe 3 or 4 years if lucky! I'll keep an eye out for the OBDII - any easy way to work out if it is OBDI or OBDII? Cheers mate! Bennie
