el_freddo
    153
  1. Not tried this. Be very careful cutting open and working on used fuel tanks. Boom boom if not done correctly! Cheers Bennie
  2. Sorry, a 1.5 litre EJ? Power?? Sorry, couldn’t help myself. On a serious note, have you checked for codes from the ecu (if it has one)? Or looked into the coolant temp sensor? If it’s running a dizzy, is there an issue in there? Cheers Bennie
  3. So your conversion uses the coil wiring from the brat or the donor loom? Is the fuel pump powered through the beat loom or the donor loom? It should be powered by the ECU which takes its triggers from the optical dizzy from the donor vehicle. If this is kaput, you need another dizzy. I have no idea how to check these things Cheers Bennie
  4. As per here: link dropped to keep it tidy - I’ll reply in there with my question about your setup. Cheers Bennie
  5. Lucky mate! My mum had the same issue in a Range Rover classic coming off a freeway. The throttle wouldn’t release from cruise and she put it into a ditch where she went flying out the other side. This landing released the issue with the throttle and she was able to pull the vehicle up. Damage: shock! Front diff housing was bent and one king pin mount stretched by at least two mm. The rear of the chassis was bent when the rear bar contacted the ditch when the car dragged its arse through the ditch after the front end started up the other side. Bloody scary! Glad yours was an easy fix and not a major issue Jono!! Cheers Bennie
  6. Probably not. Why not just run a surge tank? Cheers Bennie
  7. Are the diagnostics plugs under the dash still connected? (If this model still has them) All the best with finding the fix. I hope it’s a simple one. Cheers Bennie
  8. If your old ones have a hex nut on top of the tube then you can rebuild them. Chasing seals then become an issue. Cheers Bennie
  9. As carfreak said - not bolt in. Some custom mounts will be needed if it fits in the cavity at all. Cheers Bennie
  10. EJ swap it, slip the stock drivetrain under a bench in “storage mode”. EJ swap can be reversible if you do it properly. Cheers Bennie
  11. I found the image of what I did with the angle change I was talking about: https://imagizer.imageshack.com/img401/9123/p7281486.jpg This was over ten years ago and I’m still running the same engine mounts. The EJ18 flywheel won’t make a difference, it’s still the same diametre. It might be lighter though. Glad you got it sorted! Cheers Bennie
  12. I found the image of what I did with the angle change I was talking about: https://imagizer.imageshack.com/img401/9123/p7281486.jpg This was over ten years ago and I’m still running the same engine mounts. The EJ18 flywheel won’t make a difference, it’s still the same diametre. It might be lighter though. Glad you got it sorted! Cheers Bennie
  13. Do a starch on the forum or using google. There’s a full write up about it from what you need to how to do it. Cheers Bennie
  14. I’ve not had this issue and I’m running the EJ22 with the EJ flywheel and clutch sandwiched in front of a hybrid EJ gearbox. My difference is that I’ve got some wedges under the engine mounts to “correct” an apparent angle change between the engine crossmember mount face and that of the EJ engine mount angle. Cheers Bennie
  15. Hmmm... interesting that you didn’t get the NA MPFI. Those turbo boys would’ve been hard up looking for replacement heads when needed! Cheers Bennie
  16. You’re after a 4wd rear disc setup. The2wd rear disc hub won’t fit the 4wd. Everything else is basically the same. The 2wd backing plate is only different in the hole for the bearing to pass through. The key is the 4wd rear disc hub. Cheers Bennie
  17. I can confirm what @ferp420 is saying about rear strut length - the 2wd unit is longer than the 4wd unit. As ferp said, this is due to the 4wd unit needing to clear the CV joint of the rear shaft. The 2wd unit has the lower strut/shock mount directly behind the rear wheel axle. As for adjustable struts, the came out on series 1 of the L series, and we’re dropped for fixed height struts on the series 2 - but they are interchangeable. Cheers Bennie
  18. Problem is that the Aussie market is a BIG place and freight isn’t cheap over long distances. We don’t see the L series in yards anymore, even the Gen1 Liberty/Legacy is had to find. @ferp420 - 25 spline diff stubs are also found on the manual NA MPFI EA82. The auto versions is still 23 spline. Cheers Bennie
  19. Try the factory L series unit or rotate the thermostat housing 180*, make an elbow piece to marry to the factory hose and use a small piece of hose for the gap between the adaptor piece and the thermostat housing. The factory L series upper hose would be way easier though! Cheers Bennie
  20. Welcome to the forum! Bit of a stance nation fan? Cheers Bennie
  21. Hmmm... touring wagon, could be either! One way to do it is to slip an inner CV joint as far as you can and count the splines. It’ll be 23 or 25. Or look at the fuel outlet pipe at the fuel tank to the fuel pump, if it’s 10mm the vehicle was EFI. If it’s closer to 5mm, it was a carb unit. Or if you’re running a surge tank, you probably have a originally carb fed EA82 touring wagon on your hands. Cheers Bennie
  22. It’s more than likely a carb unit originally. Mis your wagon a touring wagon or a DL with the flat roof? If flat roof it’s definitely a carb unit which means 23 spline count on the diff stubs. Cheers Bennie
  23. Geez mate, it’s not Facebook with its millennial instant gratification! This forum is quite friendly, is very active for a forum these days and many members have a lot of knowledge that they’re willing to share. But if you’re going to wallow around in self pity you’re not going to get far on here. In your current situation I know that’s an easy thing to do. I was referencing your second post in this thread. Welcome to the forum Dusty. Have you got a link to a thread about your EJ conversion? Cheers Bennie
  24. Welcome Raynman, I’ve put a set of Repco units into my brumby. Not as good as OEM but the best aftermarket units I’ve come across so far. Cheers Bennie
  25. You might find you’ll get more replies when posting in the 90’s to present sub forum @ElliottAugust Don’t get me wrong, there will be some stez buffs in here, but being specific to your vehicle’s setup I reckon you’d get more specific replies in the other sub forum Cheers Bennie
