okie bill
Everything posted by okie bill
  1. Different option oops already posted. Sorry Bill
  2. I'm sure you have thought of this, but whatever you do, Keep track of the original motor. A car with that much history should be kept original or have the ability to be restored to original. Bill
  3. Betcha there have been lots of full sized ones trade hands for less. Bill
  4. Texan, you are exactly correct. The only axle I ever changed, I put together like your drawing, then turned it 180 degrees before installing the pin. Bill
  5. Drill out, tap, Heli-coil and replace 10x1.25 exhaust stud holes... Re-stud (now I have more then one per side ) and install new gaskets using the brass nuts the new stud kit came with.....Now I have Brass nuts Don't they clang when you walk?? Bill
  6. 86GL-10 you are my hero. Taking your car apart in the dark with a flashlight to help a board member is above and beyond. Now a question, my Brat doesn't have that spring, but the hill holder is hooked up, and has a pretty substantial looking spring. Shouldn't that be enough? Bill
  7. When you mounted the left blinker did you make a good ground? Are the bulbs all the same? Bill
  8. http://www.ultimatesubaru.org/forum/showthread.php?t=118248 Bill
  9. Did you find your problem? Guy on my MC forum chased one of these for a couple of weeks. Turned out that he had capped his bowl vent. Bill
  10. One question, then I will let this die a natural death. How does a Hitachi carb "wear out"? What goes away that can't be rebuilt? Just curious. Bill
  11. Try pushing in or pulling out slightly on your ignition key. Mine is really picky as far as the chimes go. Haven't gotten as far as the lights yet. Bill
  12. As we say around here "Y'all please don't get in a pissin' contest." I am enjoying both sides of this conversation. Please review the first sentence in this thread. My planned 1st step in improving my Hitachi is to replace it with a Weber:brow: Now according to Bonvo and Dirk in Bonvo's adapter thread over in the historic section, at least some EA61's and EA71's came with 306's with mechanical linkages. Dirk I'm sorry I called you an Aussie Bill
  13. I'm still trying to figure out what I have, remember my motor came in a basket. I'm assuming a 306-XX, where the XX tells me more than the 306. My motor included reman heads which were painted a silver color. The carb is the same color, and the machined flat spot on the float bowl where I assume there should be some numbers has either been painted over or sonic cleaned. No numbers. Is the "race Hitachi" streetable, or does it just want to run flat out? I saw a post by an Aussie talking about a mechanical secondary. Is this a different Hitachi or just different linkage? A small carb is not much of a concern. Look at my age. I got past 1100 double pumpers some years ago. I guess I need a book. Any recommendations?? Oh, and I already have learned something. It's spelled Hitachi:D:D Bill
  14. +1 on wanting to see the Pics. I can't Bill
  15. EvilDead, Info on your photograph? Not the car, the photo. Equipment? Filters? Notice I didn't refer to it as a pic. Did you do that on purpose, or was it an accident? Good photo either way. Bill
  16. I have a line on a new Weber which was purchased for a Beetle and never installed. May be free but benjamachine's thread re: high altitude, and skishop69's post about filling and drilling jets has me thinking. In the process of the weber conversion why not first try to improve the Hitachi? I crawled around under my 87 BRAT the other day and couldn't find the cat or the O2 sensor so I'm thinking my feedback circuit is already kaput. If I'm thinking right, pitching the feedback selenoids and about 10,000 vacuum lines will make it run rich, so I would need to do the same as benjamachine. Am I thinking right or do I have it backwards? Those Hitachie jets look like they might be removable with the carb still mounted. Are they? Has anyone tried converting from vacuum to manual secondary. Sorry for the long post Bill
  17. "You can only do better with another Subaru." Let me see if I can figure out how to make that a sig or tag line Bill
  18. Good responses, but how am I going to use them to convince my wife that I need another car? :-p:-p It only snows enough around here to worry about maybe twice or three times a year. The locals have the attitude that "If God put it there, He can remove it." About two or three days after a good snow is the worst driving conditions. Packed snow turned to ice. I think the best deal for that is studs, but can't justify them for two or three uses a year. Sounds like I need to try the BRAT.
  19. Not only is this my first Subaru, but it's my first 4WD vehicle of any kind. I know my 2WD F150 is pretty useless in slick conditions, no traction for the drive wheels. So, I was wondering, since what 4WD does in the BRAT is send power to the axle which has trouble pushing the F150, is there going to be enough improvement to justify getting this cool little car out in all that crap? Maybe I need a rusty or beat up wagon for wintertime Bill
  20. This would be really really strange. Should show up when measuring neg. side voltage drop. http://ultimatesubaru.org/forum/showthread.php?t=128521 Bill
  21. Before I knew about the spacer trick. http://ultimatesubaru.org/forum/showthread.php?t=126184 Bill
  22. The shops around here won't guarantee that they won't break the used glass. new glass, they will be responsible for breakage. Used glass, if they break it you're just out $50.00. Bill
  23. Still trying to get the models correct. The red wagon parked by the water. Is that a 1st Gen Legacy? Bill
  24. Top front of the right case half. Kind of hidden by the vacuum advance. Bill
  25. Oh, you might as well replace the front seal while you have that pulley off. Bill
