12
Everything posted by Subie Gal
hi guys. 03 OBS has completely different rear top hats vs an older model impreza as far as the impreza line strut tops? 03 is the same as 02 and that's it. but... i do believe these to be damn near identical to 96-99 Legacy rear tops i've yet to compare them side to side, but believe them to be the same. really though, the only way to find out for sure is to try it any manufacturer would be very smart to offer 1/2 off to the first guinea pig OBS as sponsorship so that they know for sure what works and what does not.... Jamie
We're gonna be on TV! We meaning... myself and my rally team, SubieGalRacing (see: www.subiegal.com) the show: Street Tuner Challenge this episode: focuses on the Treeline Rally A southern Californian rally, Treeline Rally coverage/footage will be broadcast as part of the Street Tuner Challenge Program airing TOMORROW. WEDNESDAY 8/31 - Pacific Times: 4:30pm, 7:30pm, 10:30pm and again THURSDAY 9/1 at 6:30am visit: www.speedtv.com to check for your local listings, dates, times Great exposure for rally in general AND for A GREAT RALLY in itself! Jamie Thomas ****----****----**** www.subiegal.com www.jamie-thomas.com 2003, 2004 SCCA NorPac PGT Rally Champion 2004 Western States PGT Rally Champion
i was lucky mine expired at 56k and was fixed under warranty a new shortblock will run around $1600. - $1700. - that's just for the block Really, you need to get the car inspected for specific damages if it's just head gaskets, well maybe $1200 - $2000 (parts and labor) and you'll be back on the road DOHC's are found in many early 99 model FORESTER, LEGACY & IMPREZA it was mid year before subaru switched to SOHC good luck Jamie
you must be new welcome. i work for subaru i dont tend to make random guesses earliest listing for replacment parts for STi begins with STi production date 10/2002 this would mean the first STi's off of the production line would have been stamped 10/2002 have other questions. let me know. have fun Jamie
my 99 Legacy GT did the same thing (DOHC) h.g. failure and cyl #4 cracked/gone replaced the entire shortblock best thing to do is just get it fixed now, before it gets worse i can nearly 100% guarantee you you've got bad h.g. what other issues you will find? i cant say. but keep driving the car, and it will worsen Jamie
fyi that group (little car trader.com) is located in the Seattle, WA area met up with the owner/operators by chance yesterday Jamie
I will promise you, it's the throw out bearing. and if you dont fix it? it's going to cost... basically, when a throwout bearing has gone bad, it is no longer riding flush - it's now wiggling a bit (cricket noise) and over time, this will wear down on the "snout" and likely create an irregular, rough surface bingo... damage is done.... at this point, even if you DO replace the throwout bearing it is still going to wiggle, and repeat the previous symptoms. there's a sleeve kit from subaru that can be used to fix it if the damage is too fargone the only other alternative...?? a new tranny case so change that throw out bearing before it's too late Jamie
Really, it's common to any late model Subaru you've got to learn how to drive this aggressive MT the car is LOADED with torque and not meant to go slow you have to learn to feather the clutch learn to feather the gas easy on. easy off. it will take you some time to get used to but eventually you'll get it sorted out or you'll get a chiropractor for your neck injuries Jamie
