12
Everything posted by Subie Gal
i averaged 23-25mpg in my 99 4EAT GT... checklist before traveling: check air filter fuel filter need swapping? check all fluids (washer, brake, AT, and coolant) check tire pressures and tire tread check windshield washer blades (need replacing?) need an oil/oil filter change? (if not you will after the trip!!!) have a safe trip! Jamie
aftermarket alloy links will be noisy... and likely create 'interesting' handling (snap over or understeer as they are sooo stiff....) Noltec makes endlinks for your car, but based on your post, i dont think those are what you'd want. seems to me you are best off getting new OE replacments... OE endlinks are good, but yes, they can be a wear item. They allow the sway bar to sway, thus eliminate harsh movements. up to you but here... is the link anyway Noltec Alloy endlinks here <--- hope this helps. jamie
P0122 - throttle position sensor circuit low input symptoms: erroneous idling engine stalls poor driving performance reading over the diagnostics in the shop manual... if it's not the sensor it could be the wiring from your computer to the sensor -could be the harness itself, or just the connector -could be the contact in the computer definately sounds electrical and a real pain to chase down i dont think they're lying to you... i think this is just a tough one to find. Jamie
Oil filters
Subie Gal replied to Bajaman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
in addition you can buy your filters from an on line subaru source buy in bulk, save money example.. for a non turbo Baja/Legacy: click here <--- Jamie -
new struts
Subie Gal replied to bridorf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
excellent prices at www.p-s-t.com good luck Jamie -
aftermarket clutches = shudder and chatter only way around it would be to swap to an oe style clutch the 97 outback was not known to have a clutch shudder issue. only the newer impreza wrx's were complained about and remedied with a new replacement clutch best to find out exactly what they put in there but know, beefier the clutch, harder the pedal and the more shudder you will have Jamie
if indeed you need new calipers... buy the part and learn to swap them yourself. replacement calipers (piston/boot) are quite expensive for this car - about $180 each side... so yeah $550 is not too far off. if you havent noticed any sticking there may or may not be a real issue? buuuut... on the other hand, sometimes the boots can wear down on the calipers, and yes it's best to change them... for safety's sake. it's not 'that hard' to do this yourself with simple tools. sheeeesh i hope this helps. but i'm not sure it does?? Jamie
This is the first annual Puget Sound Adventure Rally & Import Car Show Date: July 24th 2004 Location: Renton, WA ***checkpoint volunteers needed*** - contact: jamie@subiegal.com Event: A TSD-Poker Run Rally (limited to 50 cars) and Import car show afterwards (open to ALL imports! everyone is welcome!) Brought to you by: Subaru Western Region Sponsored in part by: Walker’s Renton Subaru & Eastside Subaru Misc Details: Date: July 24, 2004 Driver’s Meeting: 9:30 AM "Rally" Start Time: 10:00 AM Car Show Start Time: 1:00 PM Entry Fees: Rally $25.00 (includes BBQ for two) Car Show $20.00 (includes BBQ for one) Rally route Start Renton; mid-point Kirkland; finish Renton Poker Cards (in a sealed envelope) to be picked up at each designated stop. Rally to be formatted in TSD with times and routes specified. Separate prizes to be awarded for rally drive and best poker hand. PDF flier file download here: http://www.subiegal.com/images/misc...er_rally_r2.pdf register now!!! 50 spots available for the poker rally portion http://www.subaruwest.com/pugetsound_forms/puget_rally_form.asp car show portion register here: http://www.subaruwest.com/pugetsound_forms/puget_carshow_form.asp this isnt my 'gig' - it's brought to you by subaru, but I am assisting in spreading the word All imports are welcome! Not just subaru..... thanks and hope to see some of you there!!! jamie
putting the car into 2WD will not help your gas mileage much if at all. basically, with that many miles the AT transfer clutch/drive may be beginning to fail... so yes, basically, you may indeed need a transmission rebuild.... definately sounds as though it is beginning to slip based on your description. and yes, it's quite an expensive repair sorry! best of luck to you Jamie
nah... it's not a climate thing it's a design thing i live in seattle... temps cannot get any more mild than Seattle... and mine went at 56k and i cannot tell you (numbers too many) how many repairs we've had on this item at the local dealerships... nice theory tho but not applicable to this particular issue Jamie
Engine type
Subie Gal replied to ascus4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
what is your vin number? http://www.ravensblade-impreza.com/techdocs/vin/vin.jpg Jamie
