Everything posted by subaru_styles
Project RX: Update w/problems *edit* problem found see last post
hey tex..at least you didn't do this on run with a fresh motor..
good deal?
ditto on that..since the engine is allready out of the car replace your seals, and timing belts,... you could also maybe port or mill your heads, get cams, etc while its out get a little more HP
Weber swap instead of fuel injection?
well after owning 2 spfi motors, putting a free flow cone filter will help alot..some people disagree with me. but after i put my old intake on my coupe, i noticed a difference
good deal?
well i just wanted to make sure you didn't have an EA82 or something..I'll let someone else chime in reagarding the motor as im not that familiar with the justy. but im am 90% sure it will fit as there were no major changes to the justy during it's span,
good deal?
well first question ... is your car a justy?
adding fog lights
now you have a dual purpose bumper. It'll be great for when you have to take a s**t in the woods
Got a new toy for the coupe!
correct me if im wrong but they were only avaolable on the 85 and 86 4dr rx's.. i believe it's leaters outside, and a type of suede(sp) in the middle.. oh I forgot, they have height control and a 3 position lumbar support
they were from an 85 4dr RX and no. I'll pass on the $20
got a RX rear shock question..>.corky??
do the 85 rx 4 doors have the special dampening rear shocks? and if so can someone post a part # for the unit(tokicos right?) so i am able to check if they are real or a stock replacement from another ea82.
well as i was in the junkyard getting a seatblet clip ( so i don't die) i came across a sight that made me yell out in joy..it's one of the reasons im glad to have a credit card.. i found the most MINT set of checkered RX seats.. only one little tear, bolsters are tight and foam is like brand new..i franticly ran to get a wheelbarel (sp?). hoarding the car all to myself I removed the seats in record time. looks like im more in debt. but hey they were only $30 for the pair!
Megasquirt Info
maybe this is the route i need to go with the wagon???
Anyone need a carfax??
ill resend my request..
Tire Size for RX Turbo
i used to run 195 70 13 on my wagon.. the coupe has the cheapest tires on it..155 70 13!!!
The last hope....
wow. first my wagon, now yours...
I want some MUD
sorry, it just sounds funny when you say it aloud 7+2=9
Essential thread for new users
hahah i think only jwx noes whats going on... i personally like my retro 50's version.... DIACMA
i got one for caleb.. how about DIAF?
Just got my first car today... And other assorted fixing fun.
yeah, when i got my wagon I found a dead body inside!! j/k
Changing Transmission Fluid DIY
since tranny fluid is not changed very often i would suggest spending the extra $$ and use some Redline oil.
here's my story, and how I got another car.
well i found the mirror plate and sprayer at a yard plus the corner trim for the windsheild for $2 however my alternator just completly went out tonight...
Rear seat question
are backs to the rear 50/50 seats of a coupe the same as a wagon?? they look exactly the same, but i dont have two to compare.
thats the same problem with mine..last time i was in eugene we had it running for a little. fumes were coming out my breather filter and it was purkalating <--?
EA82 Upper door panel interchange?
no they do not. as far as the top part of the front doors go.. the 85's had the side mirrors mounted to the door, the later ea82's had them mounted in the window part. they are different. ..i learned this the hard way when i replaced one of mine..i had to dremmel out a long chunk off the 85 one
who's intersted in steering wheel adapters for the EA82
i wil find out prices in a month..they more ordered, the cheaper i can get them.. Edit by shadow: Message Board searchers, the apaters for EA82 cars are not available, but it has been discovered that Legacy or Impreza steering wheel adapters are compatible. This should allow you to mount any type of steering wheel you like to an EA82 car.
EA82 axles and XT6 axles. What are the differences?
just to add..the axle is beefy compared to the ea82 unit
