subaru_styles
Everything posted by subaru_styles
  1. yeah that adjusts the hight......but you said money was an issue.....so I would not use ground control as they are EXPENSIVE!!!
  2. i think that would be me........get the lowest struts and some adjustable coilovers..... I would stick with find some with 350lb springs for front& rear
  3. hey tex i got a Q for you.....were did you get you'r scoop from? I found a *fiberglass* one on eribuni's website....when i it looks like it came from europe but the damn thing was ABS plastic!!!! wrote emails to eribuni saying the missrepresented what the product was and that i was pissed and going to hunt them down and beat them up...........minus the beating and hunting lol.......any way that led to nothing with them....let me know
  4. hell yeah!!! gonna get a steering wheel with buttons on it for my smoke screen and missiles! tex- i need to change... that I thought they were R1's but there HP racing.....look the same... anyway the were for a 2000+ jetta....i used the 450lb spirings in the front.... and the350lb in th rear......for the rear i did NOT use the top cap as the hp coilover springs were the same NEARLY diameter as stock..you could go without using the adj bottom perch too as they comfortly sit in the shock plate but then you cant adjust it,,,,,the perches slide rite over the rear shock onto the plate....for the front there is a little ring of metal you have to grind down on the strut....no biggie
  5. scooby if you wan to use a subaru wrx momo wheel you'll have to drill it for the momo adaptor patteren..***not the same as a standard aftermaket momo
  6. go gor the impreza shell!!!! you can pic them up for a couple thousand
  7. yeah chase.......welcome aboard
  8. the MOMO pattern is the best to have cause sooo many othe manufactuors use it
  9. it's a different style of strut....P.S. did you stop at wells fargo
  10. front struts from an impreza will fit.......rear.... no way!
  11. F%*^!@%#& ...................ok i've called 22 stores across the country to see if any of them had momo #7303 still in stock...AND WELL...................I end up with nothing:boohoo: if, anyone can get me one or has one. I would be in great debt to you!!!!!!!!!!!! i need it
  12. hey this weekend in bend i saw a 90-92 white turbo legacy sedan with wash. plates and full roll cage inside.....figured whoever that was.......... was at the rally X
  13. yeah I figured that the hosings would be slightly different to hold a bulb other than an 9004 in europe and japan........anything else?
  14. I was wondering if there is any diferences in headlight housings/bulbs,interior parts, or whatever etc... with the usdmEA82 and the JDM or EDM cars
  15. is anyone going to make a DEDICATED WCSS6 website???? with all the info so subaru fans can go there to learn details about the show???
  16. Im not gonna bother right now, as its not my car....hehe
  17. I used the 3dr RX ones because they're white like my brothers wagon
  18. nope..... the mirrors are the same just different mounting
  19. hey tex- i had used the 2wd xt6 struts in the front..and lower struts in the rear..also added a set of thoose adjustable coilovers.... ................................HAVING THE STOCK SPRINGS SUCKS!!!!!! my car, especcially in the front, would use the majority of the spring travel at normal speeds during sharp corners....tires would rub the fenders!.........words cannot explain the difference with the new springs...haul major rump roast!!! go 3x as fast and never rub its amazing... lOVE IT!!!
  20. just a note for all.......I had purchased of set of white RX mirrors for my brothers 88 gl-10 wagon....and............... the pegs on the mirror DO NOT line up with the holes on the door.... just so you know:D
  21. so far I got 7 people......just a note you DON'T have to use a momo steering wheel...there is a ton of companies that use the momo adaptor...ichibahn, isotta, etc........
  22. I dont have a problem with cooling....my 2 sub amps are Kenwood eXcelon 401 mono blocks- if they ever get too hot(which has happen one time on a 8 hour trip) the top pannel automaticly slides open a built in fans kick in----it never has shut down once, even during DB drags......love thoos amps sooooo much
