14
Everything posted by monstaru
i don't get it,am i in a time warp?somebody help,.i've fallen and i can't reach my ,ummm,ummm,sense of time or something,damn i lost it.:-\
Check out this old BRAT workhorse!!!!!
monstaru replied to SuperBrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
blasphemy,i'm no where in that pic...... -
thats sweet chaz.10 horsepower for the xpploration.i gotta get down there.brian
looks good galen,see ya in the pit next year,oh wait, i mean,really in the pit:grin:
he has some type of backer under it,i thinnk he used a piece of particle board or something like that.just find a piece of wood that will fit under there and not leave a huge bump.think outside the box danny.....
WCSS8 Mudpit Video (everyone)
monstaru replied to TheSubaruJunkie's topic in Meet n' Greet. Your USMB Welcome Center
wow man, i need to go faster.i need to jump.and it was killer of you to make that video.cheers, brian! thanks man,my daughter 'll love it. -
42Motorsports coverage of WCSS8
monstaru replied to Yukonart's topic in Meet n' Greet. Your USMB Welcome Center
damn,monstaru looks good in that photo.can you e-mail me some more of her if you have them.my daughter would love to see them.cheers,brian fleshtone75@yahoo.com -
what brands do you guys use?i am obviously not a newb, so i am pretty sure they are warped.all mud cleaned ,and i am still shaking like a madman.before the show bad noises,did full brake check.all clear,obviously could not check rotors except for heat checking and what not.pads seem to have even wear,seem to have evn wear.i guess it is time to replace the whole brake system.once agian,what brands do you guys use for rotors?which are trustworthy?what aboput calipers?
what do you use?this last front set was midgrade from napa and i fear are warped after 6 or so thousand miles. what do you use?and what brands are they?and what performance stats have you gathered from them?cheers,brian
wow,who is that damn good lookin guy sittin on the fence in the 4th pic?
Big Thank you for Zap and Ken,and crew
monstaru replied to sparkster58's topic in Meet n' Greet. Your USMB Welcome Center
ya'know.all i have to say is...damn ,i hope you guys had fun.this was my first show.i appreciate the appreciation,really i do.but i did not do anything i would'nt have done whereever i was.people are stupid and they need wranglin.i guess i'm a natural wrangler(haha,i just thought about the corral)anyways,i am sure that i was loud and stupid and all kinds of things.and forthright and ,and,and.hey if you guys need a cop,i love ************ing with people.(shhh)anything i can do to help from this side of the mountain.hey ken,your daughter is one tough girl,really.good job mate.i hope mine turns out as well.and next time you have a gut feeling,follow it.then you won't have to leave and return hours later:)zap,hopefully next time we can actually bull************ a bit.and a huge thanks for first run.that was killer.i was hella nervous about that the entire ride down and was able to relinquishmy fear to the gods'o'ru.cheers,brian -
start at your base tunings and move up from there.
My car has an unfriendly tenant
monstaru replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales...
we had a pet onvce.he just hung out in the corner.we fed him whatever came along and he got bigger and bigger ,until one day he was just gone.it lasted ofr about 3 months.cool and creepy at the same time.it is nice to commune with a creature that you usually find despicable.hard,but nice. -
Mudpit Videos are here!!
i'm sad.good vids mate,hope mine pops up .i need to see the playback for my improvements!cheers,and thanks for taking some shots:grin: b -
huge hijack,me too.glad to see you made it home mate. see ya next year.
I should first say thank you so much to everyone who has been helping me with my GL I just got. All question in regars to a 82 GL 4x4 4spd 1) Must I remove the hub nut to pull off the drum?yes 2) Is the Hub Nut 32MM?36 3) E82 has some rubber piece you can remove to adjust(loosen) the brakes I assume this is not so with the E81?no, 3)I did my front brake pads and the pedal is non exsistant. Is there a way to test a master cylinder if my rears appear ok and after a bleed?check your hillholder for leakage,especially if you have already bled 4) Is there a certain pattern to follow when bleeding? 5) My brake fluid cap should be off during bleeding?not unless you are adding fluid. 6) On the back of the front calipers is a rubber boot. What is this for and is it ok if it has pin holes?probably the pivot mounting bolt,get a new boot 7) The brake line nut that screws into the caliper has a fluid hole. Should this match exact to the hole in the brake line?it should line itself up 8) I want to replace my bad half shafts. What needs disconnect? Brakes,Hub/Ball Joint etc,shocks? half shafts are in the rear.your cv's are in front.very common procedure.search for it. 9) Besides removal and install of half shafts is there anything to be aware of before starting?? 10) My reverse gear grinds often should I worry or take this as a sign of other future gear problems?adjust your clutch and be nice to your tranny,it's not a truck 11) Does early subaru boxer engines have that distinct sound like EJ boxers? (only heard with exhaust modifaction) 12) How often to you change your diff and tranny fluid?do it now,by the time it comes around again you will know 13) How hard is it to change a clutch in an E81 for a fisrt timer?no better way to learn more about your car,and doing your cv's 14) Is there a FAQ or write up on doing a clutch install and half shaft install?yes,search 15) I ordered a Chiltons and Haynes manual. Is there a more comprehensive manual?how to keep your subaru alive 16) Can you buy an altenator rebuld kit? get a gm alt 17) Can you buy a caliper rebuilt kit?yes 18) Is there any replacement parts that are very scarce?your dash,cover it 19) Is there any common problems with the stock ignition system? 20) I can get a full donar car with an 2.2 for only 200 dollars. Would you do it?i will if you tell me where. Again thanks so much if you have helped me with this problems. I could only imagine how many times these get asked.
i have been trying to find a pod like that....none of thos ea re wrecked around here yet.
see ya next year hippie.
cheers guys,hey styles...next time i won't need axle pins! :headbang: ta hell with ya you hippie!
cheers guys,i appreciate the efforts and hope that i balancedd out for you guys personally.as for anyone else,we can always giv'em concrete slippers. ya need anything let meknow.cheers,brian -
The positive side of WCSS, the fun stuff.
monstaru replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
cheers mate.maybe i can come over and go on a trail run with you guys.i'll even air down my tires. it was great fun meeting all of you whom i did not know.and next time,jerry and i have some things to show you.(imagine a brat zap....)he'll be done first.however,great show,great folks,hate to be an ********************* ,but a few deserved it in my opinion.ken and i a re finally square and i feel good about meeting everyone and definitely feel like part of the family.cheers,brian -
thanks dave,cheers to ya.loved your new rigs.brian
WCSS 8 Identifier
monstaru replied to WheaT_BeeR_MaN's topic in Meet n' Greet. Your USMB Welcome Center
um, no,who are you again?
