idosubaru
344
1997 L is an EJ22. There are no exceptions unless the engine was previously swapped - unlikely given the scarcity and cost of EJ25's in the past. L & brighton models are EJ22. www.cars101.com I'd install a gates timing belt kit soon. they're cheap on amazon for belt and all pulleys. 97 is an odd year in the US - usually the newer style tensioner but sometimes the older style. EJ22's don't have headgasket issues.
is it the tick of death?
idosubaru replied to lostalfos's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Woah - $500? That seems high but I guess $150 part and 3 hours at $100/hour? I'd install a new timing belt kit while you got the thing apart replacing the oil pump. Only $70 or less for both belts and all the pulleys. The belts have to be removed to replace the oil pump anyway - so it's zero labor. Water pump maybe as well, those EA/ER pumps aren't the most reliable pumps ever made. -
hmmmm.....the efficacy of diagnosing a noise we can't hear? your description looks like TOD - comes and goes, varies wildly. that's standard TOD. lower end knocking won't go away like that. ah the rattling - the marbles in a can while you're driving up a hill? that's common and largely benign - downshift if you're lugging the engine too much. that's not TOD though, you can have the rattling and no TOD. -
any 00-04 legacy or outback lift components will lift them. SJR, HiGuys and others on here build them in 2" and 4" flavors I think. there are 1" strut top spacers available, baja turbo springs are a little stiffer maybe pushing you another 1/2" and you can get bigger tires. King Springs are often suggested but i personally wouldn't spend high prices on a wear item you have to leave on the vehicle in the future. In my eyes they are by far the lesser option of them all...and expensive.
www.cars101.com - are those cars supposed to have premium? i don't think they are. an engine is either designed for it or it is not. otherwise there's no benefit. (unless you're going to crack the code and plan on advancing ignition timing manually yourself to push the limits?) I never run premium. I have tried on ocassion, i think my EZ30's are "recommended premium, but not required" and notice zero benefits, even when towing loads well in excess of the towing capacity. Without any physical reason, I see no need to run it personally.
+1 valve covers, very commonly leak on any vehicle with age and Subaru's are particular prone to it and have two valve covers (twice the probability) instead of 1 like some vehicles. no doesn't require lifting engine. remove various hoses/wiring in the way remove COP's remove valve covers R&R gaskets need a 10mm ratcheting wrench. generally best to replace spark plugs then too - they're $100 for a set but easily replaced with the valve covers off. annoying with them on. as to the coolant loss - if there's no bubbles in the overflow and no overheating then you may just have a leak somewhere. keep it topped off.
you better not put that sweet rust free, southern, cheap, EJ22 outback on here - someone will go get. have i bought a Subaru from Texas before? yes. if it passes basic inspection - major engine issues, etc. Buy it. It's about the best engine you can get, particularly in a situation where money is tight. reliable, cheap to maintain, noninterference.
So in summary - depends what the OP wants exactly - if it's just HG, what brand, and entire gasket set. For Fel Pro Advanced is cheaper. That's the most commonly recommended non-OEM gasket on this forum for Subarus and what was mentioned earlier. If you buy smart it's only $15 and change for Fel Pro from Advanced. Advanced ships as well, order online, free shipping over certain amount or with various coupons. With Advance - there's the chance you can get it the day of - they can get nearly anything the next day - which would be my guess with an EJ22 headgasket. Until recently I would be surprised when I saw a Subaru around Canton, so yeah up there good luck! OP is in PNW so might have good supplies. In the end, Rock Auto has zero chance of getting you the product that day or the next. I rarely do entire engine gasket sets for a variety of reasons but there's multiple ways to skin that cat if the OP is interested. ebay shop for cheap kits, buy the HG you want, or rock auto for a full kit.
I'd lean towards Gates or Subaru as well unless you can verify a good quality belt. The Gates kits on Amazon are inexpensive. As to the car dying - if it's doing it when your foot is not on the gas pedal that is usually the idle control mechanism. 1. clean it on the vehicle 2. clean it off the vehicle 3. install a used one (clean it first) - they rarely fail so this is a great and inexpensive option.
You're talking 40 or 50 mph? At interstate speeds I can set cruise control at 70mph or 80 mph and it retains that speed. Set it on the flat stretches though, setting on incline or decline is less consistent. Secondary roads here are too winding (or unmarked, or gravel, or unmaintained, or potholes....LOL) for cruise control. I might get a chance Friday to drive our automatic, I'll try to find a stretch straight enough to run cruise at a low speed.
front pad change - who undoes h,brake adjust first ?
idosubaru replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i've never done that on front ebrake XT6's. install new pads and go and the ebrake mechanism adjusts itself. lousy pedal feel could be fluid or sticky caliper pins (extremely common here in the rust prone parts of the US). -
What?! Sloooow down (pun intended)....6 people think this is normal to gain thirty miles per hour down a hill? Am I misreading this? Sounds way off to me, none of my automatic Subarus do that and I live in the mountains. 2002 H6 automatic, it holds fine down mountains at interstate speed....is it maybe slower speeds that don't cooperate? How steep? How fast?
Get the gaskets from Subaru when you're getting the water pump? Onlline dealers are like 20% cheaper than locally. Or get them from any auto parts store, buy online and use a discount code. You can pick up common parts locally. Rock Auto isn't nearly as good as it used to be and is more expensive in this case, as it usually is. $23.79 + shipping $25.99 @ Advance Auto Parts Advance Auto gets way cheaper if you shop smart: $20.79 with 20% off (P20 code) online code (which advance always has available - Rockauto only ever has 5% discount codes) $18.19 with 30% off (TRT30) - minimum 50$ order which two headgaskets meets $15.59 with $40 off $100 (TRT41 code) (which is almost always available) and creative buying Huge difference - Rock Auto is $53 and advance is only $36...or less if you buy other stuff. And you can pick up the advance auto part stuff locally, select that option online. I generally add a few things I know I'll need like antifreeze (you'll need for a headgasket job), sealant for oil pump, shop towels, head lights, wipers I'll need later to get to get the higher discounts. $100 of stuff for $60, I do it all the time. Rockauto has great prices so it's worth checking. And some things like wipers, caps, rotors, brake clips, pins, boots can be dirt cheap - i look there for those odd ball parts or when local looks really high. I wouldn't use their cheap "service grade" no name brand stuff for important things like pads, caps, and rotors. They're notably cheap grade. Some cheap pads work fine, but can last like 1 year.
