external HG leak?
idosubaru replied to efseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you describe that a little more - did you see that in oil fill tube, when draining oil, on the dipstick, or under the engine/crossmember? Also what vehicle - 1998 Foresters have the Phase I EJ25D and 1999+ Foresters have the Phase II EJ25, those two engines have distinctly different failure modes/symptoms. "external leaks" only applies to 1999+ 2000+ (and 99 Impreza RS and 99+ Forester) factory installed HG's leak externally, the oil seeps past the headgasket and eventually drips down on the ground, rear crossmember, and/or exhaust like other fluid leaks in an engine. They can leak oil or coolant. 2005+ models being more prone to oil leaks. They get worse veeeerrrrryyy slowly over time. keep topping them off and they easily run 50,000 miles or more miles without issues. you can basically run them as long as your tolerance for checking/topping fluids and/or smoking oil off the exhaust allows. Nearly 100% of factory installed coolant leaking EJ25 headgaskets will be cured with Subaru Coolant Conditioner at onset. Oil leaks haven't found any cure, just replacement. *** Previously replaced headgaskets have varying symptoms and can exhibit overheating symptoms like the older Phase I 1996-1999 EJ25D's. 2000-2002 EJ25's had an extended 100,000 mile headgasket warranty. High percentage repair used by folks very familiar with these engines goes like this: 1. resurface the heads 2. use EJ25 Turbo headgaskets
Rear CV Shaft go BG9 98 outback
idosubaru replied to ScottAust's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe subaru OEM axles are robust, run them, replacing them would a downgrade. clean, regrease, reboot with Subaru boots. i've even cleaned up, regreased, and rebooted noisy axles and they work flawlessly with no noise. it would surprise me if the old noisy axles, if they were Subaru OEM, would outlast new aftermarket axles - aftermarket axles are that trashy. i have 370,000 km on the originals on a slightly lifted outback and 270,000 km on a lifted XT6 with original rear Subaru axles. and this is the norm, not the exception - it's nearly pointless to replace them. a lot of parts are far more likely to fail than the axles.
- A good place to find a used transmission for 1986 GL Wagon?
95-99 Legacy 2.2
idosubaru replied to SedanLSi95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhe's talking about modifying it, i doubt he's selling it...but i have a 1995 Legacy sedan Ej22 i'm looking to get rid of.... can't really modify it - it'll be almost entirely novelty. so the bad news is the there's no performance gains to be had, the good news is you can do whatever you want! exhaust - sure. intake - sure. lightweight crank pulley - sure. synthetic fluids - sure. lower weight wheels - sure. drill out holes in your bumper supports, discard unecessary weight - sure. you just won't see much improvement. if the torque converter isn't fully seated you'll crack the trans oil pump and need a new transmission. if the trans is a 1/2" from the block then something is in the way or not lined up correctly - the engine needs to be at an angle and lifted up some to line up. trans comes out at an angle and needs to go in at one as well. parts in the parts wanted forum here or www.car-part.com
Exhaust gasket alternative
Are you guys having issues with OEM SUbaru gaskets - they work fairly well so far for me. It is crazy how much exhaust gaskets deterioriate.
Timing Belt Kit
idosubaru replied to yblocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGates kits on Amazon are $130 for everything timing copmonent related. Subaru OEM water pump gasket. Reseal the oil pump and tighern the backing plate screws - one or more are often loose.
98 Impreza OB saggy rear..
idosubaru replied to deezul's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have a set of rear struts that are supposed to fix this - i got them from someone else but never used them. i think they're like 2002 WRX rear struts, but they have no springs or tophats. I'm not sure if you can just install your current springs/top hats on them....or.....? i'm not very familiar with suspension swap stuff.
rwd fun and lsd test
+1. at $15 - $30 each and reboot a used Subaru OEM axle, aftermarket are excellent if you relish breaking down and working on the same part multiple times.
Blown Head Gasket-- '01 H6 3.0 Outback. Yes it does happen
idosubaru replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyep, HG's. yeah these fans are really wonky and run a various RPM's due to a rather complex algorythm.
1999 outback transmission is kaput
idosubaru replied to keepemrunning's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes it could be something else. yes it could be total failure. if it's a sensor usually the AT or POWER light will blink 16 times at start up. 1. does the light blink at start up? 2. what is the fluid level sitting at? 3. is the fluid nice, new, bright pink or something else? 4. if you move the shifter lever in the cabin - does the corresponding cabling on the passengers side of the transmission move properly too? 5. does the inhibitor switch seem to be switching properly? 6. are there any check engine lights? 7. is the transmission pan dented? 8. any prior trans work or accidents? 9. if you leave it in drive and rev the RPM's a small amount and leave it in drive for 1 minutes - does it eventually go into gear? 10. if you turn the car on and off a few time and keep moving the selector - will it go into gear? 11. when you move the selector by hand - does hte corresponding selector range on the instrument cluster change? did it work great one day then the next it didn't go into gear at all? what's the story?
idosubaru replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit would seem like fans, but i've seen H6's with bad headgaskets do the same thing he's describing. when it's under those conditions pop the overflow tank and look for bubbles. not 100% telling but worth a peak.
idosubaru replied to keepemrunning's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat's a couple dollar easy fix - Auto Trans X. alternately install a used transmission, www.car-part.com might need to search around to see what other years are compatible, but should be able to find a relatively inexpensive option.
idosubaru replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXseen the exact same thing before. sometimes they can even only do it during the summer - which i don't get as the engine temperatures are rather static - due to the thermostat. they can get worse very slowly and be driven a year or two sometimes. as they get worse, they get worse faster if you know what i mean. eventually you'll start loosing coolant and need to refill weekly - then every trip. symptoms will remain largely the same and progress to overheating at idle too. core charges are usually really low - $50 for the last 2 smaller/older/cheaper 4 cylinders i bought. $200 is not surprising.
Red-Angel A/C Stop-leak?
idosubaru replied to forester2002s's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou're sure the two orings aren't leaking, very common. you used A/C orings and an appropriate size? i'd replace: schrader valves hoses (rarely fail and easy to replace so used is reasonable fit sometimes)
dropped TC bolt down bellhousing access hole......
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXright on Dave - it may have and then jiggled loose while liting/poking/prodding. and thanks fairtax -i did turn the engine and TC a bit to move things around as well.
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit dropped out, never heard it though so not sure what the final aide was. the engine lift legs were int he way so it must have fell wiithout me seeing it. lifted the engine, moved it around, ran a magnet back in forth under there.
Dropped a TC bolt down the bellhousing access hole of a 1999 EJ22. Trying to help a friend get his car back on the road tonight....this doesn't look good. I heard it jingle a lot - so I assume it went down a ways. I lifted the engine, tried looking with a light and ran a magnet all underneath the torque converter - no dice. With all the noise it made I'm surprised the magnet didn't get it... Do I really have to pull the entire engine again? That sounds absolutely miserable....
idosubaru replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com for engines jdm places like jdmenginedepot has them for $1,000 - $1,500 as well.
lsd
ECU's are a dime a dozen. Post on here, surely someone has one. or www.car-part.com LSD's are 3.7 final drive ratio unless you find a converted one. Transmissions in this era are either 3.7 or 3.9 - which is yours? 3.7 final drive transmissions can just bolt a standard 3.7 final drive LSD in place. ; 3.9 then you need to swap the LSD chunk into your 3.9 diff. it's really easy - there's a write up on here on how to do it. If you mean a newer EJ VLSD rear diff - then the answer may differ.
Rare, but sudden loss of power going uphill
idosubaru replied to bendecker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXreplace the PCV valve - that may reduce crankcase pressures and mitigate leaks. very, very easy to do and cheap. timing belts are easy - you can do a belt only in less than an hour. i almost never do just a timing belt, because it makes sense to replace the pulleys, tensioner, reseal the oil pump etc while you have access. but it's not hard at all. gates kits with new belt, pulleys, and tensioner are only $120 on amazon.
lower bolt on rear strut
jack the rear wheel up so the control arm falls down and you can use prybars/an additional jack to push and pull things in place. i would get a new bolt or chase the threads - i would imagine the threads are mangled and unusable. it's a standard bolt if you have access to any other Subarus. i think that's a 17mm bolt which would be an M10x1.25 thread bolt. same as every other 17mm bolt on the car. if it's a 14mm then it's M8x1.25, but i think it's 17mm. in general that lower bolt is easily installed - nothing to it, no spring compressor needed and you don't have to mess with that axles or rear diff at all.
idosubaru replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can sell the engine needing headgaskets, probably better if it's never had the bluedevil in it. a guy on youtube ran the stuff in an EJ25D which has the same exhaust gases pushing into the coolant failure mode. it didn't work. maybe it'll buy you a day or a month or 4. how much for the engine if you sell it to me before dumping the magic goo in it? i'll be in atlanta next week Tue-Thu if i had known sooner maybe i could have brought an EZ30 with new headgaskets in it and sold it to you/taken the old one.
Permanent FWD w/ no rear drive shaft - discussion and risks
no issues, drive it and don't worry about it. no worries about the Duty C or clutches. The clutches certainly shouldn't see any issues - they're not connected to nor is anything being driven by them, so they're not doing anything. if you're that worried about it - install the matching rear differential and be done with it. www.car-part.com or someone on here will sell you a rear diff. auto's usually have a 4.11 or 4.44 final drive ratio, maybe 3.9's were available too. 4.44's weren't available in 1995 or earlier Subarus.
Water pump question
idosubaru replied to redXTwedgie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's the headgaskets. (which can cause no coolant flow) clogged radiator radiator cap fans
97 impreza outback sport ej22 swap trouble need I need help!
idosubaru replied to kindbud42026's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsimple answer - it was a "mid-year change" so to speak. old style and new style changed in 1997. swapping the entire intake manifold is a simple work around. requires two new intake manifold gaskets - get them from Subaru or make sure the're decent, some ofthe aftemarkets are thin and cheap. what was leaking? why didn't you replace the gaskets, hose, or seals that were leaking?
