idosubaru
344
I'd lean towards the 2013 model due to the timing chain (no replacement interval). The H6 timing chain engines from 2001+ have been amazing in reliability. Still young but i'd hope for the same with the new engine in the 2013's. The 07-09 Impreza's aren't bad motors but the EJ25 has been one of Subaru's lesser offerings. Headgasket and lower end bearing failures are far more common than in any other Subaru engines ever made. They can easily make 200,000+ miles though, don't get me wrong they can be decent motors, they just have slightly higher maintenance costs and higher percentage risk (which is still low-ish). Most folks don't really make practical decisions on that low of a risk though...%2 risk instead of %1 risk...I do, but most don't. Most rather pick price points, color, interiors, performance, etc. Everyone has a different fit. I chose the H6 engines in both of my daily drivers (and cars for two friends just this year) just to avoid the EJ25. Not a bad motor but I prefer the higher statistics of the H6. If the impreza can be equally as reliable and low maintenance that would be a great engine as it can also pull off better gas mileage.
I use Permatex anaerobic on my own stuff, will use ultra grey too. EJ water pump gaskets and thermostats gaskets get no sealant, they are of a different design. But the EJ aftermarket water pump gaskets are poor quality thin cardboard like material that should have sealant if they're used, but most folks stick with the OEM metal gasket which has proved quite robust. that is a nice hit, what I would do to turn back time and avoid all the gasket scraping i've done on those!
how sure are you of this? just trying to clarify as there's so many responses and thoughts on this. ***To clarify the tire rubbing...700 pounds of people and drum set, amps, guitar, speaker - 1,000+ pounds total. With new struts (original springs) the rear sagged bad, no room between wheel and vehicle. There was a really light rubbing sound. I would have driven the 200 miles home like that but switching heavier stuff to the other side made it go away. Could it have been just something like cladding, mud guard, trim, or something benign that was out of position enough to rub under those extreme conditions? Or you think bushings more likely? I find it odd I haven't read any other threads like this. It was very clearly an issue, not like "maybe something" is happening...it was unnerving bad, so something was clearly way wrong. stock wheels and tires. how do i figure this out? should it be visually obvious? thanks.
i saw that same one, he didn't use NPT fittings though or post sizes. for $30 i think i just need to buy one.
this is one of those dinky party store helium tanks, not the industrial ones.
really, just the tires would do that? in college i would run tires on the rear until they popped or leaked...wire would be showing, watch your hands! had full size used spare, real tools/jack so i could change it out quick. never had any drivability issues even running those used slicks. had a really warn tire that's getting replaced as i type, i can't picture a tire doing that but that would certainly be an easy fix. bowling ball is a fair enough description of this too...
lugs should be good i can yank on bearings. the rears are all original. i'll check, i was yanking on end links. Fairtax said he's disconnected his rear sways and said it's barely noticeable in the way the car drives so I assumed that suggests it couldn't do what mine is doing, making the whole car slide/oscillate like that. very. i'm hoping maybe I'm overly sensitized since it was really freaky when it first happened. But - There is no noticeable problem with the old spring, maybe it was just weak but i don't feel 100% confident i pegged the issue either.
At 50+mph, the back end of my 2002 OBW H6 VDC seems to slide, when it hits a bump, a few inches from one side to the other and back again, I don't know how else to explain it, it is strange. Without hitting a bump it drives and feels perfectly normal. Had some sagging issues if I had like 500 pounds in the car (like 3 people in the back seat or gear in the back), the rear drivers side would sit so low the tire would rub. I put more weight on the passengers side to make it home without rubbing on a long trip. Without weight in the car it drove perfectly normal. I installed new struts and springs and i assume that issue is corrected, though I haven't loaded the car since then either. And i haven't driven at highway speeds since the spring replacement but it still seems a bit off in terms of the sliding issue. I yanked on sway bars and links underneath, nothing obvious. Really isn't much rust to speak of, just standard for here rust, no rotting. 200,000 miles New rear struts and springs Front struts are original (hands head in shame LOL). Anything else to look out for?
one of those helium tanks. for $30 i should just buy one, it seemed like it might be simple since i have an empty one sitting here and i'll only use it like once a year.
have a tank I want to make into an air tank. 1. need a fitting to fill it with air? 2. need a connector/fitting that acts as a valve but i can plug a hose onto is there something that does 1 & 2? I guess I can get a T-fitting and screw in a valve to fill in one and a valve/coupler/fitting to the other side? Never really messed with plumbing so unsure about matching threads and sizes and such.
use a 1997 EJ22 intake manifold with front canister so it's identical to the EJ25? The law is meaningless - how do they enforce it? How do they inspect? They're not going to disassemble the motor...so what do they do? Make it look right and be done with it, I'd do it. Most automotive laws regarding emissions, fluid, exhaust, and more - are violated by the thousands ever day. Find out how they inspect, not what is written, and fly in under that.
simplest way to proceed is to read the air bag code. there's going to be a connector somewhere and you ground one of the pins in the connector to get it to flash the code. you can usually find where online or someone here may know. older Subaru's are above the gas pedal. once you ground the appropriate pin then the air bag light starts flashing a sequence. read the number of flashes and that's your code. while it's tricky to figure out the pin that's better than guessing.
The H6's are awesome. Plan on resealing the valve covers, they need it at some point anyway. The spark plugs are way easier with the valve covers off. It takes a while but it's at least not the pain of doing spark plugs with the covers in place. The H6's make up for it by being almost no maintenance. No timing belt, resealing oil pump, cam seals, etc. The only item they have is that serpentine belt idler/tensioner bearing issue. I'm sure you've seen that and can read about it. One of mine just hit 200,000 miles and I've only done plugs, V/C gaskets, oil cooler gasket, and those bearings. That's it. My other is at 160,000 and while embarrassing i haven't done anything to it yet. mileage isn't that great - i would expect about the same at best, maybe 1 mpg or so less than the EJ25. we get 21-22 mpg for daily commuting which is 15 miles of back mountain roads and no stop and go traffic, no red lights...it's WV. it's been awhile since i've driven an EJ22 or EJ25 for the commute but i think they'd do like 22-24 doing the same. if i cruise at 55mph i can hit 27 and sometimes 28 mpg...but that only happens on one drive that i do - 3 hours one way and back sustained at those speed due to back roads with no mountains. the H6 mileage drops really quick as soon as you start using the pedal more or hitting mountains, etc. drops quickly on the interstate for instance.
look down/up there with a light? probably no way to get much visibility that way. i think i might try pulling the dipstick and drain plug and shooting some compressed air down the dipstick hole to make sure it's not 'stuck up top' or something. you could pull the axle and pull the axle stub out of the front diff- they are only retained by a circlip and pop out and pop back in. with that out, even both sides - you might have a chance of seeing it. in the end it's plastic and one would think it won't hurt the gears as long as it can't get into bearings or compromise fluid flow to them.
what does it do after that hour...does it stay at 22psi then? not sure if different pumps/gauges could differ but i'm not surprised to see some creep due to equipment, disconnect, or internally equalizing. i've never looked that intently - i just pull the vacuum and charge. well, actually i'm almost in the habit of not even pulling vacuum or using my gauges Subaru's are so easy, so far i'm batting a thousand and the a/c works just fine for here. all three of my current daily drivers are running without vacuums being pulled and have been that way for years and i even have a vacuum pump and gauges. LOL
right - leave the EJ25 ECU, no need to touch that. gotta be some CA folks here to respond. if they don't look at and thoroughly inspect (and know a lot about them) the engine they can't tell a difference. did you google it? i'm sure there are hundreds/thousands of questions like this across all vehicles for that ignoramus state.
