Exposed axle nut
idosubaru replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've never had a problem with them being exposed here in the land of rust, so you being in a lesser rust prone area would probably be fine. given how everything else rusts up here i'm not sure why they don't. most subaru wheels have the axle nuts covered via a hub cap or center cover, does yours maybe have those?
Intermittent Airbag Light UPDATE
idosubaru replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes it is, my H6 has them. i bought it wrecked and had to replace them. they are called pretensioners, they're supposed to be safe but hard to get out of - i think it's recommended to keep something handy to cut them off if in a wreck.
power steering pump.
what you're describing is done all the time to verify if something is caused by the p/s, belt, pulley, etc or to move a car around, parts car, mechanically in progress, etc. so you're golden. due to the alternator it's use as a daily driver like this will be limited.
Hello from south central ohio
that's awesome. i'd be wanting the timing tensioner and pulleys replaced with the belt, but they'll be pricey from Subaru. the pulleys and tensioner have more issues before 200,000 than i'm comfortable taking a risk on. or you can entertain having it changed before the next 100,000 miles as well, that's an option. the lower sprocket is the one that is usually in the worst condition - $59 from subaru (that's the discounted price i think).
which new axle is vibrating? axle shake down...
if there's no way, then we'll swap them out one at a time and see what happens. my XT6 has MWE axles, but my modus operandi isn't always the best fit for every other person or situation. neither is yours. i'm trying to help someone out here and keep costs down. i already mentioned my distaste for aftermarket axles and voice that with you to others here as well, i don't need encouragement or advice about that. didn't ask for advice on or need axles, i have plenty of OEM or MWE axles already. that happens after you've owned 20 or 25 XT6's.
installed two brand new XT6 axles and have the classic new axle DOJ vibrations on acceleration - is there a way to determine which side is doing it, assuming it's only one? i avoid aftermarket axles like the plague because of numerous bad "new" axles like this. these happened to come with a car i picked up, i figured these things should be good. chances are in my favor right?
Blasted ATF leak from cooler hoses under battery
idosubaru replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood call, we need to just quit looking under our cars and drive them
brake question 2000 legacy
idosubaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow, you've really gone through some brake hardware. we have poorly maintained and winterized roads here and while I have rust issues everywhere else for some reason I've never had to replace a caliper yet. brake clips i've replaced, they rust and pads hang in them. I bought 3 sets of clips earlier this week, i'm getting into the habit of just replacing the clips now that one of mine hung on rust and devoured the new pads in a few months, they're hard to clean and pitted/rusted anyway.
idosubaru replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcrack, finish up work only to find more. well one thing tackled at least.
idosubaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXactually i don't remember, i only run into this job every few years so i don't end up getting to familiar with it. that's how i know it's fairly easy, i re-figure it out every couple years. LOL i recall that being a thought during the process though....boot goes on when...? it might not matter does it - it just sits on top of the piston so you could install it after the fact as long as you have room to seat the boot in the ridge and the piston doesn't cover that up or hinder that? some have circlips to hold the boot in place and some don't (97 Legacy brighton did not, but all the others i've seen have).
prolonged T.O.D driving = check engine light!
check engine light is not related to TOD. unless the TOD is something abnormal and not "normal" TOD - since TOD isn't super technical. if your TOD is hydraulic valve lash adjuster noise - then it's not causing any of your check engine lights unless there's something really catstrophic going on that's not normal. EGR - clean the valve and lines. probably lots of EGR related information on here if you seach - but since you can't search easily for three letter words that might hinder you.
Tire Size- Big deal or not?
idosubaru replied to Paine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe way the AWD works - you can hose the transfer clutches and more (automatic) or center diff (manual). actually - you *will* cause them to fail every single time the circumference or rotations are not congruent - it's just a matter of how long and when. the circumference is what matters - most folks aren't mechanically inclined or have the capacity to figure this stuff out - so the simplest one size fits all approach is to have all tires matching. places around here typically install two new tires by putting them on diagonally on subarus - one on one side rear, one on the toher side front. i wouldn't do it, but it's done enough around here that there must be a reason. you gotta be smart but you can work around things.
idosubaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you post up a picture of know what style caliper you have, i may have a used one i can send you for like $40. i shouldn't say "easy" - good catch. it's straight forward but it is tedious at times - seating and pressing the piston in, etc. every one i've done was leaking or just preventative maintenance. if you and him are having seizing issues - there may be pitting/rust involved and that might be compromising the seal, piston, etc, issues i haven't come across yet.
Awd issue after Trans swap! HELP!!!
idosubaru replied to Mastershredder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1. final drive ratio does not match or 2. torque bind again do you know what vehicle the used trans came out of, year, make, model, trim? different subaru's get different final drive ratios. but it's pretty simple there's only 3.9, 4.11, and 4.44 for legacy auto's, so it's going to be one of those. all you need to do is get a matching rear differential to match the front diff ratio of the new trans. (this is assuming this is the cause and not torque bind - so you'll have to figure that out first) an easier way to do this would have been to swap the rear extension housing off your buddies transmission into the original. that doesn't require dropping the trans and can be done in the car, would have saved a lot of effort and not had to worry about diff ratios.
idosubaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey're really easy to rebuild. don't even have to remove the caliper from the car. 1. remove the caliper from the rotor/bracket. 2. then push the brake pedal until the piston pops all the way out of the bore. you might want to rig up a clamp or ziptie to hold the other piston in place since it's good or just do them both at the same time. have a bucket/pan ready for all the brake fluid that's going to pour out. pull the piston all the way out of the bore once it's loose. 3. clean the bore and piston, make sure there's nothing obviously wrong, and remove the old and install the new piston seal. it's just basically an oring that goes into the caliper that the piston slides past. 4. install new dust boot and clip (some don't even have clips). refill and bleed. there's nothing to it really - you're really just replacing ONE seal, the caliper bore seal, that's it. you'll of course replace the dust boot stuff while it's apart, but the actual repair is just cleaning the bore and installing that one oring/seal that just sits in a groove. the worst part of the job is bleeding the brakes, the caliper rebuild part is simple. advanced here had them in stock so they should be able to get the kit in a day or two for you.
EA81 rear air shocks?
i'm sure you already know that EA82's and XT6's had air suspension...not sure how similar they are or if any suspension stuff is interchangeable between the two?
idosubaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXor pull it apart and rebuild it, they're not that difficult to push the pistons out, clean out, install new cylinder seals and put it back together. dual pistons are going to be more but i rebuilt my friends Legacy front caliper for $3 with the kit from advanced auto parts, not much to it really. they're really simple. or yeah - just swap in another caliper, they're probably cheap and easy to come by.
is your car comfortable to drive? need replacement seat suggestion.
idosubaru replied to afterbang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlifting a car a bit helps too, i like sitting in my higher cars more than lower ones. not that i really care personally, but i can imagine having a bad back the higher ones would be nicer. excuse for a 2" lift, call up SJRlifts.com!
Heat/overheat issue
idosubaru replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck fluid level. when it's warmed up - are the fans turning on? radiator is probably partially clogged but check simple stuff first radiatorbarn.com has cheap new rads.
2002 Legacy clicking noise, what is causing it?
if it's in the rear have someone ride in the trunk/rear comparment of the wagon. it'll be obvious from back there. if it's on the front i use a temp gun. bad wheel bearings will generate more heat and that side will be notably hotter. given how much heat is being dissipated you have to take like 20 readings to get a feel for what's going on, but compare sides and one will be 20-50 degrees warmer overall. others have had sucess with a stethoscope or other similar mechanism on the strut coils as you rotate the wheel - listen to for grinding/noise. i've seen quite a few subaru wheel bearings that had no play in them at all but were bad once removed and replaced. i only work on subaru's and i've seen it so often i don't even see any validity at all in the "move wheel" check...i mean it can verify a percentage...maybe about half...of the wheel bearing failures i've seen, but doesn't come close to ruling it out. is it more successful in older vehicles?
97 imprezza L fan motor
idosubaru replied to Temccullough's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's probably just clogged with debris/insulation, remove and clean it out. they're super easy to remove, underneath the glove box area you'll see the cylindrical-ish looking area and a few bolts/screws holding it in place. you may have to remove the kickpanel if there's a plastic piece there, it's usually just barely clipped in with two plastic pieces that pop out at the top. remove that and you'll have access to the blower motor. they rarely fail so they're only a few dollars used and super easy to replace. unscrew, unplug, replace, done.
idosubaru replied to afterbang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've never been that impressed with the 95-99 era seats either but haven't spent a ton of time in OBW's of that gen. buddy of mine just looked into swapping 03 Legacy seats into his 97 Legacy and said they were not a direct swap...but i didn't see it, he just looked into it like two weeks ago. i have a spare set of 2000-2004 leather seats i could measure the mounting points on.
OEM gaskets vs felpro, and others, and who makes what
similar thing happened with Beck Arnley headgaskets....both looked different for the same part number. this was for an EA82 but I didn't use them either.
06' Legacy 2.5i engine compatibility
idosubaru replied to salle071's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe short blocks interchange, long blocks i'm not sure. make sure both have EGR or both don't have EGR. that's a common variable over the years with Subaru with little rhyme or reason as to which models/years get EGR or not. i've seen same year/model/trans have EGR and not have it. friends out west seem to see different trends than i do...regional difference or coincidence? auto/manual makes no difference in Subaru's, engines are the same, you'll just bolt your flexplate in place of the flywheel to install in your auto. properly repaired and maintained your engine is likely to outlast all sorts of other components so i wouldn't lean too heavily on that other motor unless it's a compelling fit. for the engines, yards say 2006-2007 compatible and 2008-2009 being compatible. the short blocks are interchangeable between 2005-2010 so you could use the 2006 heads and intake manifold on the 2009 engine block.
idosubaru replied to afterbang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsomeone else has a thread on here about seats and a bad back and legacy related, check that thread out. if yours are cloth, go sit in some leather seats. given the reasoning you may want to try upgrading to newer leather seats too....though i'm not sure about compatability between later gen and older gen OBW's. any 1995-1999 Legacy will be a direct swap, bolt in for you. the second gen 2000-2004 H6 leather seats (and maybe H4's too, i just haven't been in one recently) are firm, you might want to sit in some of those and see how that treats you?
