Swapping the Er27 engine in my xt6
places that auction or sell wrecked cars. craigslist works well but H6's aren't really seen often, though i just picked one up with a blown trans for cheap in excellent condition. i look almost every week and don't see them too often. ebay.
weird stereo issue.....
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks guys, 'll try to take note of AM/FM. good call JCE, i'll just plug in another radio and antenna and see what's going on.
axle for 05 LLbean Outback
idosubaru replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, use 2001+ 4 or 6 cylinder axles. avoid aftermarket axles like the plague. reboot yours or reboot a used axle. if you get a used Subaru axle, at least reboot in the inner DOJ, they typically only last a year, maybe two if you install a used axle. seen it many, many times and i just reboot them now. if you're not aware of the aftermarket axle issues, then just search any online subaru forum and read thread after thread of issues. vibrations, noises, and even completely blowing to pieces...waste of time.
98 OBW radiator swap out
idosubaru replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmost annoying part to me is just catching the coolant dumping out. otherwise it's really easy like already covered. the ATF and radiator clamps are often rusted to the point that reusing is not an option.
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXah gotcha, that little thing. the 03's have that goofy ONSTAR system and wasn't sure if that was dedicated to that or they shared, etc. guess i'll swap stereo's first since that's easy and i want to anyway and then go from there.
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've tried turning off and on everything electrical - defrost, heated stuff, seats, etc and no change at all so far. it's very consistent, does the same exact thing every time, just like it has really weak reception. not even sure where the antenna is on these things, embedded in something? the glass? thanks, got lucky. it is very nice and i like the H6. was fortunate the original local owner sold it cheap with a blown trans in great condition.
new daily driver i just got on the road, 03 H6 sedan doesn't get radio reception at my house....but all my other subaru's always have. about half way to work it starts getting reception, though crackly. is this a stereo issue or........? it also cracks out on CD's sometimes, just seems to cut out. might need to try another CD to make sure that's not the problem.
really? i guess i get confused who is where! yeah - there's multiple swapped engine XT6's over there.
1997-1999 Legacy Repair Manual
idosubaru replied to mwbean's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru FSM's. I have almost all digital copies, only hard copies i have are older 80's era stuff...i may have one newer gen hard copy but use electronic copies almost exclusively. the hardcopies i think are nice when you first start getting into stuff to have them easily mobile.
2002 leacy timin belt help! pleas help!
yeah just line it up carefully and it will stay. it's loaded by the valve train so it wants to spring out of position. once you get used to it, it's actually really easy. remove the passengers side lower timing belt idler pulley, it can be installed once the belt is in place easily and gives a little bit more play to install. get the belt around the crank and the drivers side pulley first and have a helper or use a clamp, clothes pin, or something to hold the belt onto the cam - that will prevent it from moving out of place as you go about installing it the rest of the way around everything else. once you get used to it, like i said, they go right on.
Shock fluid replacement for stiffer damping
did installation go like this: 1. install valve. 2. fill oil 3. compressed air or like this: 1. fill oil 2. install valve 3. compressed air you would recommend 10wt or 15wt oil depending on usage/climate then? i think i'd want a little stiffer too - 15wt if it could handle the winter temps here which is when i often drive the XT6.
refilling air struts with new oil thread...
great! that's it. i was searching for threads started by you and i didn't see that. thanks. since all 4WD XT6's came with air suspension we have a few air suspension threads on subaruxt.com. be a good idea to compile them all, with yours. we also have: 1. drier / dryer silica refilling http://subaruxt.com/forum/posting.php?mode=reply&f=1&t=12443 2. reconditioning the air struts 3. reconditioning the solenoids if you don't have rust maybe reconditioning air struts isn't an issue like it is out here. the strut body rusts and wears the bottom of the air bag where it attaches to the strut.
in general that rules out every single possible swap. so you'll have to define "minor". everything will require adapter plates or trans swaps to go with it and most importantly - wiring. simple solution to that is to pay someone $200 to do it for you, there's a couple folks that do it, but you have to also buy and find a wiring harness which isn't super easy since it's buried behind the dash too. so again - you'll have to define "easy" nate - i think you've seen all the swaps on subaruxt.com - there's a couple EG33 swaps, EZ30 swaps, a bunch of EJ turbo swaps.....there's a tons of them right on the XT6 forum.
OBDII code reader advice?
i like the cheap ones off ebay since i travel with them and take them places, in my work bag often, etc. if it breaks, no big deal, just buy another one. i've gotten them as cheap as $35 before. i'd buy nicer ones if i wasn't so mobile and rough on them. some ready the code only and don't tell you what it is. if that annoys you, you don't have a list of codes, will be working on multiple different kinds of vehicles, or don't have internet access - you might want the kinds that tell you what the codes are verses just the number. if you're just working on one or two vehicles, just print the lists of codes out and put them in the owners manual in the glove box and it doesnt' matter.
Duty C life expectancy when...
idosubaru replied to SubaruFred's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGD has a good point - the TCU's are very easy to swap and they very rarely fail so there's zero demand meaning they're not worth anything (they're cheap). it's a counter productive question because every thread ends up exactly the same way - tons of commentary and little, if any, real world experience. that doesn't help you. most people are going to say don't do it because something bad will happen. first they're wrong, because i've done it. second, who cares since it's already hosed!? it's a no brainer: 1. possibility of zero work and maybe needing to replace later. 2. replace now. #1 is a great fit sometimes and saves a bunch of time and money. no one has actually ever seen this cause a Duty C to fail, so that's rather good news. and i've driven a long time exactly like this, about 2 years, controlling the Duty C by a switch. if you're worried about it and dont' need 4WD - run it without the Duty C and remove the rear half of the driveshaft.
which radiator to order??
idosubaru replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXradaitorbarn.com has awesome prices. EJ radiators for under $100 shipped to your door.
there was a thread about a year ago roughly....very foggy at the moment, where someone drilled, drained, and refilled the fluid in their airstrut. i did some searching and can't find anything on it though. anyone know what i'm talking about/find it?
Knock Sensor, matched to Block or ECM?
if it's leaking oil, does their 3 year warranty come into play?
Exhaust Manifold Nuts and Studs
idosubaru replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've never even done that, i just assume they're all relatively similar and visually appear that way. but that is really good advice, never thought of it. occassionally you'll have one that mangled a bit of thread, chasing it with a tap is a really good idea (regardless of whether or not you use new or old studs).
AWD testing, Subaru Vs Others
friend of mine is a mercedes mechanic, he recently had regional recognition and was selected for a free trip where they flew his family to germany this summer to view their plants, etc. he is now driving a very new...forget year/model i don't really follow cars at all, mercedes. he got it cheap because the AWD rear transfer components failed. he said this one has one rear transfer clutch plate in it and is really weak.
idosubaru replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyears ago i used to replace them...and now i just reuse them - the stud/nut combo's just turn into bolts, no big deal. some of the ones i replaced years ago then turned into bolts too! LOL i see no point in worrying about it anymore and i won't locktite anything in place because we have too much rust around here - would probably end up stripping threads once it's rusted and has to pull the stud out.
Rear Differential Seal Leak?
idosubaru replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnice, a square for holding on the other ones! got a pipe wrench big enough to just fit on the entire flange? oh right, i wouldn't use the nut either. if you rig something up to hold it in place, it won't snap those driveshaft bolts. though you could just use different bolts and throw them away when you're done for the holding process in case you're worried about fatigue, stressing, etc, but it won't be an issue - they will hold. i would not hold one nut to counter against the pinion, but rather somehow bolt a piece of metal or wood or to a vice or something like that to hold it in place and use the bolt holes to hold it that way.
idosubaru replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXare you sure it's leaking and not just blow back from some other leak/fluid up front? i think you're on the right track. that does look like a beasty nut, though i've yet to need to remove one. i wouldn't think i'd have any problem trying some things to get it off. the flange has the 4 bolt holes in it too for the driveshaft i think, those could be used to hold it in place. a friend of mine uses his elec impact for cam pulley bolts which can be quite tight, might be worth a shot to put it on there for a minute and see what happens.
Remove or just loosen the intake manifold for HG replacement for a on 93 Legacy L
idosubaru replied to illanrob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXunless i'm missing the question the intake manifold should come off for a variety of reasons. *could* it be done without removing....yes. there really isn't much of a reason though. you're going to save 30 minutes of work but it could cost you 30 minutes...or an hour in other ways (like it already has on this post), and the likely hood of a lesser quality job. helpful to remove mostly for cleaning. the block mating surfaces need to be thoroughly cleaned for headgaskets, they aren't like normal gaskets and should be installed correctly every time - clean surfaces are a must for HG's. cleaning the block with the intake manifold in place is challenging and requires more effort than pulling the intake manifold off. you could clean from underneath if you enjoy that sort of thing... the heads to have to come out of the engine to clean them, though if you wanted to try this they could be dropped underneath. i've done it before...but it's hardly any extra work just to pull it off. it never saved me time because the manifold makes things harder to get to, harder to clean, less room, needs moved out of the way for something, and it's just hoses and throttle cables, very easy to remove. you can disconnect the minimum and prop it up out of the way or even flop it all the way back towards the windshield....but still all the same comments apply and simple to remove. but if you're the kind of person that likes the thought of it sounding and seeming quicker, then by all means roll with it! it's only a few minutes work, not a big deal either way.
Did I blow my head gasket or worse?
idosubaru replied to danbennett2u's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe heat could have compromised just about anything on a 20 year old car. water pump gasket, water pump as miles suggests are definite possibilities and headgaskets are too. probalby have to pull timing covers to verify.
