NoahDL88
Everything posted by NoahDL88
  1. Umm, I'm 6 hours and 22 minutes away, according to yahoo maps, how about you PM me, i send you my address, and you ship it to me? Cause gas there and back would be around 100 bucks, plus the 12 hours travel. :-\
  2. Thats good news. It seems like its only a problem on the drivers side, when i push in the top of the knuckle to bolt it to the strut, it was really hard to get the holes to line up, and it seemed like it was the axle that was limiting the inward travel. I guess i'll go through it again and see what i can find.
  3. I have an almost complete EJ harness sitting in the back seat of my car, i'll see if i can't get some pictures of the keep and cut stuff.
  4. Used an impact, so i'm pretty sure there all the way through :-\
  5. So, with Impreza hubs and FWD axles, i have all the fit issues taken care of, but it seems like the axles are being pushed together, as if there too long, anyone else have this problem?
  6. Get a service manual, it'll make your life infinately better. ShawnW will get it ready for you and strip it down for i think 200 bucks. Kenedy adapters makes a really good info kit for wiring, its around 25 bucks, but its worth it.
  7. Umm, yeah, eliminateing it is easy, its the 2 wires that don't have a home that are currently the problem.
  8. Could just be a dirty valve, a bad valve would give you no compression. Try some seafoam through a vacuum line, if theres carbon in there it will absorb fuel and make your HC's go up.
  9. You can drill the t-stat hole out for a nut and bolt setup, had that on my EA-82 for about 3 years, worked great. As for the EGR, if thats not sealed, that will be one huge vacuum leak.
  10. The green connectors are near the wiper motor. those will set the timing to base, from which you can set your 20 degrees BTDC does it run good when its warm? Are the timing marks on the belts all in the right spots? Did you change the fuel filter?
  11. Is your T-stat stuck open? Happened to me with a brand new one, go with an OEM subie one, they don't seem to have the problems that the aftermarket has.
  12. Theres a small coolant hose under the throttle body, that goes from the top of the block to the manifold, if thats off, it'll piss coolant.
  13. On another oil note, every oil with the dougnut and the star on the back meet minimum requirements, if you don't see both, don't buy that oil. That said, those are the minimums, your name brand oils are going to have more of a space between those minimums and what they are actually at, so after 3000 miles, the good oils, Castrol, Mobile 1 and the like will still be above the minimums where your walmart brand will be just scraping by. don't forget to change your filter.
  14. Hmm, i can't say for sure without looking at it, i'd say get a volt meter, and hook it up to the battery, and turn on all your headlights and see if the voltage drops, if it does your alt is shot. which could be your problem.
  15. Leave some innovation for the rest of us, whats next, a sealed passenger compartment and propellers?
  16. If the two wire plug is shapped like a T then thats your alternator wire, and thats rather important. Go through and make sure all your connections are tight and that everything that was plugged in is, any shiny clean halves of connectors should have a mate.
  17. A good 10W-30 like they said. i'd say away from the bigger spread oils as they break down faster and have more additives and less base oil. On the other end of the spectrum, a lot of guys run 20W-50 in the summer cause it leaks less, but it causes more harm than good because of increased wear at startup. Stay away from "high mileage" motor oils, if you stop using them, like rogaine, the leaks come back twice as bad, which will make your hair fall out.
  18. The SMJ is 6 columns by A-P rows, so its a 6X16 i'm specifically looking for the wires that go through L4 and L5
  19. Theres some really good info over on Legacy central do a search for wiring diagrams, or check out the FAQ, its near the top
  20. Ohh, it needs some parts for the hatch anyone up for a sunday run?
  21. It is in a FSM a friend has my FSM, which happens to be one of those E-bay store copies that leaves out the foldouts so it probably won't have what i need anyway The 10 gajillion FSM scans on the internet also have all left out the SMJ fold out It would be near the front of your FSM book 6 if you have a "real" copy and if you find it would you be a dear and scan it and upload it?
