Everything posted by ford'ssubaru's
HELP! Car pulls to right on acceleration...Les Schwab screw up.
I am only throwing out a suggestion to you. I am not looking at your car in front of me but if it were me I would break it down. Typical fwd cars have a shorter shaft but this is an awesome Subi so the shafts are the same length unless of course it is a Justi(i believe). So what is next... I would check the splines on the hubs them selves. I am slow to judge other mechanics (only because I am not looking at your ride myself) some things are easily missed. They may not have been paying that close attention and the splines were just barely grabbing on oneside enabling the car to still move forward. Kind of a different thought when your dealing with differentials. Here is an interesting thought. If you engage AWD does it still pull? That would be an interesting clue. Many posts on USMB on the whole spline thing. If it were me. Put the front on jackstands to ensure there are no brakes dragging and such. Love to here what the others have to say.
- Intake Gasket
- Intake Gasket
- Intake Gasket
- Intake Gasket
- Intake Gasket
WA, ID Brat Meet
Any comments on the turnnout?
1992 Subaru Loyale
Ditto
1992 Subaru Loyale
What I do is set 1 ant tdc compression. Veriify by timing mark on flywheel. Install dist at 1 plugwire and adjust accordingly.
Broken Crank Pulley
Nope, I see your in MA. Reuse it if your in a pinch or let any of us know and the next time were at Pull and Save I send ya one...
1992 Subaru Loyale
I actually know where Tulare is. Personally from Stockton. Anyhow like Eeyore said. Something is missing. There are alot of us that are mechanics that get this wrong. MilesFox is dead on target. There is an awesome thread on Timing. Reset your distributor timing. Cheers, Eric
Broken Crank Pulley
Yes, It has been that way for awhile. That was most likely done on a previoius repair by someone prying on the pulley. If I were a bettin man I would say that someone previous to you put a chain wrench around it to get the crankbolt off. You can see that somene has had that bolt out before. Go to the wrecking yard, get another one and slap it on there and call it good. Don't put that one back on. Just my advice though. Cheers,' Eric
GEN 2 front bumper build pics
Very nice job! What size is the steel?
Subaru Brat trailer
Subaru Brat trailer
Hello, Anyone ever built a Subaru trailer? I am going to give it a whirl. What do ya all thing?
broke bolt, then made worse...
Great! Keenserts or Nutsert are better easier and stronger than a helicoil.
ea82t heads
I am not being sarcasted please don't beat me up but I would love to really back way up to the beginning. Is the OP er even sure of the extent of the original problem. We could be confusing him with alot of time and money he may not need to do. I like the fact that the car has low miles. Holy cow I want that motor..... I ran my first EA82 for almost 300K When the heads went they were junk. I like the post about taking them both off and have them pressure tested. I am sure that is what Mikaleda meant. I took the heads off for the motor I mentioned off an EA82 with 160k to the machine shop and they did both for 150.00 which I was happy with because they looked good and completely resealed. Now this is just my opinion. It is not that hard to do a set of heads just takes patience.
88 DL Exxon Valdez
Love the title!
88 DL Exxon Valdez
My dad once told me that son you won't find a better car, referring to the 79 Brat that he bought new, but know one thing, all Subaru's leak, all Subaru's tick, but most important they all run and run and run. I've alway liked that.
I should of said intake but it is hard to type and drive on my computer...LOL.
This is an awesome thread!
Or get another intake.....That is also a good idea.
Naw relax bro! If you were Spokompton i'd go and help you with it so I will do my redneck best to walk you through it. The reason machine shops make so much money is because we (me included) are impatient. First of all we need to clear away, the best you can, the area around the thermostat. Then you put the small brazing tip on a torch set. If you dont have a torch set I actually did a similar thing using a small butane torch from Radio Shack. Lay wet rags around the work area. Now this is where the patience comes in. The idea is to heat up the bolt but not damage the block. Heat it up really hot then let it cool down slowly on its own. Walk away, shoot guns or something. Do this 2 or 3 times you will know when metal and the easy out is breaking down. You will need new hardened steel bits and slow down your trigger finger on your high speed drill. Slower is better in this case. Try this and have a beer. Cheers, Eric
Roof Rack?
My son did this over las weekend. Found at the wrecking yard.
88 subaru gl wagon - timing broke
Very true...
