ea82 turbo stuff on ea82 N/A stuff?
Why not just drop in an EJ22 (you can get a whole first-gen Legacy donor for about $500 or less these days) and get 135 HP without all the monkey business? And then if that's not enough you can substitute an EJ25 bottom end and increase displacement and compression under the EJ22 heads - resulting in about 180 to 190 HP. You'll never come close to this with an EA82 of any flavor. Even a dual carb or a turbo. I congradulate your enthusiasm..... and I've been involved with builds like your's. They eventually end up with some kind of fuel injection setup in the end anyway. Carbs are just too primitive and troublesome - getting them setup for doing one thing really well invariably results in reduced performance under other circumstances. FI has none of the drawbacks and many, many advantages over a carb setup. GD
EA 4EAT adapter plate for EJ engine
I've done an EJ swap to a 3AT and the flexplate was matched to the EJ pattern just like any flywheel redrill. Worked great with a standard adaptor plate. I would assume the same would be true for a 4EAT. GD
Differnces between 80 and 85I Brats
Hardware store...... 10x1.25.... GD
Almost nothing is compatible. They are different chassis generations. 77 to 81 is first gen. 82 to 87 is second gen. Complete redesign - wider, heavier, bigger engine, etc. GD
Radiator questions.
Subaru hasn't even used a metal tank radiator in over a decade. Correctly manufactured there is no issue with them. They tend to last just about as long as the brass units. Further the plastic tanks handle the expansion characteristics of their aluminium cores better and the single row aluminium core rejects more heat than a single row brass core. GD
Wanting to change my distributer, anything i should know?
Take your distributor slightly south and see these gentlemen: http://www.philbingroup.com/ They can take care of whatever it needs - shaft bushings, vac advance, pickup's, etc. Typically it's around $75 to $100 to have one gone through. A few years back when I was a broke college student they hooked me up with new bushings and a vac advance diaphram for $55. GD
Cylinder Out of Round Question??
Just hone it round again and have the pistons coated by SwainTech. They can add .004" to the skirts and save your block. GD
98 subaru legacy 2.5
Just about any of the Legacy racks will work typically. Just about all the shocks and struts you can find used will be bad - especially the rear's - better to get some KYB GR-2's for it. Pretty much all the 95 to 99 Muffler's are the same. Have to read the code(s) and go from there. Sounds like the mesh screen/pickup tube on the bottom of the fuel pump is missing or has fallen off. I would pull the pump/sending unit assembly and inspect that first - seen that happen a time or two. If you want to bring it by I'm down in West Linn - about 45 minutes south of Vancouver - about 6 miles from where 205 joins back into 5. PM me if you want to stop in. GD
That depends on what you need for it? GD
EA82 Questions
Idle mixture (ONLY idle mixture) screw is at the bottom front of the carb. It was designed to never need adjustment and is blocked by a roll-pin. It is unlikely that you need to change it. GD
3.9 diff value?
It would say LSD in very large letters. LSD's never came in automatic's. If you want to be absolutely sure - turn one of the stubs. If the other turns the same direction then it's an LSD (or welded). If it rotates the opposite direction it's a normal open diff. GD
EA81 Dual Carbs.
As noted - without the rest of the engine it's basically a nice wall ornament. Going to the trouble of fixing that twin-hitachi setup and making it work would be a time-consuming and messy task (parts availibility) when you can just build your own setup from new parts and new carbs. Just build some adaptors to mount the carbs of your choice to each head, build a coolant cross-over, and rip it up. GD
Ea82 tick of death
There's about a half dozen problems that cause this: Oil pump/seals Cam carrier o-rings Bypass valve springs Dirty/worn lifters Worn lifter buckets Worn out bottom end (rod/main bearings). Any and all of these contribute to the problem. Fixing one of them may solve it or you may have to go farther. Depends on how low the pressure is at the lifters and how much aeration of the oil is taking place due to failed seals. There is no magic bullet for lifter tick - changing oil viscocity will only result in worse protection against wear - either at startup or at operating temp depending on which way you go. Repair in a bottle has similar effects over time as it is not what Subaru engineers had in mind when they designed the engine - they designed it to use 10w30 oil. Not a bunch of additives or different weights except in extreme hot or cold climates. GD
ea81 passenger front suspension or axle
You'll just have to inspect stuff. It's likely that it needs shocks anyway due to age. That could be part of it and they are cheap. Ball joints and tie-rod ends are common sources of noise. As are axle joints when making sharp turns, etc. Those noises could be any of a dozen things - best to just get under it and start looking and prying on things to check what's loose. Swaybar bushings, leading rod bushings, rack bushings - all that stuff gets old, loose, mushy, etc. GD
3.9 diff value?
Pretty much worthless. They are common as dirt, never fail, and a real bear to ship due to their weight. It's easier to just recycle them as scrap metal. GD
anyone seen this before???
Some wagons also had them but it was rare. It's a standard 5MT D/R with a locking center diff. The low range is only 1.2:1 and the final drive is 3.7:1 so effectively if you put them in low-range they have the same gearing as a "normal" 1.59:1/3.9 D/R has when in high range. So pretty useless except on a very small range of builds (lower end of the performance spectrum and with a "street" setup) or as a platform for building special transmissions using parts from a normal D/R and the XT6 R&P to get a 3.9 final and 1.59:1 low w/locking center. GD
2 core radiator for 86 GL
They don't seem to be available anymore. Some places will list them but when people have asked them to lay eyes on the part and confirm the number of cores it's either a single core or a mis-represented EA81 radiator which are all two-core units. There was a time when you could get them - but they seem to have ceased production on the EA82 dual-core units. A brand new single core unit should be adequate - especially if you don't have a turbo model. If it's not then you have other cooling system problems besides the radiator. GD
97 Legacy engine
GeneralDisorder replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDefinitely check all the valve adjustments. Usually somewhere between 1/4 to 1/2 the valves will need new shims. Have the heads resurfaced if you haven't already. Use only Subaru head gaskets. They redesigned the gasket about 4 times so you want the latest from Subaru. GD
Engine Question
Certainly. It's been done many times. Check the retrofitting forum. GD
97 Legacy engine
GeneralDisorder replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs this a 2.2 or a 2.5? GD
Engine Question
Your Brat was never a Turbo. Turbo decals perhaps.... but definitely not fuel injected or turbo-charged. Also - if the cam broke because of a seized oil pump - you can just toss the whole engine short-block in the dumpster because it will not be pretty inside. It will be easier to just find a used EA81 and drop that in. Your best bet for more power, if you still want FI and more power, is an EJ22 swap. It will be about half as much work as converting your's to an EA81T and you'll get more reliability, and 40 more HP without the need for a turbo. GD
Engine Question
The EA81 is a 1.8L engine. They did not make EA81's that were 1.6L - that would be an EA71. If your's is an '84 Brat with turbo decals.... that *wasn't* really a turbo.... then you can't "put back" anything because it never had any of that stuff. Please take a picture of your engine bay and post it here. I can tell you with absolute certainty if it was a geniune turbo or not. GD
Subaru EA82 to Subaru EJ205
If you have to ask - too hard. GD
Going from 14" to 15" wheels
GeneralDisorder replied to Scomber's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX15's are very common and not much different in price. Your Brighton came with 14's but a GT of the same year would have come with 15's. Just lookup tires for a GT instead. GD
Starter on 06 Legacy
GeneralDisorder replied to soloz2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck with the dealer on a contact kit for it. I would probably use some form of Lithium Complex (white or off-white) grease. That is the most common thing to find in small gear drive's like starters and wiper motors, etc. Lubriplate makes some really good quality mil-spec stuff. GD
