Wheel Bearing Replacement....Quite Expensive
I've bought three of them now where (apparently) the previous owner just turned up the radio and ignored everything - on the last car the front wheel bearing sounded like the rotor was dragging on the ground, the car had massive, terrible torque bind, and the engine had been starved of oil till a rod nearly let go and the lifters had deflated. Basically the woman just drove the car till it stopped driving. But you should always address wheel bearings as soon as it is apparent that there is a problem. A week or two likely isn't going to make any difference but it's just like waiting an extra 1000 miles before changing your oil - is it going to kill it? No - but it's a bad habit to get into. GD
looking for help from the suby masterminds
Short answer - no. The computer has only a single O2 sensor that controls mixture. It has to be installed in the exhaust stream of all 4 cylinders. Thus you cannot operate a *true* dual exhaust and have the computer work correctly. An H pipe will not work for the same reason - you are not getting a true sample because the flow can bypass the sensor. It MUST go to a collector first where the sensor can sample the exhaust stream and THEN you can run two pipes out the back if you want. There's no benefit to it though. GD
They typically last much longer than 64k. Being it was already done once before on the same wheel..... I would be looking for a used knuckle with good bearings. Pretty easy to find - try www.car-part.com if you can't pick one up from a yard yourself. I would be concerned that the knuckle is warped or damaged and that no bearing will last much longer than the 40k you got from the last dealership replacement. Better to just pickup a used complete knuckle for less than $50 and swap out the assembly - takes less than an hour. You can definately have it replaced - but finding a shop that is willing to actually go through the hassle of doing it correctly and also doing an ID mic. of your knuckle's bearing pocket to see if there's warpage, etc..... much harder, more expensive, and at the end of the day not really beneficial. Just figure the knuckle is bad and replace the whole unit with a good used part. Always cheaper and in most cases will last as long as you need it to. This can be an $800 repair, a $300 to $500 questionable repair, or a $100 repair with some help from a board member or someone from craigslist that needs some side work, etc. Harbor Freight has a "front wheel drive service set" (their cheap version of a hub-tamer) that includes most of what is needed to change out the bearing yourself. It cost's $80 and a new bearing is $35 and a few bucks for seals. I have done it using only what is in that set, a cheap two-jaw puller, and hand tools. The one I did using that setup now has 40k on it and no trouble at all. The owner drives 160 miles a day so I'll get to see how it lasts compared to these monkeys at the dealer that can't seem to install a bearing to save their life. GD
ongoing EA81 axle troubles
Typically the cone washer has to be replaced - sometimes the hub as well if the splines have been damaged or the conical section where the cone washer seats. You can't effectively file or grind either the cone washer or hub to correct the wear either - the MUST be replaced with undamaged parts. The loss of metal affects the way they interact and will not allow them to grab the axle shaft properly. Rarely the damage will be so severe that the axle has to be replaced as well. That is typically not the case though as the axle splines are much harder than the hub splines. GD
ANY Ideas? Dead '88 GL
The carbed car's do not have an ignitor (well - they do but it's in the distributor and entirely different). But the SPFI/MPFI/Turbo's all use the same ignitor on the coil bracket - as you surmise you have to replace the entire bracket as the ignitor is soldered to it in a way that it cannot be removed seperately without risk of damage. It's just a simple transistor that acts as an amplifier/relay for the coil ground signal from the ECU. GD
Piston Damage - Fixable?
GeneralDisorder replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX251/253 blocks will take damage - but from what I understand the "interfereance" on the 25D is valve/valve due to the DOHC system. In other words the pistons still don't reach high enough to tap a valve..... GD
GeneralDisorder replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake a small whet-stone to those couple little marks, have the cylinders power-honed and it will likely be fine. The rings don't come up as far as those marks on the chamfer of the liner. And no - dont use a cracked piston like that. That thing is scrap metal. GD
lowering boost pressure
EA81 carb: 8.7:1 EA82 carb: 9.0:1 EA82 SPFI: 9.5:1 EA82 Turbo: 7.7:1 Off the top of my head. Pretty sure those are the numbers though. GD
rip subaru
I doubt that clean lake water would corrode anything. You might have to change the gauge cluster just because it will be pretty wet inside... I would put it back in operation. I pressure wash electrical all the time - it's not the water that gets it but rather the salt in those states that salt roads, etc. A compressor and a blow-gun is all you need to make that thing work again. And of course buy some new interior. Buy it back for $500 and sell the car whole for $1000. It's worth it - that's an easy $1500 profit for someone with an afternoon and some used interior bits. When I worked on industrial machinery - it was common practice to STEAM clean elecrical stuff - I would tear down electric induction motors and steam clean the windings with soap, etc. Dry them as best I could with a blow gun then put a fan on them for a couple days. We had a Meg-Ohm meter for checking to see if they were dry. Never once had a problem. This was accepted common practice at our shop and we worked on 480v 3-phase motors in the 5 to 500 HP range. 12v DC is not going to get damaged by some lake water. GD
Yes - crap in the tank is entirely possible. I've fought that with my '69 truck. Similar symptoms. I would be more inclined to suspect the ignitor (coil bracket) than the actual coil. Subaru coil's are pretty tough - I've never actually seen a confirmed case of one failing. Mostly I've seen aftermarket coil's fail after some idiot has thought it needed to be changed. GD
No spark on one side of coil pack
GeneralDisorder replied to murphywd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck for proper power to the coil - there are two sides to the coil so there are two leads that have to be powered going into the coil pack. I'm pretty sure that's how it works. They might be powered off seperate fuses..... Did you try a third ignitor? I've seen them fail where only half the coil would fire. GD
rip subaru
Why are they selling it? You don't do that much work to then lose your rump roast on it by selling it for $1500..... I am always VERY wary of people selling swapped cars - IMO you should never buy such a thing from "man off the street" - the level of competance of those who swapped it is as important as what they swapped and what conditions it's in. That ad has precious little info on what was done. Sounds like billy joe bob threw in a used 2.2. Probably butt-spliced rats nest of wireing.... there's no shot of the engine bay so it doesn't look like they are too proud of the work..... I'm going to go out on a limb here and say you should probably avoid that mess. GD
85 Brat leaking front diff seals
Punch mark both the ring and the case to indicate the current setting. Count the number of turns as you remove and when the threads get close to letting go apply outward pressure and make a seccond punch mark on the case indicating the proper location to re-engage the threads. It's pretty straightforward. GD
89 GL-10 turbo wagon questions
$2000 tops. Even with the low miles - its an EA82t and its old. It's going to need a bunch of rubber and maintenance..... and its just not at all desirable. GD
ea82T rebuild kit
You need a kit for an IHI RHB5. GD
Stereo wiring harness - GONE! help!
GeneralDisorder replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is an easy fix - you just need a "reverse" wireing harness. Here's a whole bunch: http://www.google.com/search?q=Scosche+su03rb&rls=com.microsoft:en-us&ie=UTF-8&oe=UTF-8&startIndex=&startPage=1#q=Scosche+su03rb&hl=en&rls=com.microsoft:en-us&prmd=ivns&source=univ&tbs=shop:1&tbo=u&ei=Ff00TfGTPIX4sAOGvLiCBg&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CD8QrQQwAg&biw=1823&bih=814&fp=5fc6e4edb7c346ed GD
Still having some RPM issues *PLEASE READ/HELP NEEDED*
Feel the burn of the EA82T yet? :cool: Yep - now you know why we hate them. You are already on engine #2 and the "I can't make it run right" tantrums are starting. Growing up and learning the hard way sucks. You should really listen to those of us that have been there and given up on that POS. A wise man learns from the mistakes of others... A smart man learns from his own mistakes.... A foolish man never learns at all. GD
Need help connecting the temperature control cable
GeneralDisorder replied to chrisw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes - there should be like a plastic clip that the cable "slots" into IIRC.... Maybe look closely..... broken off? I haven't seen that happen but you never know.... GD
There should be an IAC adjusment somewhere that *can* be changed. At least there is on the SPFI's..... I thought there was on the turbo as well.... In any case you really shouldn't be messing with settings like that if it ran fine before you took it apart. If you haven't removed any of those devices then something else has changed. Better to find out what has changed and work toward a solution than to just turn screws and move hoses in a futile attempt to make it function. GD
The EA82 was intended to be a 2.0L Engine!
The Lloyd ancestory of the Subaru engine has been talked about on this board before. I've known about it as far back as when I joined this forum back on EZ-Board. It's not really discussed much though. Mostly it's brought up when someone thinks that Subaru is somehow related to the VW boxer. They are completely different animals though and being water cooled the Subaru pushrod EA series has much more in common with the Lloyd. But yeah - descended from the German design..... back when the Germans actually made stuff that wasn't *too* complex. GD
- 19 replies
- 1
- ea
- loyale 2.7 turbo
- engine
- jeszek
Tagged with:
You need to have them all rebuilt. At $4.50 each.... why would you bother shipping them just some of them? GD
My Tranny
GeneralDisorder replied to Suba9792's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know - it wasn't ever meant to be pressed like that. I doubt we can use it anyway. A puller probably would break the hub. It's THAT stuck. This one is no joke. My goal is to save his OEM axle at this point. I think heat will be used . GD
Probably due to their supreme rareity there. It's still not common to see them here but was more-so when I was driving mine around. Been a few years. I did get approached on occasion but nothing like what most people here talk about. GD
- 19 replies
- ea
- loyale 2.7 turbo
- engine
- jeszek
Tagged with:
That is very interesting. It does make sense though - since the EJ was developed as a 2.0 from the beginning. They eventually came to the conclusion that it was going to take a redesign to keep the fuel economy down I suppose... Really cool how he was friendly like that - having obviously never met you. I Wish people were like that in the US..... people here have no time for being friendly and having lunch with someone they just met off the street. Too bad.... GD
- 19 replies
- ea
- loyale 2.7 turbo
- engine
- jeszek
Tagged with:
Strut price opinions
Mostly people that get hurt are hurt because they compress the damn springs too much and then the compressing tools slip off or fail. I remove strut tops fairly often without compressing the spring first at all. With the strut assembly removed from the car there is very little compression taking place. They usually "pop" about 2" or less. It's kind of a let-down how little they do when you just zip the nut off with an impact . Disclaimer: No one should actually do this. GD
