GeneralDisorder
    440
  1. The emissions devices on the EA82 SPFI can be summed up thusly: 1. PCV system. 100% neccesary for proper crankcase ventilation - do NOT touch 2. EGR system. I eliminated it, but you either have to keep the solenoid, or replace it with a resistor to fool the ECU into not throwing a code. 3. EVAP system. I eleminated this as well, but again same story with it's solenoid. Be prepared to smell fuel as without the evap, the fuel tank vapor will just vent under your hood. 4. Catalytic converter. Cut hole, gut cat, weld up hole. Replace heat sheild for a stock look that won't cook your axle boots. What will you gain from all this? Absolutely zilch. I did it because I was putting the SPFI on my EA81, and didn't want the complexity of the hoses, and trying to locate a spot for the evap cannistor. GD
  2. Those without the raw muscle (not saying you're a wimp or anything), or those of us who prefer to do things the easy way get one of these: It's a "hand impact" of sorts. Works amazingly well, and cost's less than a decent burger (about $10 or so). GD
  3. I have several extras, and I can test them before I send you one. $10 plus shipping and I'll send you two of them.... GD
  4. Yeah - the really stupid part is that you don't have to take that part of the knuckle loose for an axle swap. There are about 2 dozen ways to do axles, and taking the strut loose at the knuckle isn't the easiest either. I've never done it that way - a lot of folks take the three bolts on top of the strut off, but really all you have to take loose is the sway bar link, and the inner lower control arm bolt. Hey - at least you found the problem, and it's not the suby's fault. GD
  5. They RARELY fail. Test it first - it's easy to test with a multi-meter. GD
  6. Subaru got 120 HP from a 1.0L Justy engine. The full 1.2L would probably make 140..... but it's at about 11,000 RPM. The Justy actually has 3 valves per cylinder, and a good power to weight ratio stock. It's got better power to weight than an EA81 vehicle by far. The EA81 hatch would actually be a downgrade (unless you are talking 4WD, and off-road performance) You have the only subaru made for the US market with a transverse engine. There is nothing that will go in there without massive fabrication, and that was the only engine offered in the EF series for the US market. GD
  7. Yeah - the new carpet idea is good - also gives the possibility of adding more insulation, and sound proofing. I'm sure there is some good stuff to be had. If you go that route tell us what you find... GD
  8. My experience is that the carpet is dependant on the type of transmission more than anything. On the 4WD, the shifter area is different as there is carpet between the shifter and the radio console, and there is not on the 2WD 5 speed. If you find one for an EA81 automatic they are similar to the 4WD's, but the rubber portion under the pedals may be different. Carpet is divided into front and rear under the seats. Obviously the rear carpet for the Brat is not the same as the rest, but you could probably *make* a rear brat carpet by cutting some off the wagon or hatch rear peice.... GD
  9. I've tried the CB route, but after busting several antenna's (thick brush and tree limbs, etc), I've come to the conclusion that the portable citizen band radios are more practical. Someone in the groups with a CB is good for emergency's, but the small handhelds are better for trail use as you can use them even if your battery dies, and out of the car while extracting vehicles, etc. Just my experience. Plus they are dirt cheap. Fry's had Motorola's (cheap, small ones) for $9.99 a pair... GD
  10. It's not the whole rear end - just the trailing arms. Making your own mounts would be.... dificult. There are rubber bushings in them, and so forth. And you would need welding equipment to put them on. You could use a die grinder and take the mounts off the other arms and weld them to yours. That's what I've done on my EA81. GD
  11. The rear sway bar was stock only on the RX. There were smaller ones that came on some of the FT4WD GL-10's and other "turbo" models, but some do not have them. The mounts for the rear sway are brackets welded to the trailing arms. But these mounts don't exist at all on cars not equipped with the sway bar. You will need both rear arms to install one. D/R in itself does not mean it will or will not have one. It's very hazy as to how they were equipped - but mostly they were on Turbo models - just not all of them. GD
  12. Yes - I know what you mean. The Justy took over for the EA81 hatch line as the "compact fuel saver", so there was no "need" for a short wheelbase EA82. As most hatchbacks are two door's, I think it's probably best to say that the "hatchback" is a sub-catagory of "coupe". So in a sense we are both right in different ways. GD
  13. Yeah - thought of that - fluid is actually about 3/4" above the full line. Front diff oil is full. Not sure what overfilling would do, but that's the condition it sits in now. I suspect it may have been a crappy rebuild. Car was also sitting for about a year and a half on a side street. When I would take off there was some "chattering" from the trans, but it didn't seem bad.... on retrospect that may have been the clutch pack complaining. I went to turn left up a hill and got about 15 yards up the hill when it just lost all forward power. I got it to move about another 10 feet or so, but now it doesn't move at all. Good thing the woman was in my lifted wagon behind me. Here I was blocking traffic (diagonally over two lanes!) with a car that looks semi-post-apocalyptic, bad tags, no bill of sale (I've got the title tho), and I'm smack in front of the police station. I got out of there REALLY fast. I switched with the woman, hooked up a tow strap, and yanked it home. Had to put the wagon in 4 low to pull it up that hill from a dead stop.... fun, fun. GD
  14. Interesting - fastest I went was 35 MPH or so.... but I'm told this trans was "rebuilt" not long ago. They may have weakened it. So basically it will be FWD now? I don't really care, I just want to be able to move it. It's a parts car anyway. I wanted to know if changeing the front axle out was likely to restore my power to the front wheels at least. I guess I'll do that then and drive it to it's new home in the scrap yard. GD
  15. Here's an interesting one. Picked up a 93 Loyale yesterday with a "terrible grinding noise". Found that one recently replaced front axle is a 25 spline. So I pulled it and drove it home slowly with just the rear wheel drive. About 3 miles from my destination, after driving some 15 miles or so, I lost all forward power. Had to tow it the last 3 miles. When I put it in gear, the transmission shifts, and the speedo shows I'm going about 15 MPH with the front axle off. The stub on that side spins. When I put it in 4WD, the speedo changes speed a little, but I have zero forward movement from the rear end. Rear diff, axles and driveline are fine. So what gives? These things don't have some viscous clutch pack that I burnt up right? They just are 50/50 4WD like a manual trans when you push the 4WD button right? So what did I burn up in the tranny? GD
  16. It may not be so much that the "anomilies" you describe are not there. Lord knows I've seen stranger things.... but more the way you communicate them in writing. We are quite often having a very difficult time understanding your posts. I'm guessing that if I were to speak with you in person, and actually see what you are refering to, we would come to a more mutual conclusion about it's source. You definately know something about what you are speaking, but maybe just don't know the right technical terms for such things? I'm just guessing here. Not trying to offend you, and I have only the highest regard for vetrans (having been a part of the military myself) - heck, I still think you may want to address some ground wires. If the ignition system shorts through the clutch cable, through your foot, and to the door panel then you definately have either a plug wire problem or a grounding issue with the engine block. Stuff like that can happen as the ignition system runs at around 40,000 volts, so it's possible for it to jump distances like that. The wheel thing..... well I can't see how that could possibly be electrical related. Sounds more environmental to me. Salt or other chemicals perhaps used in paving or other road work. The rubber in the tire would preclude all but the most insanely large voltages from passing, and the lug nut is not the shortest path to.... anything. GD
  17. Just cause you worked on aircraft for the military? My father was a C130 mechanic in vietnam - shop forman etc. He had similar responsibilities.... still can't work on a car to save his life. He's a good cabinet maker tho. As for electrical and electronics - I have an ARMY security clearance to work on 120 kilowatt jet-turbine generators.... you know - the ones used for the patriot missle system? Being a 52D generator technician doesn't mean I know *everything* to do with high voltage eletrical systems, but I know my way around. GD
  18. He's in holland tho.... You might just have your radiator rebuilt - it's not real expensive. About $60 around here, while a new one runs about $120 GD
  19. Actually - the term "hatchback" derives from the first hatchbacks of the 60's. Such as the 66 Plymouth Barracuda... The definition has nothing to do with the "angle", but the fact that the rear glass is part of the "trunk lid", and that the rear seats fold flat, and the rear cargo area is accesible from the back seat. All these qualifications are met by the EA82 "3 door", so it IS a hatch. The EA81 coupe has a trunk (or boot if you like) in the traditional sense - seperate from the rear glass, and the rear seat does not fold down, nor is the trunk accesible from the back. What we are actually lacking is an EA82 coupe. It would be a sedan looking thing with only two doors - but they never made one. GD
  20. 160k? That's pretty low on the EA81 spectrum. Parts that fail? Surely you jest..... axles *maybe* but only because the rubber in the boots is old. Ball joint - again old rubber on the boots. The stock Hitachi (or perhaps carter/weber) carbs are some of the worst/most complex known to man... as luck would have it they usually run ok with the exception of the choke/cold starting, and are easily replaced with a real Weber or (my favorite) SPFI from the later GL/Loyale line. Biggest issue by far in your area is going to be rust. Other than that you need to watch your oil pressure. If not kept in check, the engine will suffer main bearing and rod bearing failure easily. 160k is about perfect for a new oil pump and seals. They are cheap ~$65, and only four bolts on the front of the engine. Well worth the investment and 30 minutes it takes to change one. Change the sending unit if it's leaking, and it's a good idea to take a real pressure reading with a mechnical shop guage to verify. 1) The "chaser" is the canadian name given to the EA81 Hatchback.... you canadian or something?? Anyway, yes - same engine. No "chaser" (or any EA81 Hatch) ever came with an EA81T stock. The EA81 Turbo is rare - it came in ONLY the Brat, Wagon, and Coupe, and only for two years - 83, and 84. There was exactly two EA81T hatch's made - both for the movie cannon ball run. One was destroyed, and the other is in the possesion of some automotive education institute in WA state. What you probably heard about was a member here on the board (rguyver) that put a turbo and SPFI on his "chaser" hatch. It had NOS and second injector at one point too, but the engine was a stock EA81 with 8.7:1 compression. 2) Engines that will "bolt in" - EA81, and EA82, and turbo versions of same, but a LOT more work is involved for turbo's. 3) Engine mounts? Well the EA81 and EA82 use the same mounts, and are similar to the EJ mounts - the EJ22 will fit in the chassis by slotting the holes in the engine cross-member about 3/4" outward - but it will NOT bolt to the transmission without an adaptor plate. Not sure what you mean by "turbo mounts" as far as I know there is no such animal. 4) Fabrication? Well depends on what you are doing I guess. I'm still not clear on what you want... 5) The EA81 trans isn't meant for anything over 100 HP really. They are good transmissions, but if you start putting too much torque through them stuff will break. The reverse gears are known to snap with too much power.... but the 5 spd from the EA82 will go in without a lot of trouble and they are more rugged. The race versions of the EA82T were around 170 HP Extras.... look at the brochure scans on this site. No idea on the safari racks - everyone that has one on this site that I know of either built their own, or had another member build it for them. Newer dash - not possible without major work and probably have to be custom or from something other than a subaru. All newer models are wider. Impreza seats are easy - really ANY seat you can imagine is possible. Usually some fabing/welding is involved. I have late 80's Isuzu Impulse seats in my Brat - very simple almost bolt in with those, but they are notoriously difficult to find. I have legacy seats in my lifted wagon - comfy. I would find another hatch with the correct window in it. Lexan is a pain unless you are racing and absolutely have to use it for regs. GD
  21. The truely amazing thing, and the part that will really blow your mind, is that no one else understands it either. That's what happens when you use your imagination (and possibly supplemental pharmaceuticals) rather than a good book.... people have no idea what you are talking about. I'm seriously sending a linky to this thread to a couple EE friends of mine for a good laugh. Rock on. GD
  22. If the check engine light is something silly you don't want to fix (Purge solenoid, etc) then just pull the guage cluster and take the bulb out. Or even easier, pull the plugs off the ECU, find the ground wire for the check engine light, and cut it. GD
  23. Yeah - all the ones I've ever encountered were 2 row. Also the EA81's tend to cool a lot better than the EA82's, or they just last longer. People who have done EJ conversions report the EA81 radiator is plenty for the EJ... GD
