Everything posted by nipper
Outback H6 Questions
nipper replied to ettev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChains are supposed to last the life of the car. Old chains used to start giving up around 160,180,000 miles, so i am interested in seeing when/if they start giving up. Generaly if your buying a used car with over 100,000 miles dont be shocked that it may need a few grand put into it the first year (tires brakes wear and tear). Usually i expect to put that much in any car i buy over 80,000 miles in the first year. Sometimes i dont sometimes i do, just something to keep in mind. nipper
long travel axle solution? mostly for the front
You have my attention now... nipper
98 Legacy OB torque bind
nipper replied to twilson542's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can do all the AWD work with the tranny in the car. nipper
Will it hurt the Eng/Trans?
nipper replied to vincentmoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell the thing is if you do proper double clutching your not going to hurt anything. Your transmission has synchronized gears, which is what did away with the need to learn double clutching. Now if you get a trannny with tired synchros then it will help. Unfortunitly you sort of need a transmission that has no or tired synchros (or a truck with a stick) to know your doing it right. Now clutchless shifting on the other hand is trickey and a talent, and should be practiced on someone elses car nipper
nipper replied to twilson542's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think then its time for an AWD rebuild. Sounds like you tried everything. nipper
engine noise
nipper replied to hebrewhammer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles? Spray the acc drive belt with some water and see if the noise goes away. if it does it can be the alt/ps/idler on that belt. When was the last time the timing belt was done and what was changed with it? nipper
torque bind??
nipper replied to oldbike49's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTB seems to be in season right now. There are three people asking questions about it. http://www.ultimatesubaru.org/forum/showthread.php?t=83921&highlight=read+transmission+codes nipper
nipper replied to twilson542's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ultimatesubaru.org/forum/showthread.php?t=83921&highlight=read+transmission+codes read that first. i had mine fixed at the dealership. I actually found the price to be quite reasonable, as i do not trust transmission shops. nipper
why do they make timing belts so hard to install?
nipper replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDamn inflation, that used to be two cents.
Trans light blinking
nipper replied to bikeweek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi never heard of the procedure listed here, The proper procedure involves grounding out a pin on a harness. Do a search on Transmission codes and the procedure will show up.
nipper replied to ettev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnipper PS is basically just turn the key and drive . Normal maint and AWD test drive warnings do apply.
New engine with knock codes
nipper replied to DishMan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the knock sensor. nipper
Subaru Stereo Upgrade Mod :)
nipper replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSEE! Soft mush landyacht suspension is a good thing. http://jalopnik.com/cars/retro/screw-your-ipod-chryslers-in+car-phonograph-237401.php But it also only worked with columbia records. nipper
antifreeze
nipper replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStart with a new radiator cap. Usually with your symptons and history thats what it is.
nipper replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts not that simple. We also look at how often in a cars life the part is going to be serviced, how the engine is packaged etc etc etc. The timing belt gets changed once every 105 months, so its not necassary for it to be easily accessable. Now plugs there arent much we can do about. There is the always the BMW way of thinking, which is basically waiting for the day they can ommit the hood release and force you to take it to the dealer for everything nipper
Need cheap ideas before towing to the shop
nipper replied to dmanaenk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes they can, and 90% of the time they can go through the block. Inspect the top of the engine especially on the passenger side. Can also be a dropped valve. nipper
nipper replied to dmanaenk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles on it. Can you describe the noise better? This is not a electronic issue but a mechanical issue. Electronic issues dont make horrible noises. How old is the water pump? Pup the hood and inspect the underside of the engine, the belts, the vibration damper. I'm thinking a sieved water pumo, failed TB tensioner, or things deeper in the engine. nipper
Nextautos article: Top 10 Most Beautiful Subarus
That was my very first subaru, where it all began. nipper
Vibration in D
nipper replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou beat me to it nipper
96 outback idles rough at start
nipper replied to Scooby96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi'm tempted to say its a bad coolant temp sensor.
nipper replied to bikeweek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou left out the most critical part you got to put your left foot in you got to put your left foot out you got to shake it all about..
Any Diesel Reliability Reports from Across the Pond?
nipper replied to daehttub2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi'm all ears It's a standard, so its just a multiplexed system. Basically how hard can it be
nipper replied to daehttub2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe ignition key is netowrked as part of the anyt-theft stuff to the ECU. SO that means you need the switch also, or some work around. nipper
nipper replied to daehttub2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUn fortunitly that may be neerly impossible. The people on the subaru/vanagon list are asking the same thing. It turns out thier ECU is CAN bus type. In plain english it means it is mulitplexed with the rest of the car. It is a digital system, not an analog, so its very hard to fake things out. Also one may need the entrie car to do the first conversion, as who-knows what talks to what to make it run. So it would be a challange, but hey, someone will be crazy enough, er um, daring to take the lead. nipper
2kobw: auto trans can't decide on a gear
nipper replied to hustler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could, but since modern cars are so quiet, when you run with an open pipe they are so incredibly noisey in comparison. A vac gauge is a much better tool for this. nipper
