Everything posted by nipper
Turn signal quit, module location?
nipper replied to electrifierus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe you just ran out of blinker fluid? Near the fuse block on the drivers side, i am just not sure which one it is exactly. Haynes is vague and i never had to replace one before. nipper
speedo not working HELP!
nipper replied to crash321's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd there is a bunch of wire and a few connectors between the two. Take it back and tell him he didnt fix it and your not paying for anymore work since there was nothing wrong with the first spedo. This is an easy thing to diagnose, so i dont know what the problem is. nipper
Problems with an EJ22 motor
nipper replied to s'ko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf he had a crank issue to yes, but its cranking fine it seems, so there is a good ground between engine and battery. nipper
Thick gray-white smoke from exhaust of '05 Baja
nipper replied to Brooklyn Baja's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe not. How far did you drive it after the cruise dropped out. You also may have just shortened its life. nipper
nipper replied to Brooklyn Baja's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBoy it doesnt take long for the vultures to circle in these parts nipper
nipper replied to crash321's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX98 spedos rarely go bad. 1999-2000-2001 are suspect. You have two VSS sesnors if its an automatic, one if its a manual. I would suspect the VSS sensors first before a spedo, they are easy enough for a tech to test. Was this a sooby tech?
nipper replied to crash321's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes i have a suggestion Always post year and mileage, otherwise can just sit here and throw gueses at you. Do you have a CEL on? Is this an auto or a manual? Always important information.
2001 outback automatic transmission issue
nipper replied to Tigger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn aluminum engines, its a MUST that they go to the machine shop. The head may be flat but the surface finish will not be what it was new, and that has to be restored. Both HG's need to be done. Also if its weeping you can wait months before you repair it (read summer). Just check the fluids regularly. nipper
nipper replied to s'ko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHard Start is usually the TPS sensor. Clear all the codes and run the car again, then pull the codes. Alot of those are related by a common denominator of the car not starting when its supposed to. nipper
nipper replied to Brooklyn Baja's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCHECK YOUR FLUIDS IMMEDIATLY! If your turbo is sucking up the fluids in the car you can blow the engine. Get the car towed to the dealer. How many miles are on it? nipper
Why are suby transmissions so heavy?
Well they have a lot of stuff in them. And do simple math, alot of force is handled by them too. mipper
99 obw with p117 CD player quetions
nipper replied to asuman1179's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're pretty
nipper replied to asuman1179's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.amazon.com/Gold-Archive-minute-CD-R-jewel/dp/B00065DG8W Amazon is your freind. nipper
Coolant overflow tank full??
nipper replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry the cap first. It's cheap enough and probably need one anyway. nipper
Justy Knowledge?
The justy board is quiet but lots of info there. nipper
Anyone try Pulstar plugs?
nipper replied to FSRBIKER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhich actually is fair criteria to spec out plugs with. nipper
nipper replied to FSRBIKER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAMEN to that. There was a time with points and liquid filled coils that they made a differnce, but not now with modern ignition systems. nipper
NE - NY, NJ, CT, PA, MD - Pine Barrens NJ OUTING *** Sat jan 17th***
Your not allowed to burn your car....
Starting issue
nipper replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi repeat myself.
nipper replied to FSRBIKER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot here that i know of but i do have a bridge i can sell you. Soobys are simple cars they like the stock plugs, otherwise you can misfire codes on the ECU. They have been tried on the outback board and showed no real benefit except for the sale of code scanners to figure out the misfire codes. nipper
Can cold affect HLAs or is it just coincidence
nipper replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery cold weather does affect engines, machines, and animals too. Give the 5-30 a try. But make sure the oil is room temp and not sitting out in your garage when you fo it. nipper
Starting issue
nipper replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you start this as a new thread please, it would make it easier for us. How many miles on the car, also does it crank and not run, or just do nothing. nipper
OBW heated seat and radio not working
nipper replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust check the heaters at the seats for continuity. No reason to go nuts looking deeper just yet. Besides you have that lump of coal you can always use for heat nipper
nipper replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI forget, was this car in a crash? Drivers side seat heater commonly fails from us dragging our buts in and out of the seat repeatedly. Also the G force of an impact and the shifting of a body can do the same thing. nipper
Mysterious Warning Lights....
nipper replied to crysbren's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldnt even bother getting the codes read right now. Look under the car make sure nothing is dangling anywwhere (nothing broke). Disconnect the battery for ten minutes, that should clear the codes. In some CEL failures the car will disable the cruise. If its still an issue get the codes read at a autozone. nipper
