25
Everything posted by nipper
Just adjust the cable on the hill holder, no biggie. nipper
I used name brand aftermarket for mine when i had it. nipper
No your asking it to drive nothing more then a hloow shaft that has no resistance to rotation. The viscous coupling needs a resistance to start heating up and operating. If one side is free spinning ( a disconnected ddriveshaft) he is doing it no harm. And the VC only transfers power to the rear. Subarus are FWD by default. nipper
Leave the filter alone. These transmissions don't shed particles, so no need for it. Also they are tough to get to reseal properly. Remeber that those gaskets have been there for many many many years trouble free. Why mess with something that may cause nothing but heartache later. Use the subaru or whatever you usually use coolant. The car has reached 180,000 miles on the regular stuff, so why mess with a good thing. Any change this late in the game could possibly clog the radiator. Replace the t-stat and radiator cap, and water pump. The first thing you need to do before anything is to flush out the radiator when you start to pull out the engine. You dont want any of the old antifreeze start to solidify when the air hits it. If you really want to do the transmission a favor, add a small cooler to it. Tell your wife not to use the cruise control on mountain roads. Use it on rolling hills or flat surfaces only. Everyone will be much happier that way. Also i recomend AAA membership.
How heavy is the trailer. Anything on the roof will kill the gas mileage, where a trailer at highway speeds is essentially tailgating. So if it is smooth, it fits in the cars slip stream. The only thing about trailer towing is to use the heavy duty maintanence scheduale (which i think we should use all the time anyway). If you have an automatic, I would recomend a tranny cooler. The automatic takes the biggest beating on towing, its cheap insurance. nipper
Here in NY they are chick cars. I think they only sold one in the entire state, as thats all i ever see. nipper
i like snow camo myself...
"whoomp whoomp whoomp" up front.
nipper replied to TeamCF's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If its 4wd, just put it in 4wd with the one front axle out of it, it will move on its own. nipper -
Tire Rotation
nipper replied to PaulMidi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thats close to what i do. nipper -
Tire Rotation
front to rear same side. If you have a full sized spare add that to the mix of one side. i usually do it once in the fall and once in the spring, but nmow that im driving less then 10,000 miles a year i just do it in the fall. nipper -
You didnt forget the retaining sping pin for the axle? You really arent supposed to reuse those, and they are directional in how they get installed. I would look at that too. nipper -
If this was my engine .... I would take off the heads, see whats going on (better now then its in the car). I would also reseal the engine, replace the water pump at this time and replace the timing belt. Check the timing and make sure its on the money. For this low a mileage engine (but long on time) , its due for all that stuff anyway. nipper
Tires. Rotate the tires and see if it moves.
