Everything posted by nipper
International Users: Help Identify This Part!
CHrome thing is a bezel. I see them ocassionally on ebay. I like my idea better .... GODZILLA! nipper
Thankyou for driving your subaru for fresh air, press one for recirculated air, press two for an operator, press O nipper
2003 LLbean OBW- crappy handling
nipper replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf its an emergency manuver, it would be air pressure and roll bar (and bushings). If it some wierdness in a straight line, its air presure it seems. nipper
nipper replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is kicking around the outback board, and it looks like they are really sensative to tire pressure. 31 psi seems to be the magic number. Go higher then that and everything gets scary. If you feel like reading 10 pages of posts http://www.subaruoutback.org/forums/showthread.php?s=&threadid=11267&perpage=20&highlight=dangerous&pagenumber=1 One guy did extensive testing with dead weight in the car and air pressure and 31psi may resolve it. nipper
Water leak that fills up the spare tire well
nipper replied to aircraft engineer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno sunroof correct? nipper
One is the ejector seat, the other is the anti Godzilla defense system nipper
Dude, I just got snaked by a Subaru
nipper replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats my kind of snow boarding.... say.... How do they git it on the ski lift? nipper
Brake Fluid flushing method ... discuss....
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd your ahead of me, i use my best freinds foot nipper
301,302,303 Codes on 01 Legacy 2.5l
nipper replied to cabron's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi keep forgetting about that recall that would do it. nipper
Misfire in #4 code, can't solve
nipper replied to garthpro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsually, if you use an OE o2 sensor, it will last way beyond 100,000 miles. Mine lasted 180,000, and it saw a hell of a lot of NYC driving (you dont get much more city then that). Th o2 sensor usually throws its own code unless its long in the tooth, and getting lazy. there are tests with a multimeter you can do check the sensor. nipper
nipper replied to cabron's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNext time the CEL comes on, make note of the weather conditions, it will help us diagnose. Clear the codes, so we can start off fresh. How long ago did this start? nipper
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats what I thought, i was wondering if i missed something from someplace. This guy Junior tend to piss me off at times, I read his column as a big ad for aldata and delaerships most the time. nipper
nipper replied to cabron's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso last time the timing belt was changed?
nipper replied to cabron's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles, auto or manual? nipper
I have always done this when bleading the brakes. Use a turbey baster to get the old fluid out of the master cylinder, put in fresh, and bleed. Today in the automotive advice column, there was a letter about DOT3. The columnist (who i am not a fan off for his usual response of take car to dealer), said to use the turkey baster trick several times over a couple of weeks. Tis would be the same thing as a beading type flush. Thinking about this, I can see the pros and cons to both sides (big con is contaminating new fluid with old (which may have water in it). So thoughts and opinions? nipper
clutch slips, but not sure
nipper replied to eastwestboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemeber that the cold can do weird thigs to cars. Things that happen in biiter cold need to be montiored, but arent necassarily a problem. The clutch test is to try to start off frem a dead stop in 4th or 5th gear. if the car stalls the clutch is fine. If you can do it, its time to start budgeting for a clutch. The test doesnt mean the clutch is going to go out tomorrow, or even next week, just something to plan for. If it only does it when its bitter cold, I wouldnt worry. I had a civic that would do the opposit, in heavy traffic the clutch would slip in 3rd geag (stop and go). There was nothing wrong with the clutch, it was just getting hot. I would just blame this on the cold, be aware of it, give the clutch time to warm up, and see what happens when the weather warms up. nipper
Check this guy out...
nipper replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm bored. If someone wants to send me one brand new OX axle and an aftermarket i'll take them apart (like thats going to happen) nipper
head light and fog lights work sometimes
nipper replied to 1997outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXElectrical socket and grounds i would check. nipper
TPS Adjustment and Sputtering on SVX
nipper replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subaru-svx.net/forum/ you can ask there. They arent the most social people, but they are up on SVX tech. nipper
Loud gunshot BANG '94 Legacy
nipper replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you hit anything? Backfires are kind of rare these days, but can kill a catalytic converter. When was the last time you had a tuneup? nipper
rear washer squirts during acceleration... ('98 Imp)
nipper replied to Spiffy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHAHAHAHA It gets so excited it has to pee !!!
4spd auto- clunk on downshift
nipper replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was thinking that, easyiest way to tell, put the FWD fuse in the holder and see if it goes away. Are all your tires matching and properly inflated? nipper
2004 2.5 coolant odor - head gasket?
nipper replied to Philbiker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats always the smartest way to do it. nipper
Best answer to repair collision damage?
nipper replied to CPAScott's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot necassarily. When i hit the deer, the adjuster quoted the price of used parts. The shop went ahead and ordered all new parts for the quoted used parts. I am very happy, and all the parts have a lifetime warrenty. It just depends upon the body shop and the insurance company. nipper
nipper replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it has more to do with tolerances and the after market axles being too tight. I would love to disect a good OE axle and an aftermarket axle and blueprint them. nipper
