25
Everything posted by nipper
The Unicorn Found! Video proof of long bed brat!
nipper replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i love it. nipper -
The noise sounds like a throw out bearing. The input shaft would be there whenever the tranny is unloaded (deceleration or neutral) i would think. Once again its hard to say over the net. IF you can get a stethascope on the fork you should be able to tell. A tranny bearing wont transmit to the fork as much as a to Bearing. a TO bearing wouldnt be heard in the tranny housing. Just an idea. If its an orginal TO bearing, its about the right time for it to be upset. Test your power brake booster. With the car off pump the brakes ten times. With your foot on the brake pedal start the car, it should go to the floor. I am wondering if you have an odd vacume leak that seals itself up in the booster. nipper
Damnit, now your giving me ideas .... nipper
There is nothing you can do except hope that the parking space is really really close to the old one. The automatics can be towed for a short distance with only one set of wheels, since theere is no pressure in the system to engage the clutches. This will do damage Since one set of clutches are spinning, the others arent, and no lubrication. The manual has the viscous coupling which may get damaged. The Fuse only works when the car is on. I have no idea what thier tolerance is for damage on the hook. NYC tows cars all the time with a hook, and so do a lot of other cities. Hooke em and get them out asap. Subaru says never to tow this way. In some cities there is so much stop and go traffic the AWD units never get to dramatically heat up If there is damage it would be torque bind. Wish I had better information. nipper
A HG can blow whenever it feels like blowing. It's an old car. If it blows, you will know it. Too cold wont be a HG issue. If it does stay that cold, change your oil a little more often. Make sure your coolant is up to the task. nipper
Then dont worry about it too much. My 87 would do the same thing in the 20's. It was so bad i would block half the radiator with cardboard to get heat. If it is above 30 or more (yes 10 degrees can make a differnce) then i would worry. nipper
Whats the air temperiture? nipper
That too.. another thing is that the oil may never get fully warm either. nipper
Yes it is. The car never heats up so the engine will never run at peak performance. You will always run rich. Sounds like your thermostat is stuck wide open. nipper
You may throw some codes, the cruise control may not work at all...a couple of possabilities. Don't cut the wire, just disconnect it and see what happens. Remember though, its alos not good for the car to not downshift, as you can lug the engine. If cutting the wire stops the engine from downshifting, that would still require your intervention, so just pushing the small pedal may just be simpler. It's worth a try. nipper
There is absolutly no replacement for them? Damn that sucks. nipper
The downshifting on hills with cruise on, almost all cars do that now, and they downshift two gears. I even rented a car with a v-8 and it did the same thing. The best way to deal with the cruise on hills, is either put the car in D3 if there are a lot of hills, or press the skinny pedal with your right foot to slowly feed throttle so the cruise doesnt ask for a down shift. nipper
Its been ages, so i dont remeber if they come out. I have a theory, that all busings are replaceable. When they have had a happy home for (in car years) eons, they dont want to come out in one peice. I usually get the metal sleeve out any way i can, then ungracefully rip out the bushings. Once you get the sleeve out, you can cut the bushing. YOu can try using a penetrating oil to allow the rust to release its hold from the rubber. I have also used a torch. nipper
